[PATCH] rtems: Remove unused configuration files.
Thu Jan 18 02:59:50 UTC 2018
Close #3273
 rtems/config/tools/rtems-binutils-2.19.1-1.cfg     |  13 --
 rtems/config/tools/rtems-binutils-2.20.1-1.cfg     |  23 ---
 rtems/config/tools/rtems-binutils-2.22-1.cfg       |  15 --
 rtems/config/tools/rtems-binutils-2.23.2-1.cfg     |  20 ---
 rtems/config/tools/rtems-binutils-2.24-1.cfg       |  22 ---
 rtems/config/tools/rtems-binutils-2.25-1.cfg       |  22 ---
 rtems/config/tools/rtems-binutils-2.26-1.cfg       |  33 ----
 rtems/config/tools/rtems-binutils-2.27-1.cfg       |  28 ----
 rtems/config/tools/rtems-binutils-2.28-1.cfg       |  22 ---
 ...-3bf8131ac6b263e54669d9c282c6f69395355435-1.cfg |  21 ---
 rtems/config/tools/rtems-binutils-git-1.cfg        |  21 ---
 .../tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg      |  41 -----
 .../tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg      |  54 -------
 .../tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg       |  26 ---
 .../tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg       |  26 ---
 .../tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg      |  43 -----
 .../tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg      |  52 ------
 .../tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg       |  32 ----
 .../tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg       |  32 ----
 rtems/config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg  |  43 -----
 rtems/config/tools/rtems-gcc-4.8-newlib-git-1.cfg  |  43 -----
 .../tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg      |  26 ---
 .../config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg  |  37 -----
 .../config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg  |  50 ------
 .../tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg       |  39 -----
 .../config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg  |  13 --
 .../rtems-gcc-4.8.3-newlib-2.2.0-20150423-1.cfg    |  14 --
 .../rtems-gcc-4.8.3-newlib-2.20.0-20150323-1.cfg   |  14 --
 .../tools/rtems-gcc-4.8.3-newlib-2.4.0-1.cfg       |  14 --
 .../rtems-gcc-4.8.3-newlib-2.4.0.20160527-1.cfg    |   7 -
 .../tools/rtems-gcc-4.8.3-newlib-2.5.0-1.cfg       |  10 --
 .../rtems-gcc-4.8.3-newlib-2.5.0.20170228-1.cfg    |   7 -
 .../rtems-gcc-4.8.3-newlib-2.5.0.20170323-1.cfg    |   7 -
 .../rtems-gcc-4.8.3-newlib-2.5.0.20170519-1.cfg    |  34 ----
 .../rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg    |  42 -----
 .../rtems-gcc-4.8.3-newlib-2.5.0.20170720-1.cfg    |  10 --
 .../rtems-gcc-4.8.3-newlib-2.5.0.20170818-1.cfg    |  12 --
 .../config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg  |  13 --
 .../config/tools/rtems-gcc-4.8.3-newlib-git-1.cfg  |  13 --
 rtems/config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg  |  43 -----
 rtems/config/tools/rtems-gcc-4.9-newlib-git-1.cfg  |  43 -----
 .../tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg       |  40 -----
 .../config/tools/rtems-gcc-4.9.0-newlib-cvs-1.cfg  |  11 --
 .../config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg  |  13 --
 .../config/tools/rtems-gcc-4.9.1-newlib-git-1.cfg  |  13 --
 .../tools/rtems-gcc-4.9.2-newlib-2.2.0-1-1.cfg     |  14 --
 .../rtems-gcc-4.9.2-newlib-2.2.0-20150423-1.cfg    |  14 --
 .../rtems-gcc-4.9.2-newlib-2.20.0-20150323-1.cfg   |  14 --
 .../tools/rtems-gcc-4.9.2-newlib-2.4.0-1.cfg       |  15 --
 .../rtems-gcc-4.9.2-newlib-2.4.0.20160527-1.cfg    |   7 -
 .../tools/rtems-gcc-4.9.2-newlib-2.5.0-1.cfg       |  10 --
 .../rtems-gcc-4.9.2-newlib-2.5.0.20170228-1.cfg    |   7 -
 .../rtems-gcc-4.9.2-newlib-2.5.0.20170323-1.cfg    |   7 -
 .../rtems-gcc-4.9.2-newlib-2.5.0.20170519-1.cfg    |  34 ----
 .../rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg    |  28 ----
 .../rtems-gcc-4.9.2-newlib-2.5.0.20170720-1.cfg    |  10 --
 .../rtems-gcc-4.9.2-newlib-2.5.0.20170818-1.cfg    |  12 --
 .../config/tools/rtems-gcc-4.9.2-newlib-git-1.cfg  |  13 --
 .../rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg    |  14 --
 .../tools/rtems-gcc-4.9.3-newlib-2.4.0-1.cfg       |  15 --
 .../rtems-gcc-4.9.3-newlib-2.4.0.20160527-1.cfg    |   7 -
 .../tools/rtems-gcc-4.9.3-newlib-2.5.0-1.cfg       |  10 --
 .../rtems-gcc-4.9.3-newlib-2.5.0.20170228-1.cfg    |   7 -
 .../rtems-gcc-4.9.3-newlib-2.5.0.20170323-1.cfg    |   7 -
 .../rtems-gcc-4.9.3-newlib-2.5.0.20170519-1.cfg    |  34 ----
 .../rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg    |  28 ----
 .../rtems-gcc-4.9.3-newlib-2.5.0.20170720-1.cfg    |  10 --
 .../rtems-gcc-4.9.3-newlib-2.5.0.20170818-1.cfg    |  12 --
 ...tems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg |  16 --
 ...tems-gcc-6-20160117-newlib-2.3.0.20160104-1.cfg |  22 ---
 ...tems-gcc-6-20160124-newlib-2.3.0.20160104-1.cfg |  22 ---
 ...tems-gcc-6-20160228-newlib-2.3.0.20160226-1.cfg |  22 ---
 .../tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg  |  25 ---
 ...tems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg |  22 ---
 ...tems-gcc-6-20160609-newlib-2.4.0.20160527-1.cfg |  23 ---
 ...tems-gcc-6-20161110-newlib-2.4.0.20161025-1.cfg |  23 ---
 .../rtems-gcc-6.0.1-RC-20160415-newlib-2.4.0-1.cfg |  25 ---
 .../tools/rtems-gcc-6.3.0-newlib-2.5.0-1.cfg       |  23 ---
 .../rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg    |  23 ---
 .../rtems-gcc-6.3.0-newlib-2.5.0.20170323-1.cfg    |  65 --------
 .../rtems-gcc-6.3.0-newlib-2.5.0.20170519-1.cfg    |  58 -------
 .../rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg    |  52 ------
 .../rtems-gcc-6.3.0-newlib-2.5.0.20170720-1.cfg    |  34 ----
 .../rtems-gcc-6.3.0-newlib-2.5.0.20170818-1.cfg    |  36 -----
 .../rtems-gcc-6.3.0-newlib-2.5.0.20170922-1.cfg    |  40 -----
 .../rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg    |  70 --------
 .../rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg    |  62 -------
 .../rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg    |  58 -------
 .../rtems-gcc-7.1.0-newlib-2.5.0.20170720-1.cfg    |  42 -----
 .../rtems-gcc-7.1.0-newlib-2.5.0.20170818-1.cfg    |  42 -----
 .../rtems-gcc-7.1.0-newlib-2.5.0.20170922-1.cfg    |  46 ------
 .../rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg    |  40 -----
 .../rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg    |  50 ------
 rtems/config/tools/rtems-gdb-6.8-1.cfg             |  27 ----
 rtems/config/tools/rtems-gdb-7.11-1.cfg            |  32 ----
 rtems/config/tools/rtems-gdb-7.11-2.cfg            |  20 ---
 rtems/config/tools/rtems-gdb-7.12-1.cfg            |  41 -----
 rtems/config/tools/rtems-gdb-7.3.1-1.cfg           |  20 ---
 rtems/config/tools/rtems-gdb-7.5-1.cfg             |  15 --
 rtems/config/tools/rtems-gdb-7.5.1-1.cfg           |  13 --
 rtems/config/tools/rtems-gdb-7.6-1.cfg             |  13 --
 rtems/config/tools/rtems-gdb-7.6.1-1.cfg           |  13 --
 rtems/config/tools/rtems-gdb-7.6.2-1.cfg           |  17 --
 rtems/config/tools/rtems-gdb-7.7-1.cfg             |  29 ----
 rtems/config/tools/rtems-gdb-7.7.1-1.cfg           |  26 ---
 rtems/config/tools/rtems-gdb-7.8.1-1.cfg           |  28 ----
 rtems/config/tools/rtems-gdb-7.8.2-1.cfg           |  29 ----
 rtems/config/tools/rtems-gdb-7.9-1.cfg             |  42 -----
 rtems/config/tools/rtems-kernel-4.10.2.cfg         |  17 --
 rtems/config/tools/rtems-kernel-4.9.6-1.cfg        |  17 --
 rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg    |  11 --
 rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg    |  11 --
 rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg    |  11 --
 rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg |  26 ---
 .../tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg  | 179 ---------------------
 rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg       |  19 ---
 rtems/config/tools/rtems-tools-4.11-1.cfg          |  17 --
 117 files changed, 3100 deletions(-)
 delete mode 100644 rtems/config/tools/rtems-binutils-2.19.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-2.20.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-2.22-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-2.23.2-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-2.24-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-2.25-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-2.26-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-2.27-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-2.28-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-3bf8131ac6b263e54669d9c282c6f69395355435-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-git-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8-newlib-git-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.2.0-20150423-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.20.0-20150323-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.4.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.4.0.20160527-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170228-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170323-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170519-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170720-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170818-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-git-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9-newlib-git-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.0-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.1-newlib-git-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-20150423-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.20.0-20150323-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.4.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.4.0.20160527-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170228-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170323-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170519-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170720-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170818-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-git-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-2.4.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-2.4.0.20160527-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170228-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170323-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170519-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170720-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170818-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6-20160117-newlib-2.3.0.20160104-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6-20160124-newlib-2.3.0.20160104-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6-20160609-newlib-2.4.0.20160527-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6-20161110-newlib-2.4.0.20161025-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6.0.1-RC-20160415-newlib-2.4.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170323-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170519-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170720-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170818-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170922-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170720-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170818-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170922-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-6.8-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.11-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.11-2.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.12-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.3.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.5-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.5.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.6-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.6.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.6.2-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.7-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.7.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.8.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.8.2-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.9-1.cfg
 delete mode 100644 rtems/config/tools/rtems-kernel-4.10.2.cfg
 delete mode 100644 rtems/config/tools/rtems-kernel-4.9.6-1.cfg
 delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
 delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
 delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg
 delete mode 100644 rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg
 delete mode 100644 rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-tools-4.11-1.cfg
diff --git a/rtems/config/tools/rtems-binutils-2.19.1-1.cfg b/rtems/config/tools/rtems-binutils-2.19.1-1.cfg
deleted file mode 100644
index fb9f018..0000000
--- a/rtems/config/tools/rtems-binutils-2.19.1-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# Binutils 2.19.
-%include %{_configdir}/checks.cfg
-%include %{_configdir}/base.cfg
-%define binutils_version 2.19.1
-# The binutils build instructions. We use 2.xx Release 1.
-%include %{_configdir}/binutils-2-1.cfg
diff --git a/rtems/config/tools/rtems-binutils-2.20.1-1.cfg b/rtems/config/tools/rtems-binutils-2.20.1-1.cfg
index 1e2fee3..0000000
--- a/rtems/config/tools/rtems-binutils-2.20.1-1.cfg
+++ /dev/null
@@ -1,23 +0,0 @@
-# Binutils 2.20.
-%define binutils_version 2.20.1
-%hash md5 binutils-%{binutils_version}.tar.bz2 2b9dc8f2b7dbd5ec5992c6e29de0b764
-%patch add binutils %{rtems_binutils_patches}/binutils-2.20.1-rtems4.10-20100826.diff
-%hash md5 binutils-2.20.1-rtems4.10-20100826.diff 733899876e0b32ce0700666b29662d91
-%patch add binutils %{rtems_binutils_patches}/binutils-2.20.1-rtems4.10-20151123.diff
-%hash sha512 binutils-2.20.1-rtems4.10-20151123.diff ce24ba3e56e7552739c167950a488d80557fdf562dcb527b2e5972c2d18da42a8fd1a47197e54aff0df630d105eb40702f09cad330c193cb8f9309b43b1fb1bc
-%ifos win32 mingw ming32 cygwin
- %patch add binutils %{rtems_binutils_patches}/cygwin/binutils-2.20.1-cygwin-w64-20130324.diff
-%endif
diff --git a/rtems/config/tools/rtems-binutils-2.22-1.cfg b/rtems/config/tools/rtems-binutils-2.22-1.cfg
index 664f5d9..0000000
--- a/rtems/config/tools/rtems-binutils-2.22-1.cfg
+++ /dev/null
@@ -1,15 +0,0 @@
-# Binutils 2.22.
-%define binutils_version 2.22
-%patch add binutils %{rtems_binutils_patches}/binutils-2.22-rtems4.11-20120427.diff
diff --git a/rtems/config/tools/rtems-binutils-2.23.2-1.cfg b/rtems/config/tools/rtems-binutils-2.23.2-1.cfg
index d4f2c4b..0000000
--- a/rtems/config/tools/rtems-binutils-2.23.2-1.cfg
+++ /dev/null
@@ -1,20 +0,0 @@
-# Binutils 2.23.
-%define binutils_version 2.23.2
-# Enable deterministic archives by default. This will be the default
-# there all tools using this binutils will create deterministic
-# archives.
-%define with_deterministic_archives 1
diff --git a/rtems/config/tools/rtems-binutils-2.24-1.cfg b/rtems/config/tools/rtems-binutils-2.24-1.cfg
index 947588c..0000000
--- a/rtems/config/tools/rtems-binutils-2.24-1.cfg
+++ /dev/null
@@ -1,22 +0,0 @@
-# Binutils 2.24.
