[PATCH 2/6] sb: Add an orphan check to sb-check.
Thu Jan 18 05:27:02 UTC 2018
The orphans check lets you see which configuration and build set
files in the RSB are not referernced. You can audit the list and
remove any configuration files not being used. Top level
build set files are included so you need to becareful not to
remove something that is valid and useful. To run:
 $ ./source-builder/sb-check --check-orphans
Update #3274
 source-builder/sb/check.py | 110 +++++++++++++++++++++++++++++++++++++++++++--
 1 file changed, 107 insertions(+), 3 deletions(-)
diff --git a/source-builder/sb/check.py b/source-builder/sb/check.py
index 85a1fbe..183f4af 100644
--- a/source-builder/sb/check.py
+++ b/source-builder/sb/check.py
@@ -27,9 +27,11 @@ import os
 import error
 import execute
+import fnmatch
 import log
 import options
 import path
+import re
 import version
 def _check_none(_opts, macro, value, constraint):
@@ -162,15 +164,117 @@ def check_exe(label, exe):
     return _check_exe(None, label, exe, None, True)
+def check_orphans(opts):
+    def _find_files(path, globs, excludes = []):
+        ff = []
+        for root, dirs, files in os.walk(path, followlinks = True):
+            for f in files:
+                for g in globs:
+                    if fnmatch.fnmatch(f, g) and f not in excludes:
+                        ff += [os.path.join(root, f)]
+        return sorted(ff)
+    def _clean(line):
+        line = line[0:-1]
+        b = line.find('#')
+        if b >= 0:
+            line = line[1:b]
+        return line.strip()
+    def _find(name, opts):
+        ename = opts.defaults.expand(name)
+        if ':' in ename:
+            paths = path.dirname(ename).split(':')
+            name = path.basename(name)
+        else:
+            paths = opts.defaults.get_value('_configdir').split(':')
+        for p in paths:
+            n = path.join(opts.defaults.expand(p), name)
+            if path.exists(n):
+                return n
+        return None
+    cfgs = {}
+    for p in paths:
+        ep = opts.defaults.expand(p)
+        print('Scanning: %s (%s)' % (p, ep))
+        for f in _find_files(ep, ['*.cfg', '*.bset']):
+            root, ext = path.splitext(f)
+            cfgs[f] = { 'src': None, 'ext': ext, 'refs': 0, 'errors':[] }
+    wss = re.compile(r'\s+')
+    for c in cfgs:
+        with open(c, 'r') as f:
+            cfgs[c]['src'] = f.readlines()
+        lc = 0
+        for l in cfgs[c]['src']:
+            lc += 1
+            l = _clean(l)
+            if len(l) == 0:
+                continue
+            if l[0] == '%':
+                ls = wss.split(l, 2)
+                if ls[0] == '%include':
+                    name = _find(ls[1], opts)
+                    if name is None:
+                        cfgs[c]['errors'] += [lc]
+                    elif name not in cfgs:
+                        raise error.general('include: %s: not present' % (ls[1]))
+                    else:
+                        cfgs[name]['refs'] += 1
+            elif cfgs[c]['ext'] == '.bset' and ':' not in l:
+                for ext in ['', '.cfg', '.bset']:
+                    name = _find(l + ext, opts)
+                    if name is not None:
+                        if name not in cfgs:
+                        else:
+                        break
+    topdir = opts.defaults.expand('%{_topdir}')
+    orphans = []
+    show = True
+    for c in cfgs:
+        if cfgs[c]['refs'] == 0:
+            orphans += [c]
+        if len(cfgs[c]['errors']) != 0:
+            if show:
+                print('Warnings:')
+                show = False
+            print(' %s:' % (path.relpath(c)))
+            for l in cfgs[c]['errors']:
+                print('  %3d: %s' % (l, cfgs[c]['src'][l - 1][:-1]))
+    show = True
+    for o in sorted(orphans):
+        if show:
+            print('Orphans:')
+            show = False
+        print(' %s' % (path.relpath(o)))
 def run():
     import sys
     try:
         _opts = options.load(args = sys.argv)
         log.notice('RTEMS Source Builder - Check, %s' % (version.str()))
-        if host_setup(_opts):
-            print('Environment is ok')
+        orphans = _opts.parse_args('--check-orphans', error = False, extra = False)
+        if orphans:
+            print('Checking for orphans...')
+            check_orphans(_opts)
         else:
-            print('Environment is not correctly set up')
+            if host_setup(_opts):
+                print('Environment is ok')
+            else:
+                print('Environment is not correctly set up')
     except error.general as gerr:
         print(gerr)
         sys.exit(1)
2.14.1
