RSB release's default mode for building kernels
Wed Jan 17 06:11:51 UTC 2018
On 16/01/18 23:35, Joel Sherrill wrote:
> On Tue, Jan 16, 2018 at 4:27 PM, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     Hi,
>     The current mode on all release branches is to build the RTEMS
>     kernel. The
>     purpose was to have a single command that builds the tools and
>     RTEMS. However
>     this means all BSPs for an architecture are built and this is not
>     practical
>     because it slows a build and uses a larger amount of disk space
>     when an
>     architecture has a larger number of BSPs so I am wondering if the
>     default is
>     reversed.
> I think RTEMS itself should not be built as part of the tools.
Yes, only the tools should be built by default.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