-%define binutils_version 2.24
-%hash sha256 binutils-%{binutils_version}.tar.bz2 e5e8c5be9664e7f7f96e0d09919110ab5ad597794f5b1809871177a0f0f14137
-# archives.
diff --git a/rtems/config/tools/rtems-binutils-2.25-1.cfg b/rtems/config/tools/rtems-binutils-2.25-1.cfg
index f0b910b..0000000
--- a/rtems/config/tools/rtems-binutils-2.25-1.cfg
+++ /dev/null
@@ -1,22 +0,0 @@
-# Binutils 2.25.
-%define binutils_version 2.25
-%hash md5 binutils-%{binutils_version}.tar.bz2 d9f3303f802a5b6b0bb73a335ab89d66
-# archives.
diff --git a/rtems/config/tools/rtems-binutils-2.26-1.cfg b/rtems/config/tools/rtems-binutils-2.26-1.cfg
index 945f61a..0000000
--- a/rtems/config/tools/rtems-binutils-2.26-1.cfg
+++ /dev/null
@@ -1,33 +0,0 @@
-# Binutils 2.26.
-%define binutils_version 2.26
-%hash sha512 binutils-%{binutils_version}.tar.bz2 e77e1b8dbbcbaf9ac2fae95c4403615808af3be03b2e1d32448cd3a7d32c43273f8bcace3f2de84ec120a982879295673029da306e2885dbf5f990584932cfc7
-# Patches for x86_64 and aarch64
-%patch add binutils -p1 %{rtems_binutils_patches}/binutils-2.26-rtems-aarch64-x86_64.patch
-%hash sha512 binutils-2.26-rtems-aarch64-x86_64.patch 2236cc22dda60d5c18a2ab5abc0f44bf487794f7c0899382bf49233e789e1fb34ce28b0f7a85069642f7cc06bd34d7634a441a8d92bf890de57bb89cc398349f
-# SPARC GAS fixes.
-%patch add binutils %{rtems_binutils_patches}/binutils-2.26-gas-reloc.patch
-%hash sha256 binutils-2.26-gas-reloc.patch 21f6e887a1e8308cf3dae9a9eba431b6d5afdf8798f48024f90d71fab07ceeee
-# archives.
diff --git a/rtems/config/tools/rtems-binutils-2.27-1.cfg b/rtems/config/tools/rtems-binutils-2.27-1.cfg
index b20b2ea..0000000
--- a/rtems/config/tools/rtems-binutils-2.27-1.cfg
+++ /dev/null
@@ -1,28 +0,0 @@
-# Binutils 2.26.
-%define binutils_version 2.27
-%hash sha512 binutils-%{binutils_version}.tar.bz2 cf276f84935312361a2ca077e04d0b469d23a3aed979d8ba5d92ea590904ffb2c2e7ed12cc842822bfc402836be86f479660cef3791aa62f3753d8a1a6f564cb
-# SPARC GAS fixes.
-%hash md5 binutils-2.26-gas-reloc.patch 1b88374118c2da61eeaca9c4ba1ce42c
-# archives.
diff --git a/rtems/config/tools/rtems-binutils-2.28-1.cfg b/rtems/config/tools/rtems-binutils-2.28-1.cfg
index d1b7a11..0000000
--- a/rtems/config/tools/rtems-binutils-2.28-1.cfg
+++ /dev/null
@@ -1,22 +0,0 @@
-# Binutils 2.28.
-%define binutils_version 2.28
-%hash sha512 binutils-%{binutils_version}.tar.bz2 ede2e4e59a800260eea8c14eafbaee94e30abadafd5c419a3370f9f62213cf027d6400a1d4970b6958bd4d220e675dcd483a708107016e7abd5c99d7392ba8fd
-# archives.
diff --git a/rtems/config/tools/rtems-binutils-3bf8131ac6b263e54669d9c282c6f69395355435-1.cfg b/rtems/config/tools/rtems-binutils-3bf8131ac6b263e54669d9c282c6f69395355435-1.cfg
index a627389..0000000
--- a/rtems/config/tools/rtems-binutils-3bf8131ac6b263e54669d9c282c6f69395355435-1.cfg
+++ /dev/null
@@ -1,21 +0,0 @@
-# Binutils GIT.
-%define binutils_version 3bf8131ac6b263e54669d9c282c6f69395355435
-%source set binutils git://sourceware.org/git/binutils-gdb.git?fetch?reset=hard?branch=master?checkout=%{binutils_version}
-# archives.
diff --git a/rtems/config/tools/rtems-binutils-git-1.cfg b/rtems/config/tools/rtems-binutils-git-1.cfg
index da64bc1..0000000
--- a/rtems/config/tools/rtems-binutils-git-1.cfg
+++ /dev/null
@@ -1,21 +0,0 @@
-# Binutils GIT.
-%define binutils_version 6ae274b7dc305ae7cebcf55c5018dab05228235a
-# archives.
diff --git a/rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg b/rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
index 2ef31bb..0000000
--- a/rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
+++ /dev/null
@@ -1,41 +0,0 @@
-# GCC 4.3.1., Newlib 1.16.0
-%define gcc_version    4.3.2
-%define newlib_version 1.16.0
-%define mpfr_version   2.4.2
-%define mpc_version    0.8.2
-%define gmp_version    5.0.5
-%define with_threads 1
-%define with_plugin  0
-%define with_iconv   0
-# The RTEMS 4.9 patches
-%source set gcc ftp://ftp.gnu.org/pub/gnu/gcc/gcc-%{gcc_version}/gcc-core-%{gcc_version}.tar.bz2
-%patch  add gcc %{rtems_gcc_patches}/gcc-core-4.3.2-rtems4.9-20090825.diff
-%source add gcc ftp://ftp.gnu.org/pub/gnu/gcc/gcc-%{gcc_version}/gcc-g++-%{gcc_version}.tar.bz2
-%patch  add newlib %{rtems_newlib_patches}/newlib-1.16.0-rtems4.9-20090324.diff
-# Checksums.
-%hash sha512 gcc-core-4.3.2.tar.bz2 7fa7cfd57b3cb37990f41132037666d511a480df28d6d5a0620520501488abad89c7843067188bbe23f0c4d3eb5d113537a6a9375135596b58b3d7a848dc8a39
-%hash sha512 gcc-core-4.3.2-rtems4.9-20090825.diff d326372a756a7289404031eb16dcc51c15259342ea3f8697f23cfa754ee38305d5e6aaeef56c83f11cdd28c85711c430d894a87303ad932b024a17fa4aaa4f63
-%hash sha512 gcc-g++-%{gcc_version}.tar.bz2 b349344a9ea67418cca4b7465263e7c28b28008b9fbd76d7db2fb4ad38e63a943c601bc33e641319d48a48a8848562afff96c9ddaf90141d9ab835be6b955bb7
-%hash sha512 mpfr-2.4.2.tar.bz2 c004b3dbf86c04960e4a1f8db37a409a7cc4cb76135e76e98dcc5ad93aaa8deb62334ee13ff84447a7c12a5e8cb57f25c62ac908c24920f1fb1a38d79d4a4c5e
-%hash sha512 mpc-0.8.2.tar.gz dcaac3897adf1411e1199e295e88d7438afc600f412565c3b450b0102b83751eb160f85b7522891195ff0a0a29fccedd07dc011a950969a0979c4e3d4efc1e10
-%hash sha512 gmp-5.0.5.tar.bz2 64ba88a4a64fefb16eae9c644ea81194011ea0b42664a5af6b014e7da3d0f09605dee518b9a361b06510311cdfd496ab68d09da3d85d6680bdac3f765eb67f61
-%hash sha512 newlib-1.16.0.tar.gz 40eb96bbc6736a16b6399e0cdb73e853d0d90b685c967e77899183446664d64570277a633fdafdefc351b46ce210a99115769a1d9f47ac749d7e82837d4d1ac3
-%hash sha512 newlib-1.16.0-rtems4.9-20090324.diff 6222e85dc8a5f49089742b09348b4f9663861d8c41dba79227d0ff343d4a9f71a5a1d7aacd61567401b924c6453f0e44bc8045226f25ded2bd3fa8ede4c9742f
-# The gcc/newlib build instructions. We use 4.7 Release 1.
-%include %{_configdir}/gcc-4.3-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg b/rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg
index adc8957..0000000
--- a/rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg
+++ /dev/null
@@ -1,54 +0,0 @@
-# GCC 4.4.7, Newlib 1.18.0
-# M32C C++ does not work.
-#   gcc-4.4.7/libstdc++-v3/src/mt_allocator.cc:76: error: cast from 'void*' to 'size_t' loses precision
-%if %{_target} == m32c-rtems4.10
-%define enable_cxx 0
-%endif
-%define gcc_version    4.4.7
-%define newlib_version 1.18.0
-%define mpc_version    0.8.1
-%define with_iconv   1
-%hash md5 gcc-core-%{gcc_version}.tar.bz2 3bda0831d654964ee152c46fa8d29e46
-%hash md5 gcc-g++-%{gcc_version}.tar.gz 421ba1dfe821f32998b28ee40e71dd37
-%hash md5 newlib-%{newlib_version}.tar.gz 3dae127d4aa659d72f8ea8c0ff2a7a20
-# Hash checksums of the libraries used in GCC.
-%hash md5 mpfr-%{mpfr_version}.tar.bz2 89e59fe665e2b3ad44a6789f40b059a0
-%hash md5 mpc-%{mpc_version}.tar.gz    5b34aa804d514cc295414a963aedb6bf
-%hash md5 gmp-%{gmp_version}.tar.bz2   041487d25e9c230b0c42b106361055fe
-# The RTEMS 4.10 patches
-%patch add gcc %{rtems_gcc_patches}/gcc-core-4.4.7-rtems4.10-20120314.diff
-%hash md5 gcc-core-4.4.7-rtems4.10-20120314.diff 084c9085c255b1f6a9204e239dde0579
-%patch add gcc %{rtems_gcc_patches}/gcc-core-4.4.7-rtems4.10-20151123.diff
-%hash sha512 gcc-core-4.4.7-rtems4.10-20151123.diff 70e5868157fd02f011e66f8fa9dcdc3341deee47ff105d9102a501b6e346c0e635c70600ff0646ea5f28faf8152e806367cf8acb60ff35ac61348af20796c4e4
-%if %{enable_cxx}
- %patch add gcc %{rtems_gcc_patches}/gcc-g++-4.4.7-rtems4.10-20120314.diff
- %hash md5 gcc-g++-4.4.7-rtems4.10-20120314.diff e187db20f6d98048368f9ef86f9126dc
-%endif
-%patch add newlib %{rtems_newlib_patches}/newlib-1.18.0-rtems4.10-20110518.diff
-%hash md5 newlib-1.18.0-rtems4.10-20110518.diff e6508b36490d841b00d5011ed11cdc16
-# The gcc/newlib build instructions. We use 4.4 Release 1.
-%include %{_configdir}/gcc-4.4-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg b/rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg
index 0f5d225..0000000
--- a/rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg
+++ /dev/null
@@ -1,26 +0,0 @@
-# GCC 4.5.3., Newlib 2.0.0
-%define gcc_version    4.5.3
-%define newlib_version 2.0.0
-%define mpfr_version   3.0.1
-# Libiberty strsignal fix
-%patch add gcc %{rtems_gcc_patches}/gcc-4.5.3-strsignal-1.diff
-# The gcc/newlib build instructions. We use 4.5 Release 1.
-%include %{_configdir}/gcc-4.5-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg b/rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg
index 668e356..0000000
--- a/rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg
+++ /dev/null
@@ -1,26 +0,0 @@
-%define newlib_version 2.1.0
diff --git a/rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg b/rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg
index 9d63a92..0000000
--- a/rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg
+++ /dev/null
@@ -1,43 +0,0 @@
-# GCC 4.6.3, Newlib 1.20.0
-# AVR C++ does not work.
-#   configure: error: unable to detect exception model
-%if %{_target} == avr-rtems4.11
-%endif
-%if %{_target} == m32c-rtems4.11
-%endif
-%define gcc_version    4.6.3
-%define newlib_version 1.20.0
-# The RTEMS 4.11 patches
-%patch add gcc gcc-core-4.6.3-rtems4.11-20120303.diff
-%patch add newlib newlib-1.20.0-rtems4.11-20121011.diff
-%include %{_configdir}/gcc-4.6-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg b/rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg
index 167d7c5..0000000
--- a/rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg
+++ /dev/null
@@ -1,52 +0,0 @@
-# GCC 4.7.2., Newlib 1.20.0
-%endif
-#   gcc-4.7.2/libstdc++-v3/src/mt_allocator.cc:76: error: cast from 'void*' to 'size_t' loses precision
-%endif
-# If arm-rtems4.11 add --enable-obsolete.
-%if %{_target} == arm-rtems4.11
-%define enable_obsolete 1
-%else
-%define enable_obsolete 0
-%endif
-%define gcc_version    4.7.2
-%patch add gcc %{rtems_gcc_patches}/gcc-4.7.2-rtems4.11-20121026.diff
-%patch add newlib %{rtems_newlib_patches}/newlib-1.20.0-rtems4.11-20121011.diff
-%include %{_configdir}/gcc-4.7-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg b/rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg
index 8914815..0000000
--- a/rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg
+++ /dev/null
@@ -1,32 +0,0 @@
-# GCC 4.7.2., Newlib 2.0.0
-%include %{_configdir}/versions.cfg
-# Incompatible with Texinfo 5
-%if %{__makeinfo_ver} >= 5.0
- %error Incomaptible version of makeinfo found!
-%endif
diff --git a/rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg b/rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg
index 518e28b..0000000
--- a/rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg
+++ /dev/null
@@ -1,32 +0,0 @@
-%define gcc_version    4.7.3
-%patch add gcc %{rtems_gcc_patches}/gcc-4.7.3-rtems4.11-20130414.diff
-%endif
diff --git a/rtems/config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg
index 78514d4..0000000
--- a/rtems/config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,43 +0,0 @@
-# GCC 4.8.x., Newlib CVS
-%ifn %{defined gcc_version}
- %error No GCC version defined.
-%endif
-%ifn %{defined newlib_version}
- %error No Newlib version defined.
-%endif
-%ifn %{defined with_iconv}
-%endif
-%hash md5 mpfr-%{mpfr_version}.tar.bz2 bfbecb2eacb6d48432ead5cfc3f7390a
-%hash md5 mpc-%{mpc_version}.tar.gz    e98267ebd5648a39f881d66797122fb6
-# Newlib is from CVS.
-%source set newlib cvs://pserver:anoncvs@sourceware.org/cvs/src?module=newlib?src-prefix=src?date=%{newlib_version}?reset
-# The gcc/newlib build instructions. We use 4.8 Release 1.
-%include %{_configdir}/gcc-4.8-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.8-newlib-git-1.cfg b/rtems/config/tools/rtems-gcc-4.8-newlib-git-1.cfg
index 58d8b62..0000000
--- a/rtems/config/tools/rtems-gcc-4.8-newlib-git-1.cfg
+++ /dev/null
@@ -1,43 +0,0 @@
-# GCC 4.8.x., Newlib GIT.
-%endif
-%endif
- %define with_iconv 1
-%endif
-# Newlib is in git
-%source set newlib git://sourceware.org/git/newlib-cygwin.git?fetch?reset=hard?branch=master?checkout=%{newlib_version}
diff --git a/rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg b/rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg
index 0fd1641..0000000
--- a/rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg
+++ /dev/null
@@ -1,26 +0,0 @@
-# GCC 4.8.x., Newlib 2.0.0
-%define gcc_version    4.8-20130303
-%source set gcc ftp://gcc.gnu.org/pub/gcc/snapshots/%{gcc_version}/gcc-%{gcc_version}.tar.bz2
diff --git a/rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg
index 7c545fd..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,37 +0,0 @@
-# GCC 4.8.0., Newlib CVS
-%define gcc_version    4.8.0
-%define newlib_version 31-May-2013
-%endif
-# Joel's stack_t patch.
-%patch add newlib -p0 %{rtems_newlib_patches}/newlib-sys-signal-20130532.diff
diff --git a/rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg
index 32c6547..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,50 +0,0 @@
-# GCC 4.8.1., Newlib CVS
-%define gcc_version    4.8.1
-%define newlib_version 15-Sept-2013
-%endif
-%endif
-# Sebastian's atexit patch.
-%patch add gcc %{rtems_gcc_patches}/gcc-4.8.1-rtems4.11-20130709.diff
-# Chris's patch to use the POSIX thread model for C++.
-%patch add gcc %{rtems_gcc_patches}/gcc-rtems-thread-model-posix-1.diff
diff --git a/rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg b/rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg
index 2c6e5e5..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg
+++ /dev/null
@@ -1,39 +0,0 @@
-# GCC 4.8.2., Newlib 2.1.0
-%define gcc_version    4.8.2
-%endif
-# Hash checksums.
-%hash md5 gcc-%{gcc_version}.tar.bz2      a3d7d63b9cb6b6ea049469a0c4a43c9d
-%hash md5 newlib-%{newlib_version}.tar.gz c6559d83ecce4728a52f0ce7ec80de97
-%hash  md5 newlib-sys-signal-20130532.diff 34af05f28a4921e47c053528f5a8b9fb
diff --git a/rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg
index c9e89b2..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GCC 4.8.2., Newlib CVS
-%define newlib_version 12-Jul-2014
-%include tools/rtems-gcc-4.8-newlib-cvs-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.2.0-20150423-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.2.0-20150423-1.cfg
index 43a1e91..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.2.0-20150423-1.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
-# GCC 4.8.3, Newlib 2.2.0-1 (actually a snapshot)
-%define gcc_version    4.8.3
-%define newlib_version 2.2.0.20150423
-%hash md5 gcc-%{gcc_version}.tar.bz2 7c60f24fab389f77af203d2516ee110f
-%hash md5 newlib-%{newlib_version}.tar.gz c819de85d4cb4be540ebf6d405f42296
-%include tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.20.0-20150323-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.20.0-20150323-1.cfg
index 06d2963..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.20.0-20150323-1.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
-%define newlib_version 2.2.0.20150323
-%hash md5 newlib-%{newlib_version}.tar.gz a5107ff59e53a5731bdd0e245cbd1ad8
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.4.0-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.4.0-1.cfg
index b570148..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.4.0-1.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
-# GCC 4.8.3, Newlib 2.4.0-1
-%define newlib_version 2.4.0
-%hash sha512 newlib-2.4.0.tar.gz c60665e793dce2368a5baf23560beb50f641e1831854d702d1d7629fb6e9200cf814527f29796792a3d2dff81afee4255723df99ceb0732f99dd9580a17d2ac0
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.4.0.20160527-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.4.0.20160527-1.cfg
index 2e23618..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.4.0.20160527-1.cfg
+++ /dev/null
@@ -1,7 +0,0 @@
-%define newlib_version 2.4.0.20160527
-%hash sha512 gcc-%{gcc_version}.tar.bz2 2b40d231e8445f9c1654137df509f09ce1187b475138ca7f648f710d922a1718f740b2d8a37c26e16b5e27900c60358be98229ae884a6f1f70e9df44ad24d02b
-%hash sha512 newlib-2.4.0.20160527.tar.gz 09d0c8ac2a657e910eebfeeb7e5fcc6956591223fe499ed4717b5e719287148fc35e80835821fb5b6b586e371100737a7765a03c43f0c194cf67892484132d3f
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0-1.cfg
index 1f43ba1..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0-1.cfg
+++ /dev/null
@@ -1,10 +0,0 @@
-%define newlib_version 2.5.0
-%hash sha512 newlib-2.5.0.tar.gz 4c99e8dfcb4a7ad0769b9e173ff06628d82e4993ef87d3adf9d6b5578626b14de81b4b3c5f0673ddbb49dc9f3d3628f9f8d4432dcded91f5cd3d27b7d44343cd
-%patch add newlib %{rtems_newlib_patches}/RTEMS-Add-user-defined-name-to-thread-queues.patch
-%hash sha512 RTEMS-Add-user-defined-name-to-thread-queues.patch d7ab6c0a9d7688af1d4af0696365f4da5cf90a4e4edbd4b858ad266a98e7e35fa40713b6a86a07dd97895558afd9bc641bedf8d5aa907ef570f805fe8b802b15
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170228-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170228-1.cfg
index ce05262..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170228-1.cfg
+++ /dev/null
@@ -1,7 +0,0 @@
-%define newlib_version 2.5.0.20170228
-%hash sha512 gcc-4.8.3.tar.bz2 2b40d231e8445f9c1654137df509f09ce1187b475138ca7f648f710d922a1718f740b2d8a37c26e16b5e27900c60358be98229ae884a6f1f70e9df44ad24d02b
-%hash sha512 newlib-2.5.0.20170228.tar.gz d3d5b902bd2e30d24c51867c493c4672c83d2be1e574bea65b453e91641afe558bd305e8e6118b9926f21d86cd4656220bb37ea598d19da7df34b77506637b09
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170323-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170323-1.cfg
index ea5556b..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170323-1.cfg
+++ /dev/null
@@ -1,7 +0,0 @@
-%define newlib_version 2.5.0.20170323
-%hash sha512 newlib-2.5.0.20170323.tar.gz 323992603f994e82d1b8117da39ce08f8a6584330606e2d053ccefc62fce5682ac47f983aa3bc526c85bcabbcfce85cf607b08f87c5435d00cec6727c006f6b7
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170519-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170519-1.cfg
index e8366b2..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170519-1.cfg
+++ /dev/null
@@ -1,34 +0,0 @@
-%define newlib_version 2.5.0.20170519
-%hash sha512 newlib-2.5.0.20170519.tar.gz 3196acc2749d89f510054163ec8dab529f1b05863831ddce7ba57f027aa346133226706a0e0f52c1e67118be0b16e41dac2eb0783cd52bcd03f33f876778c9a0
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=15b59a15b42c4918c9e0b7bb4a3cbfd46d9b539e
-%hash sha512 newlib-cygwin-git-15b59a15b42c4918c9e0b7bb4a3cbfd46d9b539e.patch fd8c019b94d33c2fcbcd0c9d5fb5c3fe5488dde5ebc229f492d7b222e962c405ee7ed981f75b1489c409f51cec892d3e59eb82763b94fac6d364a35bb6cec3d5
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=2efb1170473ac0c560978567f39a0d69883a2f8b
-%hash sha512 newlib-cygwin-git-2efb1170473ac0c560978567f39a0d69883a2f8b.patch 4e7da66589b275f49a10ab48c3b7df87f77669227b678dd63ca3088a8153a5f20b48ac6fc00ad2b54b783639b21b0089ebfee7c0ce3809f91647173e69d57629
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=0008601042291502e479fd0d2738855b40f9b2b2
-%hash sha512 newlib-cygwin-git-0008601042291502e479fd0d2738855b40f9b2b2.patch 69a5193a3c91eac9caed40b88708b33445a8453e4b282c3c0182508023eae17fc60b81e71dad9d91f500e2884104b6098f35c5e7aeb7674e95dbba43556c72a2
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=0b915d6be0acdbdb23ce35f12289f4d7ee4c0eb6
-%hash sha512 newlib-cygwin-git-0b915d6be0acdbdb23ce35f12289f4d7ee4c0eb6.patch 842203f6e04168dbf7bf02c91b474ccffc57857816e76662270d98af7fb82fff38b49095400c1614fa23e95fd543690aca9bacd59f23d4776c09160e549b3b5c
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=2693c1db694f515d7b59ec8057e01942c212b8c1
-%hash sha512 newlib-cygwin-git-2693c1db694f515d7b59ec8057e01942c212b8c1.patch 4171b23077c1f1907bc8082db1cda0c0da49d927dfdc201cfcee20d3eae56c54f704885be32b42520a92a8464ed2319006516577ddf6d8e4e78e2e4a554e5e8f
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=764eda728f864492accef0eda61e4b2549ea452e
-%hash sha512 newlib-cygwin-git-764eda728f864492accef0eda61e4b2549ea452e.patch 7e58bb3af05becf83fcb66b8b4cceb0add83153c4527fb7c07c56c9f3ad689782e5d454c4dc571214856cd7e5186f74dfa59df8cccf485b7c1dafe44c368aaf4
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=fa88e93d3dc639228fcfc21e9f457108f5186727
-%hash sha512 newlib-cygwin-git-fa88e93d3dc639228fcfc21e9f457108f5186727.patch 4dfef3ffe515c3cb5b7c50d73b682b0705043360178590f17cdd8a60ea2cae51d02f88a89b73092873f6a2bc046b1eaa2dbf313bb299565e058df9d5447a96c1
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=d70983ea1b9bd39ec85dbddd34d7cb9c7379f946
-%hash sha512 newlib-cygwin-git-d70983ea1b9bd39ec85dbddd34d7cb9c7379f946.patch 3b0c3f7a776cabf5582c92525df27261362b722b60cdfcc7957255e9c8965d999ccf9668f59ad12f20387c69e4423fb291eb588b9cc5847fa0e9171ce45eec08
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=9b7bbd03132ac8e67cce239558f789630caacb4d
-%hash sha512 newlib-cygwin-git-9b7bbd03132ac8e67cce239558f789630caacb4d.patch b181378a2d9e5b407e5eb19b677ee16551e45f46d763adc7ad69d2b7ea5b28c79f09012ae7326c0c89544bc5a8548799af89d96336e56ca32ee10ca68956eb2f
-%patch add newlib -p1 https://sourceware.org/cgi-bin/get-raw-msg?listname=newlib&date=2017&msgid=20170607073409.11245-1-sebastian.huber%40embedded-brains.de
-%hash sha512 get-raw-msg-listname-newlib-date-2017-msgid-20170607073409.11245-1-sebastian.huber-40embedded-brains.de 546b135033cb0d896dd129cc038601f37326f7a7718366818f780106164f5305daa180f3ed35e42eccb763ab6ecc1ac04bbaaeb5084cef50ed9ffedd3a34fe75
-%patch add newlib -p1 https://sourceware.org/cgi-bin/get-raw-msg?listname=newlib&date=2017&msgid=20170607073409.11245-2-sebastian.huber%40embedded-brains.de
-%hash sha512 get-raw-msg-listname-newlib-date-2017-msgid-20170607073409.11245-2-sebastian.huber-40embedded-brains.de 33213c3924bf744e45383ad65c2bcc9754dc7d194d616cd6b34059f1f2cc2c1ed1e8f1898e3d1bace556170fdd12cb59f85b03f52b6de6b5d51e35f93103474c
-%patch add newlib -p1 https://sourceware.org/cgi-bin/get-raw-msg?listname=newlib&date=2017&msgid=20170607090821.14403-1-sebastian.huber%40embedded-brains.de
-%hash sha512 get-raw-msg-listname-newlib-date-2017-msgid-20170607090821.14403-1-sebastian.huber-40embedded-brains.de c0344943dc6f7196735084b0a194eaf8de97b7b3ee4c89c82e051f907c0631bfe01b32d0caf6d4f83ac8521fd0f20721199a9fb113210101694261ccebc13f11
-%patch add newlib -p1 https://sourceware.org/cgi-bin/get-raw-msg?listname=newlib&date=2017&msgid=20170612064218.11969-1-sebastian.huber%40embedded-brains.de
-%hash sha512 get-raw-msg-listname-newlib-date-2017-msgid-20170612064218.11969-1-sebastian.huber-40embedded-brains.de 89450ee635754730391a439f449ade6069ef45b16cad6ef041f60bc00994844aa4891b57a6bf29a30a0396c6024f521fd1ce98390e835e682bcc324ec2d26afa
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg
index 5ec7eea..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170623-1.cfg
+++ /dev/null
@@ -1,42 +0,0 @@
-%define newlib_version 2.5.0.20170623
-%hash sha512 newlib-2.5.0.20170623.tar.gz 94bdf09f4279920cafe93b112d6b32c11aed0663beff51b30712c3f31f0d6b416ad62ec8f34c96facf142fac65a6a929b434416994146fd2433666f9a60d78df
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=b70c0bc706d5e9fc19ac84bfaa0fb049c898ef33
-%hash sha512 newlib-cygwin-git-b70c0bc706d5e9fc19ac84bfaa0fb049c898ef33.patch 8b2f2d0efae5a6342023b24e52d41bb5ded4043b656941409a6b5b50fc0dfb23cdb55a1c3de059259750624a5d9fbeac63fa1695a621a520159e39ad19d4ce63
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=79cc9cb8f30522a4bdf73362803aff5831b73512
-%hash sha512 newlib-cygwin-git-79cc9cb8f30522a4bdf73362803aff5831b73512.patch 6158151ff44b6b1128576ee6a9c979334e834680b75066d99d776626cce02eaa80a7dd2fddbdd871c5faf62f4f7082151094d44879d16368e49ee1eb2d9780d7
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=668a4c8722090fffd10869dbb15b879651c1370d
-%hash sha512 newlib-cygwin-git-668a4c8722090fffd10869dbb15b879651c1370d.patch e2c100c627fca0a372d6630638d79b54d97117951c20be2e0d61d7b1040a6723d009b790319970a69bf6e4548a1811580f1d699c8eed63ab5232711f60419fde
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=d2e256a36a877fca17272c2e4640d967ea8c490f
-%hash sha512 newlib-cygwin-git-d2e256a36a877fca17272c2e4640d967ea8c490f.patch bdc125e5dffaf65692189bcb3982c826f3de31d761e7ed63b7f46bbc331af520cb41daec1420a2f5125b8ea42d31665f945f00e15fb150675cdfe8cde11bf546
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=a254c82486fd405623f1655383ee67e96216a883
-%hash sha512 newlib-cygwin-git-a254c82486fd405623f1655383ee67e96216a883.patch 08334de13601df491ced3dfac119f446c394fe00027bb08baf0f18c0bf187618810c3da9a44d20f192bc973b96fe648fa5ee175fa77da44326c70a0d26097f30
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=d736941a5198d43269c57170a4cdb4e87efa3297
-%hash sha512 newlib-cygwin-git-d736941a5198d43269c57170a4cdb4e87efa3297.patch fb8616a4e83b9103cc3260523352e24dc85e000d5b06ce087f535ec23748f6b86125d7f9f97176eaed48e65b6b60e6cabfdf1bcc23c793e62c4878242d90e36f
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=2390e71a4278308ba84d937a3fc5a9a10f1f7ecb
-%hash sha512 newlib-cygwin-git-2390e71a4278308ba84d937a3fc5a9a10f1f7ecb.patch 4ea8fbf3e5a02cbc0fdf7a19e676895978afdde19241d92a13c7d927d153b88c72c0cf14151875626b3768fb020f697e1c2baa7794631b953b661fd6c5fc552c
-%patch add newlib -p1 %{rtems_newlib_patches}/newlib-cygwin-git-461152e4ebd94f7d8b1e20f4cd1c704138ba2083.patch
-%hash sha512 newlib-cygwin-git-461152e4ebd94f7d8b1e20f4cd1c704138ba2083.patch 35b6432ab18129c4fbc134ef67a739f277138ab969152722e4fb59ea69f45e34374757f64574d5355959d683b860f282801a84e56c40227de3638a03d9a3276e
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=1d49ce4d6b4649a3f89396de67e9c73fc88162f4
-%hash sha512 newlib-cygwin-git-1d49ce4d6b4649a3f89396de67e9c73fc88162f4.patch 72c6386c4b5202700b12f84c4a843a6c59440044fb8ac890ff89d4d6d3bd492e3b4a0672b82aa3bf872199c507a4480f6545703a48bc37cee04d14dd5f508ef3
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=a3617d7bde0ac1f816f9311f6d715b0b73f6ecff
-%hash sha512 newlib-cygwin-git-a3617d7bde0ac1f816f9311f6d715b0b73f6ecff.patch 3861d8f44a3f73dd3ecdea4161ce23111429811bfd7cdd3992ffa7075881583b06f4b7149db36e990637cf99e176617bed0a0f1b818adb1ec64604f13cd2630c
-# Fix for MSYS2 on Windows. See ticket #2990 for details.
-%patch add gcc -p1 https://devel.rtems.org/raw-attachment/ticket/2990/gcc-4.9.3-20170404-1.patch
-%hash  sha512 gcc-4.9.3-20170404-1.patch c6402e578793e39869d0f3ba021922794e8ea30595286f63cbc9d32c5cb9ef1d9bb3be28f2a9127077d62a44f425f9c0685e3c22596aed67837fe2fcf8a09e71
-# FreeBSD specific fix for MIPS
-%if %{_build_os} == freebsd
- %patch add gcc --rsb-file=freebsd-libgcc-sed-fix.patch -p0 https://gcc.gnu.org/bugzilla/attachment.cgi?id=41380
- %hash  sha256 freebsd-libgcc-sed-fix.patch 8a11bd619c2e55466688e328da00b387d02395c1e8ff4a99225152387a1e60a4
-%endif
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170720-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170720-1.cfg
index f377da2..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170720-1.cfg
+++ /dev/null
@@ -1,10 +0,0 @@
-%define newlib_version 2.5.0.20170720
-%hash sha512 newlib-2.5.0.20170720.tar.gz 2afcea3db3c0ad89997de78c8dfac176b72255ef5c58a2af1cabcc40803e46db96853140ec0c9a3ee50df4c43365739d186bf68e6816a55716294f53edb8e112
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=b0f271d1db223b2cadd73e10258c48013d943691
-%hash sha512 newlib-cygwin-git-b0f271d1db223b2cadd73e10258c48013d943691.patch 05c7ebe2bb4afeece848ad6ed16ef5e2fcacd6f0cfcafd96a85dfea553d1be39ab4125695ebe01516576b0db098d8fbbdd88a073f7760d2dc965e5cc42b87466
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170818-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170818-1.cfg
index 8abba36..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.5.0.20170818-1.cfg
+++ /dev/null
@@ -1,12 +0,0 @@
-%define newlib_version 2.5.0.20170818
-%hash sha512 newlib-2.5.0.20170818.tar.gz 41382f722232593a9a2bf7de09dc51a26ad51bf8ad06259b0fd38a13cfcd577688e836446d7e88b7741eeec316cfa137ff9b4e16cca846b11bb70948ff1b8c16
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=7b2c3621901dbb0a3535f8056a2eadb9095a5ad2
-%hash sha512 newlib-cygwin-git-7b2c3621901dbb0a3535f8056a2eadb9095a5ad2.patch de14e30ad11716b15edf18fd6cbd593316c7586136dcf7993c97bd1a0a90b75bcccf2dd05963dcc5d30d2fb81d90e5ba999db0df9da7b6cdcca29ccbdc677619
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=524eb4dc2913e5b8f73b4b450c3c96bb40f5006d
-%hash sha512 newlib-cygwin-git-524eb4dc2913e5b8f73b4b450c3c96bb40f5006d.patch 968928c7007c7cdde0a467ef2004ddd7878f8c012f6ffeb2c328cd8a0ebd4d6457e2913b15a96ebce98aecfaeeb427236fd6301cedeb5173818b98cfbc1cb680
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg
index d4ea2c7..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GCC 4.8.3., Newlib CVS
-%define newlib_version 19-Aug-2014
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-git-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-git-1.cfg
index 84cbd62..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-git-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GCC 4.8.3., Newlib GIT
-%define newlib_version 8b1ede3ce11d53292036aadfcfb6043df0235f9c
-%include tools/rtems-gcc-4.8-newlib-git-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg
index ed56cca..0000000
--- a/rtems/config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,43 +0,0 @@
-# GCC 4.9.x., Newlib CVS.
-%endif
-%endif
-%endif
-# Newlib is from CVS. No hash on CVS.
-# The gcc/newlib build instructions. We use 4.9 Release 1.
-%include %{_configdir}/gcc-4.9-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.9-newlib-git-1.cfg b/rtems/config/tools/rtems-gcc-4.9-newlib-git-1.cfg
index 014e45c..0000000
--- a/rtems/config/tools/rtems-gcc-4.9-newlib-git-1.cfg
+++ /dev/null
@@ -1,43 +0,0 @@
-# GCC 4.9.x., Newlib GIT.
-%endif
-%endif
-%endif
-%hash sha256 mpfr-%{mpfr_version}.tar.bz2 e1977099bb494319c0f0c1f85759050c418a56884e9c6cef1c540b9b13e38e7f
-%hash sha256 mpc-%{mpc_version}.tar.gz    ae79f8d41d8a86456b68607e9ca398d00f8b7342d1d83bcf4428178ac45380c7
-%hash sha256 gmp-%{gmp_version}.tar.bz2   1f588aaccc41bb9aed946f9fe38521c26d8b290d003c5df807f65690f2aadec9
-# Newlib is in git
diff --git a/rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg b/rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg
index 3e6854e..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg
+++ /dev/null
@@ -1,40 +0,0 @@
-# GCC 4.9.0., Newlib 2.1.0
-%define gcc_version    4.9.0
-%endif
-# Hash checksums.
-%hash md5 gcc-%{gcc_version}.tar.bz2      9709b49ae0e904cbb0a6a1b62853b556
diff --git a/rtems/config/tools/rtems-gcc-4.9.0-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.9.0-newlib-cvs-1.cfg
index c8ba8b7..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.0-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,11 +0,0 @@
-# GCC 4.9.0., Newlib CVS
-%include tools/rtems-gcc-4.9-newlib-cvs-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg
index 5fdfcdd..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GCC 4.9.1., Newlib CVS
-%define gcc_version    4.9.1
-%hash md5 gcc-%{gcc_version}.tar.bz2 fddf71348546af523353bd43d34919c1
diff --git a/rtems/config/tools/rtems-gcc-4.9.1-newlib-git-1.cfg b/rtems/config/tools/rtems-gcc-4.9.1-newlib-git-1.cfg
index 08b6414..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.1-newlib-git-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GCC 4.9.1., Newlib GIT
-%define newlib_version ef23a12ff8f840cc571e47870cd5f4ad6bca4553
-%include tools/rtems-gcc-4.9-newlib-git-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-1-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-1-1.cfg
index 6e1bca4..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-1-1.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
-# GCC 4.9.2., Newlib 2.2.0-1
-%define gcc_version    4.9.2
-%define newlib_version 2.2.0-1
-%hash md5 gcc-%{gcc_version}.tar.bz2 4df8ee253b7f3863ad0b86359cd39c43
-%hash md5 newlib-%{newlib_version}.tar.gz 94114fdc1d8391cdbc2653d89249cccf
-%include tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-20150423-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-20150423-1.cfg
index d5fdcca..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-20150423-1.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
-# GCC 4.9.2, Newlib 2.2.0-1 (actually a snapshot)
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.20.0-20150323-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.20.0-20150323-1.cfg
index 4b6cd29..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.20.0-20150323-1.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.4.0-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.4.0-1.cfg
index 7543de6..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.4.0-1.cfg
+++ /dev/null
@@ -1,15 +0,0 @@
-# GCC 4.9.2, Newlib 2.4.0-1
-# NOTE: These should be recent enough. Do not duplicate more.
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.4.0.20160527-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.4.0.20160527-1.cfg
index 3df90bf..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.4.0.20160527-1.cfg
+++ /dev/null
@@ -1,7 +0,0 @@
-%hash sha512 gcc-%{gcc_version}.tar.bz2 e96cba06d572dbe7f382a2b00fd9297dcf9f9219d46a9ad0bd904dc36d5e7db3335e422640b79a27fed6fde91b0731732b94a0e2fbcd47344d6779f8ba1f4f9c
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0-1.cfg
index f0f34e1..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0-1.cfg
+++ /dev/null
@@ -1,10 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170228-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170228-1.cfg
index 76eff7f..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170228-1.cfg
+++ /dev/null
@@ -1,7 +0,0 @@
-%hash sha512 gcc-4.9.2.tar.bz2 e96cba06d572dbe7f382a2b00fd9297dcf9f9219d46a9ad0bd904dc36d5e7db3335e422640b79a27fed6fde91b0731732b94a0e2fbcd47344d6779f8ba1f4f9c
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170323-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170323-1.cfg
index 3eb4800..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170323-1.cfg
+++ /dev/null
@@ -1,7 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170519-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170519-1.cfg
index a0b577a..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170519-1.cfg
+++ /dev/null
@@ -1,34 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg
index e8e05d1..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170623-1.cfg
+++ /dev/null
@@ -1,28 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170720-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170720-1.cfg
index 12deaed..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170720-1.cfg
+++ /dev/null
@@ -1,10 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170818-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170818-1.cfg
index 22a34c3..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.5.0.20170818-1.cfg
+++ /dev/null
@@ -1,12 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-git-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-git-1.cfg
index c7b12d0..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-git-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GCC 4.9.2., Newlib GIT
diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg
index 9d756ad..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
-# GCC 4.9.3, Newlib 2.2.0-1 (actually a snapshot)
-%define gcc_version    4.9.3
-%hash md5 gcc-%{gcc_version}.tar.bz2 6f831b4d251872736e8e9cc09746f327
diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.4.0-1.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.4.0-1.cfg
index 596a4a7..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.4.0-1.cfg
+++ /dev/null
@@ -1,15 +0,0 @@
-# GCC 4.9.3, Newlib 2.4.0
diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.4.0.20160527-1.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.4.0.20160527-1.cfg
index f8d9ad5..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.4.0.20160527-1.cfg
+++ /dev/null
@@ -1,7 +0,0 @@
-%hash sha512 gcc-%{gcc_version}.tar.bz2 9ac57377a6975fc7adac704ec81355262b9f537def6955576753b87715470a20ee6a2a3144a79cc8fcba3443f7b44c7337d79d704b522d053f54f79aa6b442df
diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0-1.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0-1.cfg
index 318e0ef..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0-1.cfg
+++ /dev/null
@@ -1,10 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170228-1.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170228-1.cfg
index 1d1aec6..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170228-1.cfg
+++ /dev/null
@@ -1,7 +0,0 @@
-%hash sha512 gcc-4.9.3.tar.bz2 9ac57377a6975fc7adac704ec81355262b9f537def6955576753b87715470a20ee6a2a3144a79cc8fcba3443f7b44c7337d79d704b522d053f54f79aa6b442df
diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170323-1.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170323-1.cfg
index 1dba03b..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170323-1.cfg
+++ /dev/null
@@ -1,7 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170519-1.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170519-1.cfg
index 38955fd..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170519-1.cfg
+++ /dev/null
@@ -1,34 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg
index de16dbe..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170623-1.cfg
+++ /dev/null
@@ -1,28 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170720-1.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170720-1.cfg
index 2eacd79..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170720-1.cfg
+++ /dev/null
@@ -1,10 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170818-1.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170818-1.cfg
index 2e390ad..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.3-newlib-2.5.0.20170818-1.cfg
+++ /dev/null
@@ -1,12 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg b/rtems/config/tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg
index 3f44d3f..0000000
--- a/rtems/config/tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg
+++ /dev/null
@@ -1,16 +0,0 @@
-%define gcc_version    6-20151101
-%define newlib_version 2.2.0.20151023
-%define gmp_version    4.3.2
-%include %{_configdir}/gcc-6-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-6-20160117-newlib-2.3.0.20160104-1.cfg b/rtems/config/tools/rtems-gcc-6-20160117-newlib-2.3.0.20160104-1.cfg
index 7fb898a..0000000
--- a/rtems/config/tools/rtems-gcc-6-20160117-newlib-2.3.0.20160104-1.cfg
+++ /dev/null
@@ -1,22 +0,0 @@
-%define gcc_version    6-20160117
-%define newlib_version 2.3.0.20160104
-%hash sha512 gcc-6-20160117.tar.bz2 61d05ad097c640004fad4805b6c407282825d5fcdad11413c47de7178d8f7f2488e2b5f3e354620bca5506b7b7abd464d65db0aea78f89cd63a253e88dd217eb
-%hash sha512 newlib-2.3.0.20160104.tar.gz d83ce298b1b72eabf92e4ec14af3afdf3122e34aff5e320295a398df077235a78aa87148895b441a4f7de3047815e7ce13ea06a06135dd86b69a200236514293
-%hash sha512 mpc-0.8.1.tar.gz 14cb9ae3d33caed24d5ae648eed28b2e00ad047a8baeff25981129af88245b4def2948573d7a00d65c5bd34e53524aa6a7351b76703c9f888b41830c1a1daae2
-%hash sha512 gmp-4.3.2.tar.bz2 2e0b0fd23e6f10742a5517981e5171c6e88b0a93c83da701b296f5c0861d72c19782daab589a7eac3f9032152a0fc7eff7f5362db8fccc4859564a9aa82329cf
diff --git a/rtems/config/tools/rtems-gcc-6-20160124-newlib-2.3.0.20160104-1.cfg b/rtems/config/tools/rtems-gcc-6-20160124-newlib-2.3.0.20160104-1.cfg
index bf58c6c..0000000
--- a/rtems/config/tools/rtems-gcc-6-20160124-newlib-2.3.0.20160104-1.cfg
+++ /dev/null
@@ -1,22 +0,0 @@
-%define gcc_version    6-20160124
-%hash sha512 gcc-6-20160124.tar.bz2 ab90e21b13ead10c58bd2ce17abf4ccffc81355f366c99e6bfce883d288198704d3510d447d48217d4a3e233120da20fc6335dce102ba2dc4785b28a745881da
diff --git a/rtems/config/tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1.cfg b/rtems/config/tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1.cfg
index b35e2ce..0000000
--- a/rtems/config/tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1.cfg
+++ /dev/null
@@ -1,22 +0,0 @@
-%define gcc_version    6-20160228
-%define newlib_version 2.3.0.20160226
-%hash sha512 gcc-6-20160228.tar.bz2 cc768440bf6b89ad58fb64cf2fd93898929f63cd212cdb54443543135be9e713c409f9e2740531376510cad59172b197cad769df14345834bc1cd17b33976a57
-%hash sha512 newlib-2.3.0.20160226.tar.gz f3862b9e8622997cb47688115fa919a0ce933211b590e72f6ab8f7de2d6d1cfa30de405f6a02cf227e81dace94abee8018b80861b291361d1b95062ba67a5175
diff --git a/rtems/config/tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg b/rtems/config/tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg
index bfdc36e..0000000
--- a/rtems/config/tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg
+++ /dev/null
@@ -1,25 +0,0 @@
-%define gcc_version    6-20160327
-%hash sha512 gcc-6-20160327.tar.bz2 0213c44e457585d15ad13fc3a7c665ba78faba0d1685e71cbf0cf32e44523394589ac60c7aea567e29c6f5e18159b446b1b0a7d39e330021c40efd8077aa5ad7
-%patch add newlib --rsb-file=PATCH_libc_sys_rtems_crt0.c_Add_sys_lock.h_symbols_required_to_link_autoconf_probes -p1 https://sourceware.org/cgi-bin/get-raw-msg?listname=newlib&date=2016&msgid=1460668859-31336-1-git-send-email-joel%40rtems.org
-%hash sha512 PATCH_libc_sys_rtems_crt0.c_Add_sys_lock.h_symbols_required_to_link_autoconf_probes 7cce6236f1a126c37c800783268f7a8816fd06f67fa742a60f4a05cd91af12f74293942c687bf58a1b22f7a17545e9b3c46f04c875c3b6d50d93fd59d96e9201
diff --git a/rtems/config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg b/rtems/config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg
index af363fa..0000000
--- a/rtems/config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg
+++ /dev/null
@@ -1,22 +0,0 @@
-%define gcc_version    6-20160526
-%hash sha512 gcc-6-20160526.tar.bz2 8ad457b463432b2cc7fc4c1b7967c2a01909f5fd40d2e7a1f38f8b197859ab2c823b96dfaf36add4177f6f932c7e702cc4ac9201b88375404235fc1a03ef778d
diff --git a/rtems/config/tools/rtems-gcc-6-20160609-newlib-2.4.0.20160527-1.cfg b/rtems/config/tools/rtems-gcc-6-20160609-newlib-2.4.0.20160527-1.cfg
index 66c83b9..0000000
--- a/rtems/config/tools/rtems-gcc-6-20160609-newlib-2.4.0.20160527-1.cfg
+++ /dev/null
@@ -1,23 +0,0 @@
-%define gcc_version    6-20160609
-%hash sha512 gcc-6-20160609.tar.bz2 f9ea9034c0456d350e418a7263cdd02596fdd553f40e9741907436f0df7dbbc5b025ea421c2aece2769ade8e356985c104a37fe6c1bdc51eb61d52257206e0f1
diff --git a/rtems/config/tools/rtems-gcc-6-20161110-newlib-2.4.0.20161025-1.cfg b/rtems/config/tools/rtems-gcc-6-20161110-newlib-2.4.0.20161025-1.cfg
index dbb3547..0000000
--- a/rtems/config/tools/rtems-gcc-6-20161110-newlib-2.4.0.20161025-1.cfg
+++ /dev/null
@@ -1,23 +0,0 @@
-%define gcc_version    6-20161110
-%define newlib_version 2.4.0.20161025
-%hash sha512 gcc-6-20161110.tar.bz2 b75f73950a409658b45a6dc2fcbfe18b38aba53fdd55f509e17637fb0d50464b6636394297fd33a0843684f7ef3eefefd1dcf8f257694ab4f15339ae37c8437e
-%hash sha512 newlib-2.4.0.20161025.tar.gz bad47dc4062e0e9a0660a95cdd7a8b180d4257f68352a4a1fb66cd936aa38fbf44ccbe51f8281f89667e96a8296a02f1dbfc6ee5daba6951db375bbca74898eb
diff --git a/rtems/config/tools/rtems-gcc-6.0.1-RC-20160415-newlib-2.4.0-1.cfg b/rtems/config/tools/rtems-gcc-6.0.1-RC-20160415-newlib-2.4.0-1.cfg
index 54746dc..0000000
--- a/rtems/config/tools/rtems-gcc-6.0.1-RC-20160415-newlib-2.4.0-1.cfg
+++ /dev/null
@@ -1,25 +0,0 @@
-%define gcc_version    6.0.1-RC-20160415
-%hash sha512 gcc-6.0.1-RC-20160415.tar.bz2 5c03c1a74cc762c2421cd9b5818deca6e6191a19ebe07eaa407e152cd1d4341eed5e15ed9a35d8e372891574d492fb67d0885ce302dcf5d71c89021b0f420c40
diff --git a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0-1.cfg b/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0-1.cfg
index a5a8829..0000000
--- a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0-1.cfg
+++ /dev/null
@@ -1,23 +0,0 @@
-%define gcc_version    6.3.0
-%hash sha512 gcc-6.3.0.tar.bz2 234dd9b1bdc9a9c6e352216a7ef4ccadc6c07f156006a59759c5e0e6a69f0abcdc14630eff11e3826dd6ba5933a8faa43043f3d1d62df6bd5ab1e82862f9bf78
diff --git a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg b/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg
index 36a70ed..0000000
--- a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170228-1.cfg
+++ /dev/null
@@ -1,23 +0,0 @@
-%patch add newlib --rsb-file=newlib-ARM-Optimize-IEEE-754-sqrt-implementation.diff -p1 https://sourceware.org/cgi-bin/get-raw-msg?listname=newlib&date=2017&msgid=1490082540-22841-1-git-send-email-sebastian.huber%40embedded-brains.de
-%hash sha512 newlib-ARM-Optimize-IEEE-754-sqrt-implementation.diff b23154285e4fbabfbd27e3bc7493e7336b698e0da4a93bd1860b11ad40e5bc530b86ddfcef8421c1e2f0e7c8039b1b340297d7cd88381f75abdffd590eb51962
diff --git a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170323-1.cfg b/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170323-1.cfg
index c865910..0000000
--- a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170323-1.cfg
+++ /dev/null
@@ -1,65 +0,0 @@
-%endif
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=f70d9ae6adc6ed7952806056349ba9f8ba3c65c8
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=086730fb14c1c4171764e605d7510e33f0fc34ed
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=e0dabc0e8dd6d9e2a21ceef124a1e4bf9f3d8aa3
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=84a6dba57ed351a275889a3e8c87f566e3b3e508
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=81c121c48739df247ade660659cd6672a9a2c7dd
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=e1563a05b714f42502496466f12df7b461f40dd1
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=7b07f11b1fc79224afaa8967a356796610bf82bf
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=3abc66ec6bf8c4312da413a62a5740a33edccaad
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=d3e919b42a26c14d47f668397519f455807dd613
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=a36e348a9f6d8ec690b827a3ea2e0ef9814579f7
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=d3f9311fff9e16241590f0bc10cf5466f04b40b7
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=73603c98aa6f52ebedc539289c30c03f3b8f7093
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=218c5e7d7264f1ed532d64d1932104fd8864b962
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=9998bd4b7c4596e47d8e0fbc6f1f370d096a6618
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=5e36b7010419bdd22116ac26c1b33a4b0831a047
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=6c6ea2e457373d59e48634363c409412c3c09ccd
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=7c4ae7770ea1537ba3bed956d328fb48fdef708f
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=eb14d0cc649978c10928bf38c1847f295bf0de69
-%hash sha512 newlib-cygwin-git-086730fb14c1c4171764e605d7510e33f0fc34ed.patch 40ec1c04932e8a11ed2e8ea6986d9a1ca3ac9d866b9ab7007ad4126a4abe8616ee5304742fd4a387433c455cede3a108b00909ba206be227570e6de0121c26c2
-%hash sha512 newlib-cygwin-git-218c5e7d7264f1ed532d64d1932104fd8864b962.patch 632c5a4e09d6e73451d5664444f4c84540dad53ca4e5446253fac141bc62f22ddc374a6f0bff9758fe15a651aba4f63f8494242e9103a0930f042d2206fb7188
-%hash sha512 newlib-cygwin-git-3abc66ec6bf8c4312da413a62a5740a33edccaad.patch 4b05c9522a077c56daddcbf83f1356d6125dd4461e0d2c9fcf8b9fe896fb805754de4e0aba35cf20d158f86b07cf92acf21e9f26ce082f3118889a25318b253e
-%hash sha512 newlib-cygwin-git-5e36b7010419bdd22116ac26c1b33a4b0831a047.patch 8783bc19bf018c7019cae01bac7340b93ef9e6c492aae363a1882de8a9f467d9ef268bd8d9d5304fbc2addeeb953975756499843721fb972f5f4182b239b1739
-%hash sha512 newlib-cygwin-git-6c6ea2e457373d59e48634363c409412c3c09ccd.patch 30b85f9b04bb62d614e372d108e2c61eb25cbb8034bd0fa9e1fa0efc6341f189d6bf46eee1496e4922e2c01c1044d30c31b5ee6e96af342d8f3f9ba5c30fdf78
-%hash sha512 newlib-cygwin-git-73603c98aa6f52ebedc539289c30c03f3b8f7093.patch 2d52911384c4c3a098eb59915ba555c414e1322e9846d7a1490ac8cb744cb50781ccb30e95a54bfb3194c4a5c63fe520c1a51d1aa4f41cec12902d830ee1cc89
-%hash sha512 newlib-cygwin-git-7b07f11b1fc79224afaa8967a356796610bf82bf.patch 5b0628ff32af4665df73178a60844b5c2afbe217abacf550b63494400e9a667e8ced1bfe023703eb16f993ad286e1b5cf5d47369cacfd914cc9d8a64c4b3f950
-%hash sha512 newlib-cygwin-git-7c4ae7770ea1537ba3bed956d328fb48fdef708f.patch b7a9115464f35e2352f9fbb05f1c748e2e59d279ea1fa0bf798645a7929856732308c18badf7f520faf460818b10e69761ba7ec79254b0931fb2c5a65f690c76
-%hash sha512 newlib-cygwin-git-81c121c48739df247ade660659cd6672a9a2c7dd.patch 61420cfe84a2cda56f210e25027812ee6daae20a95d06b6e73bb22d7f31c1659f1198acb787dd9d11a710603a59e5c24fcf7f0c75c1f7899b5ea825c40f3a28b
-%hash sha512 newlib-cygwin-git-84a6dba57ed351a275889a3e8c87f566e3b3e508.patch 9d1fad38b27d23dd36fc9f4bfe505bda73e573c50a5db6160485596f3bc470efc8fbdd491e70523421f4cb49e0d14f5f145071a1cc2cdca1ed4e24582322077a
-%hash sha512 newlib-cygwin-git-9998bd4b7c4596e47d8e0fbc6f1f370d096a6618.patch 554263929cc229b084c7efa2a0dd7ce0bb742f314377886204ef770a3ef611222035b278240e93833c637649ab8992112c1aa33e905e460566fc6a6d69e04b5a
-%hash sha512 newlib-cygwin-git-a36e348a9f6d8ec690b827a3ea2e0ef9814579f7.patch 20db3205eb5b5eee2a4c8c40fb0c56f579c7d14b51b4785ab48d638a5f6fa9ba3c455a7ce655f80baac66ac74848da7074fc74f63be6d372cffc45061fa31b6b
-%hash sha512 newlib-cygwin-git-d3e919b42a26c14d47f668397519f455807dd613.patch 0866f67fb3e231707bf49fa6451364f5a214aec8b4d1dc1a06b523da80db44552735122396b7ec113be5c6dcd3543db689593584fd4ff9560586c5fcac2d9da5
-%hash sha512 newlib-cygwin-git-d3f9311fff9e16241590f0bc10cf5466f04b40b7.patch 879db1d25f47ae152fa70b031da9cfcc45b7dec0f5c9a4491adbd494fd6e0d38d4a6f9ab93b06943a62512b17fd163ea19e20bfb865ceec953180fe5fd0ad627
-%hash sha512 newlib-cygwin-git-e0dabc0e8dd6d9e2a21ceef124a1e4bf9f3d8aa3.patch 01203a1e5241e4c983cca7a55a81233167f0c796a0e14cae17b7761878fab41c88fa6ebacc783eb90323a315223a51f691908ba51d732125841045811e668056
-%hash sha512 newlib-cygwin-git-e1563a05b714f42502496466f12df7b461f40dd1.patch d1429572928e1fac9043d1958e41f48ef1592d43f2cd6fd817e096952671b0ee4b0aba7848722dc83a52dd3b5454249c4929a46b38ab1c342b3af3003d7db554
-%hash sha512 newlib-cygwin-git-eb14d0cc649978c10928bf38c1847f295bf0de69.patch eac2005f778419a5917dd7cd9a42488d3d1251a72c970b70f110c75fe9b4a7388a36c55e3244df65454c62e7262f48998390b37968060f3d7419d66d8516f708
-%hash sha512 newlib-cygwin-git-f70d9ae6adc6ed7952806056349ba9f8ba3c65c8.patch 915d233ae124a8fd6552aa320eb2b9910bb1417d378bad3cc43ee6dcb1b649fb7ea964a056e0afcf71b115c692af6c2ee99472f05b34b0024dd761041fdeb0db
diff --git a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170519-1.cfg b/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170519-1.cfg
index 48bbad9..0000000
--- a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170519-1.cfg
+++ /dev/null
@@ -1,58 +0,0 @@
-%endif
-%patch add gcc --rsb-file=ubsan.c-109382498fda534d7a8de790e1ebfe39fdb7e231.patch -p1 https://gcc.gnu.org/git/?p=gcc.git;a=blobdiff_plain;f=gcc/ubsan.c;h=109382498fda534d7a8de790e1ebfe39fdb7e231;hp=56637d8f0a9e009a0046344d5820fed508b0320b;hb=c0c52589c6a7265e8fc6b77706a83d22aa1ef0ce;hpb=519ce11014aac4f9910018523c3e9e6968bb2a53
-%hash sha512 ubsan.c-109382498fda534d7a8de790e1ebfe39fdb7e231.patch 0b2eb2e9c195f7495b10f2a65bf2363f391065352385703b1a1fbd5f5005a629481b268f3483c4030512d1cd47f81f72ddff9899ded904866d8bcdd6e6ffa756
diff --git a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg b/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg
index fb6a6be..0000000
--- a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170623-1.cfg
+++ /dev/null
@@ -1,52 +0,0 @@
-%endif
diff --git a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170720-1.cfg b/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170720-1.cfg
index 7db2c4c..0000000
--- a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170720-1.cfg
+++ /dev/null
@@ -1,34 +0,0 @@
-%endif
diff --git a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170818-1.cfg b/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170818-1.cfg
index 1632f79..0000000
--- a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170818-1.cfg
+++ /dev/null
@@ -1,36 +0,0 @@
-%endif
diff --git a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170922-1.cfg b/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170922-1.cfg
index 249bb4b..0000000
--- a/rtems/config/tools/rtems-gcc-6.3.0-newlib-2.5.0.20170922-1.cfg
+++ /dev/null
@@ -1,40 +0,0 @@
-%define newlib_version 2.5.0.20170922
-%endif
-%hash sha512 newlib-2.5.0.20170922.tar.gz 5f29509c53d2858c0067e2fe33565a8b8e9decfc2761b3616729a274e7747c120a0b82b2c50aae291b182178da274a1540e218d23b86debd56256e17f3651d4b
-%patch add newlib -p1 https://devel.rtems.org/raw-attachment/ticket/2514/0001-RTEMS-Self-contained-POSIX-objects.patch
-%hash sha512 0001-RTEMS-Self-contained-POSIX-objects.patch dbe5e81d30f3ad84cbc1b1e9f76479dafaf2e11f4a32b3d700aec57d0c758aa7723980ddf2ad4c7778db530dcb5412ba0a2e0c40c1631f11fac44b8e60d969e1
-# Fix _PTHREAD_MUTEX_INITIALIZER
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=c165a27c0147471977377acd8918ab3b446f947a
-%hash sha512 newlib-cygwin-git-c165a27c0147471977377acd8918ab3b446f947a.patch 535f81ba3c30c89d1e55ce4b9e5b7aed141b3b916e84fab095f5af04fffacdc46351524725a8ed53d829ed463426f1c90772852d4715b7170f69521db9258e1d
-# Remove internal timecounter API
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=ce189d8afef720b0977b5cae7f9eabf5d49b530c
-%hash sha512 newlib-cygwin-git-ce189d8afef720b0977b5cae7f9eabf5d49b530c.patch 280c586416b0bfc0f5d09f36a7d553a2e6115129da5f4afffe26159bb92333ca6ef297e5fe0e97557c3dd93f574ace4ef2f5ee6c16bf52a9c557c1b75e327cba
diff --git a/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg b/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg
index e952b07..0000000
--- a/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170323-1.cfg
+++ /dev/null
@@ -1,70 +0,0 @@
-# GCC 7.2
-%define gcc_version    7.1.0
-%define mpfr_version   3.1.4
-%define mpc_version    1.0.3
-%define gmp_version    6.1.0
-%endif
-%hash sha512 gcc-7.1.0.tar.bz2 b5d952be9a10f0e0926bb2868877d10544039d6d2f35ba0a08f51231dd622a007650764a03e173194701467547789ad7d2d9cbc10adcdf118d619cdedbd14aec
-%hash sha512 mpfr-3.1.4.tar.bz2 51066066ff2c12ed2198605ecf68846b0c96b548adafa5b80e0c786d0df488411a5e8973358fce7192dc977ad4e68414cf14500e3c39746de62465eb145bb819
-%hash sha512 mpc-1.0.3.tar.gz 0028b76df130720c1fad7de937a0d041224806ce5ef76589f19c7b49d956071a683e2f20d154c192a231e69756b19e48208f2889b0c13950ceb7b3cfaf059a43
-%hash sha512 gmp-6.1.0.tar.bz2 3c82aeab9c1596d4da8afac2eec38e429e84f3211e1a572cf8fd2b546493c44c039b922a1133eaaa48bd7f3e11dbe795a384e21ed95cbe3ecc58d7ac02246117
-%include %{_configdir}/gcc-7-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg b/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg
index 0a3904e..0000000
--- a/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170519-1.cfg
+++ /dev/null
@@ -1,62 +0,0 @@
-%endif
-%patch add gcc --rsb-file=Makefile.in-2dff5ab36e64e5368c0e27ebe720f576da009d3b.patch -p1 https://gcc.gnu.org/git/?p=gcc.git;a=blobdiff_plain;f=gcc/ada/gcc-interface/Makefile.in;h=2dff5ab36e64e5368c0e27ebe720f576da009d3b;hp=e5a79f8d9723a4e65f9d7b5c3e4a27f0ef4ea9ab;hb=34df49547806512c6e1549a58048f161f5fa42bc;hpb=6ba6a94d7fab90cda7f75ec665a2fe9e36b5d498
-%hash sha512 Makefile.in-2dff5ab36e64e5368c0e27ebe720f576da009d3b.patch 22983bf61ff07cd89b23ce003abbb44218680cf34e74e34aaf4a38edea3bb2ce1411479b045edf90fd4b69e9baabdc97a75022af78a515c1587b9f6713dd3380
-%patch add gcc -p1 %{rtems_gcc_patches}/PR-ada-81070.diff
-%hash sha512 PR-ada-81070.diff 2ce006adeaefd9e9cbed23a01c5a5853661b5a9cfb62775ff4d14bc4c96e008a066e504cf0fd0d942c25b114760f4c01127e129bf447669bffc61b9a0644a2ff
-%patch add gcc --rsb-file=m68k.md-7933f8eb253270ef835167e4668be2d8ea47810e.patch -p1 https://gcc.gnu.org/git/?p=gcc.git;a=blobdiff_plain;f=gcc/config/m68k/m68k.md;h=7933f8eb253270ef835167e4668be2d8ea47810e;hp=5bf6c92d3d55074dc0bfde3c2e014b9b9839f896;hb=434ca1d9a3d1a67e41fb934518b121a480f32d2e;hpb=760680df9dc3ac271093974b085b32f005358f0a
-%hash sha512 m68k.md-7933f8eb253270ef835167e4668be2d8ea47810e.patch 6eae11375a726ed8d3ae6e0b12870a7e34fe038328ebc6997e9f01c9bdf35cda895f2140beb10d37cc33e713069500080c7703d15b103f54a746fc09473ef7ae
diff --git a/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg b/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg
deleted file mode 100644
index d8bb2a8..0000000
--- a/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170623-1.cfg
+++ /dev/null
@@ -1,58 +0,0 @@
-%include %{_configdir}/checks.cfg
-%include %{_configdir}/base.cfg
-%endif
-%patch add gcc -p1 https://devel.rtems.org/raw-attachment/ticket/3057/0001-config-sparc-sparc.opt-mfix-ut700-New-option.patch
-%hash sha512 0001-config-sparc-sparc.opt-mfix-ut700-New-option.patch 45a9460680a7367df5d68560c72bdc313f576a7bfbbf25142663299cb7affbf0657a738119e428e0fa1864e4be17b188fcfabbe431a90d4af37cf0bb0505cc4c
diff --git a/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170720-1.cfg b/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170720-1.cfg
index 6c659a4..0000000
--- a/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170720-1.cfg
+++ /dev/null
@@ -1,42 +0,0 @@
-%endif
-%patch add newlib -p1 https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=patch;h=d6cac3e1da1a117f8a93b91371f3f0a5c071219f
-%hash sha512 newlib-cygwin-git-d6cac3e1da1a117f8a93b91371f3f0a5c071219f.patch a2819435925b8cdff61e149457f943abd52800e71f6339591a96232ca31d9f039f1ca449f12b9df737369a44200b0a8cbbfc90e00ff8e0ac585e5c84b2c5534b
diff --git a/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170818-1.cfg b/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170818-1.cfg
index 01ed2f4..0000000
--- a/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170818-1.cfg
+++ /dev/null
@@ -1,42 +0,0 @@
-%endif
diff --git a/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170922-1.cfg b/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170922-1.cfg
index c0d4225..0000000
--- a/rtems/config/tools/rtems-gcc-7.1.0-newlib-2.5.0.20170922-1.cfg
+++ /dev/null
@@ -1,46 +0,0 @@
-%endif
diff --git a/rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg b/rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg
index cfba006..0000000
--- a/rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170818-1.cfg
+++ /dev/null
@@ -1,40 +0,0 @@
-%define gcc_version    7.2.0
-%if %{_build_os} == freebsd || %{_build_os} == darwin
-%endif
-%hash sha512 gcc-7.2.0.tar.xz f853cd6530b4055d8d8289da74687cb4c6d5f363598d386332d31852b581bac76c3adb7d61889edec3b779f63d8646f0122840f12965ce4a4389ba535dbbb6e1
-%patch add gcc --rsb-file=gcc-62ffbcb7502f0ff88ff7566cd6d7c59c0483ecc0.patch https://gcc.gnu.org/git/?p=gcc.git;a=commitdiff_plain;h=62ffbcb7502f0ff88ff7566cd6d7c59c0483ecc0
-%hash sha512 gcc-62ffbcb7502f0ff88ff7566cd6d7c59c0483ecc0.patch 61286ad8d6ac904da90b1123930c4c4a251e8de7692ee91f5a3afbfa873c62d7d0f29b8b22fab63b1896c34510fa811cb1061883b33217f35a5f9758802c23a0
-%patch add gcc --rsb-file=gcc-593631849bb5e0df5cc4ff42c1a1cc34b7eec2f8.patch https://gcc.gnu.org/git/?p=gcc.git;a=blobdiff_plain;f=gcc/config.gcc;h=593631849bb5e0df5cc4ff42c1a1cc34b7eec2f8;hp=a9196cd26d9ec24c2e3f6026f63348cae3734861;hb=e840389000b8339a63bee56d8b35c83fa11dea0c;hpb=4bca9835915bbe8a5ec229b04d8d6cf4d8be19a8
-%hash sha512 gcc-593631849bb5e0df5cc4ff42c1a1cc34b7eec2f8.patch 003cb678cd2a87acaa6995624d4ddd79e080096571604880cf6a0db1afa98f25bfe61499bd0b62c961f999c4001d005b39d012d3d9a1f8dce7f0d1230cc17bf6
-%patch add gcc --rsb-file=gcc-7ea9ebdb77b6a9b7060ad2362318e0e12b9058ae.patch https://gcc.gnu.org/git/?p=gcc.git;a=blobdiff_plain;f=gcc/config/rs6000/rtems.h;h=7ea9ebdb77b6a9b7060ad2362318e0e12b9058ae;hp=8a62fdcbaf321d616021c4c396619b7f56cf5ed2;hb=e840389000b8339a63bee56d8b35c83fa11dea0c;hpb=4bca9835915bbe8a5ec229b04d8d6cf4d8be19a8
-%hash sha512 gcc-7ea9ebdb77b6a9b7060ad2362318e0e12b9058ae.patch 9fbd0a9d1568c1b5536f449a9f8bd7ab63f20007119831aa16d3878f1a3e8fc631e2e36b59d39e5e609c54a61e2f84ccb80c43a35eb40d2caa3065e6a2b840df
-%include %{_configdir}/gcc-7.2-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg b/rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg
index cfda5aa..0000000
--- a/rtems/config/tools/rtems-gcc-7.2.0-newlib-2.5.0.20170922-1.cfg
+++ /dev/null
@@ -1,50 +0,0 @@
-%endif
-# SPARC chip errata workarounds
-%patch add gcc -p1 https://devel.rtems.org/raw-attachment/ticket/3242/gcc-sparc-ticket-3242-v2.patch
-%hash sha512 gcc-sparc-ticket-3242-v2.patch 6c815975747ddf7a5bad0b0aa3fb57a5328756eb5e9d314d7dc39038e1bdafb117fb938e3b5e8c85a34fff55359d96396fc277187cfcc6fdf13496b1167e8a98
-# Ada: Fix some POSIX types
-%patch add gcc -p1 https://devel.rtems.org/raw-attachment/ticket/3256/v2-0001-RTEMS-Ada-Fix-some-POSIX-types.patch
-%hash sha512 v2-0001-RTEMS-Ada-Fix-some-POSIX-types.patch b323908044a2780c1a24879784c85b82bafeb9c28b183f014125cdb8c0661c95ecdc22ab0011863485682faca58174315133a1be7462867a8e76901068cdd969
diff --git a/rtems/config/tools/rtems-gdb-6.8-1.cfg b/rtems/config/tools/rtems-gdb-6.8-1.cfg
index 16f087c..0000000
--- a/rtems/config/tools/rtems-gdb-6.8-1.cfg
+++ /dev/null
@@ -1,27 +0,0 @@
-# GDB 6.8.
-%define gdb_version 6.8
-# Force the standard of C code for GCC.
-%define build_cflags %{build_cflags} --std=gnu89 -Wno-return-type
-# RTEMS Build Set patches.
-%source set gdb http://ftp.gnu.org/gnu/gdb/gdb-6.8a.tar.bz2
-%patch  add gdb %{rtems_gdb_patches}/gdb-6.8-rtems4.9-20091111.diff
-%hash sha512 gdb-6.8a.tar.bz2 5114fe14ab25dc085590acff3a6feb75eb93347e501c634548308c4f51b31416ea23b8e612dfc54da466d3e7471e210d8f7a12ff6c050e9e89920884e5a64008
-%hash sha512 gdb-6.8-rtems4.9-20091111.diff 2e6eb2bdeac4bba7c2fcaf701399148fc5de82dfa81e021111f5a20654afe5aad77d6fd0edbc31965107f2fe9a43738938d79a313836267ad69dc8509fcbf691
-# The gdb build instructions. We use 6.xx Release 1.
-%include %{_configdir}/gdb-6-1.cfg
diff --git a/rtems/config/tools/rtems-gdb-7.11-1.cfg b/rtems/config/tools/rtems-gdb-7.11-1.cfg
index ed46616..0000000
--- a/rtems/config/tools/rtems-gdb-7.11-1.cfg
+++ /dev/null
@@ -1,32 +0,0 @@
-# GDB 7.11
-%define gdb_version 7.11
-%define gdb_src_ext xz
-%hash sha256 gdb-%{gdb_version}.tar.xz 7a434116cb630d77bb40776e8f5d3937bed11dea56bafebb4d2bc5dd389fe5c1
-# aarch64 and x86_64 support.
-%patch add gdb -p1 %{rtems_gdb_patches}/gdb-7.11-aarch64-x86_64.patch
-%hash sha512 gdb-7.11-aarch64-x86_64.patch 20fc58f6979afd27b4cb0d94f1d5784a5d429ca78d66956e14cd21ad7dc23899
-# ERC32 simulator fixes.
-%patch add gdb %{rtems_gdb_patches}/gdb-7.11-sis-leon2-leon3.diff
-%hash sha512 gdb-7.11-sis-leon2-leon3.diff 0b8b2a23c7d1592315fe0130188f457c80f8b1e26645535bed091a5e0671682dc44a1987d00e6939a1b1c562c7579404db43183e666c29c2b479446aa61ca4f6
- %patch add gdb -p0 %{rtems_gdb_patches}/patch-gdb-python-python-config.py
- %hash  sha256 patch-gdb-python-python-config.py c06cafc9370063b6f966c68973434f9cce6227c96e22f8ea23f156126f0b33d3
-%endif
-# The gdb build instructions. We use 7.xx Release 1.
-%include %{_configdir}/gdb-7-1.cfg
diff --git a/rtems/config/tools/rtems-gdb-7.11-2.cfg b/rtems/config/tools/rtems-gdb-7.11-2.cfg
index 1e42a8d..0000000
--- a/rtems/config/tools/rtems-gdb-7.11-2.cfg
+++ /dev/null
@@ -1,20 +0,0 @@
-# GDB 7.11
-%endif
diff --git a/rtems/config/tools/rtems-gdb-7.12-1.cfg b/rtems/config/tools/rtems-gdb-7.12-1.cfg
index f049dca..0000000
--- a/rtems/config/tools/rtems-gdb-7.12-1.cfg
+++ /dev/null
@@ -1,41 +0,0 @@
-# GDB 7.12
-%define gdb_version 7.12
-%hash md5 gdb-%{gdb_version}.tar.xz a0a3a00f7499b0c5278ba8676745d180
-%patch add gdb https://gaisler.org/gdb/gdb-7.12.1-sis-leon2-leon3.diff
-%hash md5 gdb-7.12.1-sis-leon2-leon3.diff 40670e05b7fc3868a405fb43138f3262
-%patch add gdb https://sourceware.org/git/gitweb.cgi?p=binutils-gdb.git;a=blobdiff_plain;f=gdb/location.c;h=8dce21ada12b3f8cb4145d1af96e29efe378bda2;hp=65116c732f7071444986c4b582580b7cc4622f0b;hb=909de2c5cc91b815d671f7018da2a925fbd19aaf;hpb=a945860b6cb4f8a26343ac5dcb0b42fe5fb2f68a
-%hash sha512 binutils-gdb-git-8dce21ada12b3f8cb4145d1af96e29efe378bda2.patch c5acc276312067cdb9bbda1678f066b3d2b2c1e11275574aa2e3b5c4541c51e670da00e057a184211b282df254e9e1afa14ae7563f2a0588cf11a4dcbd2e5f7a
-# FreeBSD specific fixes (still OK from 7.11)
- %patch add gdb -p0 https://svnweb.freebsd.org/ports/head/devel/gdb/files/patch-gdb-gnulib-import-stddef.in.h?revision=428876&view=co
- %hash  sha256 patch-gdb-gnulib-import-stddef.in.h da35940004c6fa8d113013c1019e0a3b8267d1d5e1d79b2c78becb055cd261f3
- %patch add gdb -p0 https://svnweb.freebsd.org/ports/head/devel/gdb/files/patch-gdb-python-python-config.py?revision=384978&view=co
- %hash  sha256 patch-gdb-python-python-config.py 1c5d1362828c9b343e4a48a0cc1f63775726fbe8c9ead6078dec76442c0221ea
- %patch add gdb --rsb-file=PATCH_Define_an_error_function_in_the_PPC_simulator https://sourceware.org/cgi-bin/get-raw-msg?listname=gdb-patches&date=2016-11&msgid=20161124152917.52189-1-jhb%40FreeBSD.org
- %hash sha256 PATCH_Define_an_error_function_in_the_PPC_simulator 26a39e952a5427207f4dc76beececbd72eaeb9ab85f984e53457df309767998c
-%endif
-%if %{_build_os} == darwin
-%endif
diff --git a/rtems/config/tools/rtems-gdb-7.3.1-1.cfg b/rtems/config/tools/rtems-gdb-7.3.1-1.cfg
index 0adefa1..0000000
--- a/rtems/config/tools/rtems-gdb-7.3.1-1.cfg
+++ /dev/null
@@ -1,20 +0,0 @@
-# GDB 7.3.
-%define gdb_version 7.3.1
-%hash md5 gdb-%{gdb_version}.tar.bz2 b89a5fac359c618dda97b88645ceab47
-%patch add gdb %{rtems_gdb_patches}/gdb-7.3.1-rtems4.10-20120918.diff
-%hash md5 gdb-7.3.1-rtems4.10-20120918.diff 81607fc7366fe2ee0a2c8f991929acdc
-%patch add gdb %{rtems_gdb_patches}/gdb-7.3.1-rtems4.10-20151123.diff
-%hash sha512 gdb-7.3.1-rtems4.10-20151123.diff 2e03f9b01626a1f18c025eecb70350bdd7a29574970fb80edc985d0c5731325a68e42d55fb5d3e23440ea6e384e093269cca79a95d5a4e44a678439977da313f
diff --git a/rtems/config/tools/rtems-gdb-7.5-1.cfg b/rtems/config/tools/rtems-gdb-7.5-1.cfg
index 7853d40..0000000
--- a/rtems/config/tools/rtems-gdb-7.5-1.cfg
+++ /dev/null
@@ -1,15 +0,0 @@
-# GDB 7.5.
-%define gdb_version 7.5
-%patch add gdb %{rtems_gdb_patches}/gdb-7.5-rtems4.11-20121003.diff
diff --git a/rtems/config/tools/rtems-gdb-7.5.1-1.cfg b/rtems/config/tools/rtems-gdb-7.5.1-1.cfg
index 7cebe17..0000000
--- a/rtems/config/tools/rtems-gdb-7.5.1-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GDB 7.5.1.
-%define gdb_version 7.5.1
diff --git a/rtems/config/tools/rtems-gdb-7.6-1.cfg b/rtems/config/tools/rtems-gdb-7.6-1.cfg
index 9d359e6..0000000
--- a/rtems/config/tools/rtems-gdb-7.6-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GDB 7.6.
-%define gdb_version 7.6
diff --git a/rtems/config/tools/rtems-gdb-7.6.1-1.cfg b/rtems/config/tools/rtems-gdb-7.6.1-1.cfg
index 4841256..0000000
--- a/rtems/config/tools/rtems-gdb-7.6.1-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GDB 7.6.1.
-%define gdb_version 7.6.1
diff --git a/rtems/config/tools/rtems-gdb-7.6.2-1.cfg b/rtems/config/tools/rtems-gdb-7.6.2-1.cfg
index 523e55f..0000000
--- a/rtems/config/tools/rtems-gdb-7.6.2-1.cfg
+++ /dev/null
@@ -1,17 +0,0 @@
-# GDB 7.6.2.
-%define gdb_version 7.6.2
-%endif
diff --git a/rtems/config/tools/rtems-gdb-7.7-1.cfg b/rtems/config/tools/rtems-gdb-7.7-1.cfg
index 0f99725..0000000
--- a/rtems/config/tools/rtems-gdb-7.7-1.cfg
+++ /dev/null
@@ -1,29 +0,0 @@
-# GDB 7.7.
-%define gdb_version 7.7
-%define gdb_src_ext bz2
-%hash md5 gdb-%{gdb_version}.tar.bz2 271a18f41858a7e98b28ae4eb91287c9
-# Clean up the sim-arange inline code so it builds.
-%patch add gdb %{rtems_gdb_patches}/gdb-sim-arange-inline.diff
-%hash  md5 gdb-sim-arange-inline.diff 11bb2936ea29afeaa023077191fd4705
-%patch add gdb %{rtems_gdb_patches}/gdb-sim-cgen-inline.diff
-%hash  md5 gdb-sim-cgen-inline.diff e6f7d6d7295cdba99f51aab514ea9778
- %hash  md5 patch-gdb-python-python-config.py c0260fcca4c1a5509635049c0094eee3
-%endif
diff --git a/rtems/config/tools/rtems-gdb-7.7.1-1.cfg b/rtems/config/tools/rtems-gdb-7.7.1-1.cfg
index 2e49f38..0000000
--- a/rtems/config/tools/rtems-gdb-7.7.1-1.cfg
+++ /dev/null
@@ -1,26 +0,0 @@
-# GDB 7.7.1.
-%define gdb_version 7.7.1
-%endif
diff --git a/rtems/config/tools/rtems-gdb-7.8.1-1.cfg b/rtems/config/tools/rtems-gdb-7.8.1-1.cfg
index 19e0544..0000000
--- a/rtems/config/tools/rtems-gdb-7.8.1-1.cfg
+++ /dev/null
@@ -1,28 +0,0 @@
-# GDB 7.8.1
-%define gdb_version 7.8.1
-#%hash md5 gdb-%{gdb_version}.tar.bz2 997492cc3475c96f35ecc8775248c9b1
-%patch add gdb https://devel.rtems.org/raw-attachment/ticket/3226/gdb-sim-arange-inline.diff
-%hash  sha256 gdb-sim-arange-inline.diff d20d509942c9f9a69d191b8d8c1546e27d78768dba10b339acad708cf9997d81
-%patch add gdb https://devel.rtems.org/raw-attachment/ticket/3226/gdb-sim-cgen-inline.diff
-%hash  sha256 gdb-sim-cgen-inline.diff 0ec465d3c5ae967d125409488a1d24fda90b361051adebee32b7512a4031606e
-%endif
diff --git a/rtems/config/tools/rtems-gdb-7.8.2-1.cfg b/rtems/config/tools/rtems-gdb-7.8.2-1.cfg
index 9a5f3cb..0000000
--- a/rtems/config/tools/rtems-gdb-7.8.2-1.cfg
+++ /dev/null
@@ -1,29 +0,0 @@
-# GDB 7.8.2
-%define gdb_version 7.8.2
-%hash md5 gdb-%{gdb_version}.tar.xz a80cf252ed2e775d4e4533341bbf2459
-%endif
diff --git a/rtems/config/tools/rtems-gdb-7.9-1.cfg b/rtems/config/tools/rtems-gdb-7.9-1.cfg
index 5fa293e..0000000
--- a/rtems/config/tools/rtems-gdb-7.9-1.cfg
+++ /dev/null
@@ -1,42 +0,0 @@
-# GDB 7.9
-%define gdb_version 7.9
-%hash sha256 gdb-%{gdb_version}.tar.xz 9b315651a16528f7af8c7d8284699fb0c965df316cc7339bb0b7bae335848392
-# Fix building on Windows. Download the patches from GDB git repo.
-#%define sourceware_binutils_gdb http://sourceware.org/git/gitweb.cgi?p=binutils-gdb.git;a=patch
-#%patch add gdb %{sourceware_binutils_gdb};h=63413d85873c450fa4ed2494f21fb1a65bdaf554
-#%patch add gdb %{sourceware_binutils_gdb};h=03b7960334677d33ee7410f2c819f78820c32024
-%patch add gdb -p1 %{rtems_gdb_patches}/gdb-7.9-aarch64-x86_64.patch
-%hash sha256 gdb-7.9-aarch64-x86_64.patch e809ccb4fffa0188cb985512695e0f48
-%endif
diff --git a/rtems/config/tools/rtems-kernel-4.10.2.cfg b/rtems/config/tools/rtems-kernel-4.10.2.cfg
index 29d4b95..0000000
--- a/rtems/config/tools/rtems-kernel-4.10.2.cfg
+++ /dev/null
@@ -1,17 +0,0 @@
-# RTEMS 4.10.2
-%define rsb_released
-%define rtems_kernel_version     4.10.2
-%define rtems_kernel_compression bz2
-%hash md5 rtems-%{rtems_kernel_version}.tar.bz2 158566d0f1330d4eaba5a60e757d3dd0
-# The RTEMS build instructions. We use 4.xx Release 1.
-%include tools/rtems-kernel-4-1.cfg
diff --git a/rtems/config/tools/rtems-kernel-4.9.6-1.cfg b/rtems/config/tools/rtems-kernel-4.9.6-1.cfg
index d48bc44..0000000
--- a/rtems/config/tools/rtems-kernel-4.9.6-1.cfg
+++ /dev/null
@@ -1,17 +0,0 @@
-# RTEMS 4.9.6
-%define rtems_kernel_version     4.9.6
-%hash sha512 rtems-4.9.6.tar.bz2 16ab7b2f9119208a24dc0bd21361a5fd910e73044c42d7b68174490ca9cc5c226543664831f9a036f28d1cf8b61d19a15404516d7a87d424e0bc2c09e60767e3
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg b/rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
index 836c0bb..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
+++ /dev/null
@@ -1,11 +0,0 @@
-# MIPS STX39 GDB 7.6.
-%undefine _target
-%define _target mipstx39-rtems%{rtems_version}
-# The gdb build instructions for RTEMS 7.6.
-%include tools/rtems-gdb-7.6-1.cfg
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg b/rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
index 0e65b5e..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
+++ /dev/null
@@ -1,11 +0,0 @@
-# MIPS STX39 GDB 7.7.
-%undefine _target
-# The gdb build instructions for RTEMS 7.7.
-%include tools/rtems-gdb-7.7-1.cfg
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg b/rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg
index 5777b5f..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-7.9-1.cfg
+++ /dev/null
@@ -1,11 +0,0 @@
-# MIPS TX39 GDB 7.9.
-%undefine _target
-# The gdb 7.9 build instructions for RTEMS.
-%include tools/rtems-gdb-7.9-1.cfg
diff --git a/rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg b/rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg
index 92f9520..0000000
--- a/rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg
+++ /dev/null
@@ -1,26 +0,0 @@
-# RTEMS NIOS2 Binutils 2.21.
-%disable select
-%define binutils_version 2.20
-%define host_force_32bit
-%define with_deterministic_archives
-# Source
-%source set binutils http://ftp.rtems.org/pub/rtems/people/chrisj/nios/nios2-binutils-2.20.tar.bz2
-%hash   md5 nios2-binutils-2.20.tar.bz2 42ce11b421a1d35fc7b17ee051ccf92a
-%patch  add binutils %{rtems_binutils_patches}/nios2/nios2-binutils-2.20-rtems-20110703.diff
-%hash   md5 nios2-binutils-2.20-rtems-20110703.diff edaa78cdf7b87866c976232ccb1704ac
-# The binutils build instructions. We use 2.xx Release 1.
-%include %{_configdir}/binutils-2-1.cfg
diff --git a/rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg b/rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg
index 28342cd..0000000
--- a/rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg
+++ /dev/null
@@ -1,179 +0,0 @@
-# RTEMS NIOS2 GCC 4.1., Newlib 1.19.0
-# This configuration has special support for the NIOS2.
-%disable select
-%define gcc_version    4.1
-%define newlib_version 1.19.0
-%define newlib_cfg     normalc
-%define with_threads 1
-%define with_plugin  0
-%define enable_cxx   1
-# The RTEMS 4.11 patches
-%patch add gcc %{rtems_gcc_patches}/nios2/nios2-gcc-4.1-rtems-20110818.diff
-%patch add newlib %{rtems_newlib_patches}/nios2/nios2-newlib-1.19.0-rtems-20110720.diff
-Name:      %{_target}-gcc-%{gcc_version}-newlib-%{newlib_version}-%{release}
-Summary:   GCC v%{gcc_version} and Newlib v%{newlib_version} for target %{_target} on host %{_host}
-Version:   %{gcc_version}
-Release:   %{release}
-URL: 	   http://gcc.gnu.org/
-BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
-# Supports Candian Cross (Cxc).
-%define allow_cxc
-# Source
-# GCC core and G++
-%source set gcc http://ftp.rtems.org/pub/rtems/people/chrisj/nios/nios2-gcc-4.1.tar.bz2
-%hash   md5 nios2-gcc-4.1.tar.bz2 717e5a25fda68d96d09353bcfa149cff
-# Newlib
-%source set newlib ftp://sourceware.org/pub/newlib/newlib-%{newlib_version}.tar.gz
-%hash   md5 newlib-%{newlib_version}.tar.gz 0966e19f03217db9e9076894b47e6601
-# The GCC library directory
-%global _gcclibdir %{_prefix}/lib
-# Prepare the source code.
-%prep
-  # save the build top directory and cd back to it rather than
-  # using 'cd ..' because some shells change $PWD to a symlink's
-  # target location and 'cd ..' fails.
-  build_top=$(pwd)
-  # gcc
-  source_dir_gcc="gcc-%{gcc_version}"
-  %source setup gcc -q -b -n gcc-%{gcc_version}
-  %patch setup gcc -p1
-  cd ${build_top}
-  # newlib
-  source_dir_newlib="newlib-%{newlib_version}"
-  %source setup newlib -q -b -n newlib-%{newlib_version}
-  %patch setup newlib -p1
-  cd ${build_top}
-  # Link newlib into the gcc source tree
-  %{__rmfile} ${source_dir_gcc}/newlib
-  %{__ln_s} $PWD/${source_dir_newlib}/newlib ${source_dir_gcc}/newlib
-  echo "%{gcc_version_message}" > gcc-%{gcc_version}/gcc/DEV-PHASE
-  # Fix timestamps
-  cd ${source_dir_gcc}
-  contrib/gcc_update --touch
-  cd ${build_top}
-%build
-  %{build_directory}
-  mkdir -p ${build_dir}
-  cd ${build_dir}
-  languages="c"
-%if %{enable_cxx}
-  languages="$languages,c++"
-%endif
-  %{host_build_flags}
-  ../${source_dir_gcc}/configure \
-    --prefix=%{_prefix} \
-    --bindir=%{_bindir} \
-    --exec_prefix=%{_exec_prefix} \
-    --includedir=%{_includedir} \
-    --libdir=%{_gcclibdir} \
-    --libexecdir=%{_libexecdir} \
-    --mandir=%{_mandir} \
-    --infodir=%{_infodir} \
-    --datadir=%{_datadir} \
-    --build=%_build --host=%_host \
-    --target=%{_target} \
-    --disable-libstdcxx-pch \
-    --with-gnu-as --with-gnu-ld --verbose \
-    --with-newlib \
-    --with-system-zlib \
-    --disable-nls --without-included-gettext \
-    --disable-win32-registry \
-    --enable-version-specific-runtime-libs \
-    %{?with_lto:--enable-lto}%{!?with_lto:--disable-lto} \
-    %{?with_threads:--enable-threads}%{!?with_threads:--disable-threads} \
-    %{?with_plugin:--enable-plugin}%{!?with_plugin:--disable-plugin} \
-    %{?enable_obsolete:--enable-obsolete} \
-    --enable-languages="$languages"
-  if test "%_host" != "%_build" ; then
-    # Bug in gcc-3.2.1:
-    # Somehow, gcc doesn't get syslimits.h right for Cdn-Xs
-    mkdir -p gcc/include
-    cp ../${source_dir_gcc}/gcc/gsyslimits.h gcc/include/syslimits.h
-  fi
-  # jobs > 1 is broken with this version of gcc
-  %{__make} -w N2GNU_BUILD_NEWLIB="%{newlib_cfg}" all
-  cd ..
-%install
-  %{__rmdir} $SB_BUILD_ROOT
-  cd ${build_dir}
-  # Filter the doc stuff we do not want so it builds without error on
-  # hosts that do not have tex to pdf converters installed.
-  for m in $(find . -name Makefile)
-  do
-    mv $m $m.orig
-    echo "Doc filteirng $m.orig -> $m"
-    cat $m.orig | sed -e 's/ pdf / /g' \
-                      -e 's/ pdf$/ /g' \
-                      -e 's/ install-pdf / /g' \
-                      -e 's/ install-pdf$/ /g' \
-                      -e 's/ install-html / /g' \
-                      -e 's/ install-html$/ /g' \
-                      -e 's/ html / /g' \
-                      -e 's/ html$/ /g' > $m
-  done
-  %{__make} -w DESTDIR=$SB_BUILD_ROOT N2GNU_BUILD_NEWLIB="%{newlib_cfg}" install
-  cd ..
-  # libiberty doesn't honor --libdir, but always installs to a
-  # magically guessed _libdir
-  %{__rmfile} ${SB_BUILD_ROOT}%{_libdir}/libiberty.a
-  # We use the version from binutils
-  %{__rmfile} $SB_BUILD_ROOT%{_bindir}/%{_target}-c++filt%{_exeext}
-  # We don't ship info/dir
-  %{__rmfile} $SB_BUILD_ROOT%{_infodir}/dir
-  # Don't want libffi's man-pages
-  %{__rmfile} $SB_BUILD_ROOT%{_mandir}/man3/*ffi*
-  # Clean the symlinks away incase the source is a repo
diff --git a/rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg b/rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg
index 1af43ba..0000000
--- a/rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg
+++ /dev/null
@@ -1,19 +0,0 @@
-# GDB 7.0.
-%disable select
-%define gdb_version 7.0
-%define without_python
-%source set gdb http://ftp.rtems.org/pub/rtems/people/chrisj/nios/nios2-gdb-7.0.tar.bz2
diff --git a/rtems/config/tools/rtems-tools-4.11-1.cfg b/rtems/config/tools/rtems-tools-4.11-1.cfg
index 67f8fe2..0000000
--- a/rtems/config/tools/rtems-tools-4.11-1.cfg
+++ /dev/null
@@ -1,17 +0,0 @@
-# RTEMS Tools for 4.11.
-# The RTEMS Tools version is set to the RSB version or the RTEMS version.
-%if %{rsb_released}
- %define rtems_tools_version %{rsb_version}
-%else
- %define rtems_tools_version %{rtems_version}
-%endif
-# The RTEMS Tools build instructions. We use GIT Release 1.
-%include tools/rtems-tools-1.cfg
2.14.1
