[PATCH 5/6] rtems: Remobve used tool configurations.
Thu Jan 18 05:27:05 UTC 2018
Update 3274
 rtems/config/tools/rtems-binutils-2.19.1-1.cfg     |  13 --
 rtems/config/tools/rtems-binutils-2.20.1-1.cfg     |  21 ---
 rtems/config/tools/rtems-binutils-2.22-1.cfg       |  15 --
 rtems/config/tools/rtems-binutils-2.23.2-1.cfg     |  20 ---
 rtems/config/tools/rtems-binutils-2.24-1.cfg       |  22 ---
 rtems/config/tools/rtems-binutils-git-1.cfg        |  21 ---
 .../tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg      |  29 ----
 .../tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg      |  52 ------
 .../tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg       |  26 ---
 .../tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg       |  26 ---
 .../tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg      |  43 -----
 .../tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg      |  52 ------
 .../tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg       |  32 ----
 .../tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg       |  32 ----
 .../tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg      |  26 ---
 .../config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg  |  37 -----
 .../config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg  |  50 ------
 .../tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg       |  39 -----
 .../config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg  |  13 --
 .../rtems-gcc-4.8.3-newlib-2.20.0-20150323-1.cfg   |  14 --
 .../config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg  |  13 --
 .../config/tools/rtems-gcc-4.8.3-newlib-git-1.cfg  |  13 --
 .../tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg       |  40 -----
 .../config/tools/rtems-gcc-4.9.0-newlib-cvs-1.cfg  |  11 --
 .../config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg  |  13 --
 .../tools/rtems-gcc-4.9.2-newlib-2.2.0-1-1.cfg     |  14 --
 .../rtems-gcc-4.9.2-newlib-2.2.0-20150423-1.cfg    |  14 --
 .../rtems-gcc-4.9.2-newlib-2.20.0-20150323-1.cfg   |  14 --
 .../config/tools/rtems-gcc-4.9.2-newlib-git-1.cfg  |  13 --
 rtems/config/tools/rtems-gdb-6.8-1.cfg             |  19 ---
 rtems/config/tools/rtems-gdb-7.3.1-1.cfg           |  18 ---
 rtems/config/tools/rtems-gdb-7.5-1.cfg             |  15 --
 rtems/config/tools/rtems-gdb-7.6.1-1.cfg           |  13 --
 rtems/config/tools/rtems-gdb-7.6.2-1.cfg           |  17 --
 rtems/config/tools/rtems-gdb-7.7.1-1.cfg           |  26 ---
 rtems/config/tools/rtems-gdb-7.8.2-1.cfg           |  29 ----
 rtems/config/tools/rtems-kernel-4.10.2.cfg         |  16 --
 rtems/config/tools/rtems-kernel-4.9.6-1.cfg        |  14 --
 rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg  |  11 --
 rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg    |  11 --
 rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg    |  11 --
 rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg |  26 ---
 .../tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg  | 179 ---------------------
 rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg       |  19 ---
 rtems/config/tools/rtems-tools-git-1.cfg           |  53 ------
 45 files changed, 1205 deletions(-)
 delete mode 100644 rtems/config/tools/rtems-binutils-2.19.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-2.20.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-2.22-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-2.23.2-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-2.24-1.cfg
 delete mode 100644 rtems/config/tools/rtems-binutils-git-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-2.20.0-20150323-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.8.3-newlib-git-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.0-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-20150423-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-2.20.0-20150323-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gcc-4.9.2-newlib-git-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-6.8-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.3.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.5-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.6.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.6.2-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.7.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-gdb-7.8.2-1.cfg
 delete mode 100644 rtems/config/tools/rtems-kernel-4.10.2.cfg
 delete mode 100644 rtems/config/tools/rtems-kernel-4.9.6-1.cfg
 delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg
 delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
 delete mode 100644 rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
 delete mode 100644 rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg
 delete mode 100644 rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg
 delete mode 100644 rtems/config/tools/rtems-tools-git-1.cfg
diff --git a/rtems/config/tools/rtems-binutils-2.19.1-1.cfg b/rtems/config/tools/rtems-binutils-2.19.1-1.cfg
deleted file mode 100644
index fb9f018..0000000
--- a/rtems/config/tools/rtems-binutils-2.19.1-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# Binutils 2.19.
-%include %{_configdir}/checks.cfg
-%include %{_configdir}/base.cfg
-%define binutils_version 2.19.1
-# The binutils build instructions. We use 2.xx Release 1.
-%include %{_configdir}/binutils-2-1.cfg
diff --git a/rtems/config/tools/rtems-binutils-2.20.1-1.cfg b/rtems/config/tools/rtems-binutils-2.20.1-1.cfg
index 925730d..0000000
--- a/rtems/config/tools/rtems-binutils-2.20.1-1.cfg
+++ /dev/null
@@ -1,21 +0,0 @@
-# Binutils 2.22.
-%define binutils_version 2.20.1
-%hash md5 binutils-%{binutils_version}.tar.bz2 2b9dc8f2b7dbd5ec5992c6e29de0b764
-%patch add binutils %{rtems_binutils_patches}/binutils-2.20.1-rtems4.10-20100826.diff
-%hash md5 binutils-2.20.1-rtems4.10-20100826.diff 733899876e0b32ce0700666b29662d91
-%ifos win32 mingw ming32 cygwin
- %patch add binutils %{rtems_binutils_patches}/cygwin/binutils-2.20.1-cygwin-w64-20130324.diff
-%endif
diff --git a/rtems/config/tools/rtems-binutils-2.22-1.cfg b/rtems/config/tools/rtems-binutils-2.22-1.cfg
index 664f5d9..0000000
--- a/rtems/config/tools/rtems-binutils-2.22-1.cfg
+++ /dev/null
@@ -1,15 +0,0 @@
-# Binutils 2.22.
-%define binutils_version 2.22
-%patch add binutils %{rtems_binutils_patches}/binutils-2.22-rtems4.11-20120427.diff
diff --git a/rtems/config/tools/rtems-binutils-2.23.2-1.cfg b/rtems/config/tools/rtems-binutils-2.23.2-1.cfg
index d4f2c4b..0000000
--- a/rtems/config/tools/rtems-binutils-2.23.2-1.cfg
+++ /dev/null
@@ -1,20 +0,0 @@
-# Binutils 2.23.
-%define binutils_version 2.23.2
-# Enable deterministic archives by default. This will be the default
-# there all tools using this binutils will create deterministic
-# archives.
-%define with_deterministic_archives 1
diff --git a/rtems/config/tools/rtems-binutils-2.24-1.cfg b/rtems/config/tools/rtems-binutils-2.24-1.cfg
index ca6c02b..0000000
--- a/rtems/config/tools/rtems-binutils-2.24-1.cfg
+++ /dev/null
@@ -1,22 +0,0 @@
-# Binutils 2.24.
-%define binutils_version 2.24
-%hash md5 binutils-%{binutils_version}.tar.bz2 e0f71a7b2ddab0f8612336ac81d9636b
-# archives.
diff --git a/rtems/config/tools/rtems-binutils-git-1.cfg b/rtems/config/tools/rtems-binutils-git-1.cfg
index da64bc1..0000000
--- a/rtems/config/tools/rtems-binutils-git-1.cfg
+++ /dev/null
@@ -1,21 +0,0 @@
-# Binutils GIT.
-%define binutils_version 6ae274b7dc305ae7cebcf55c5018dab05228235a
-%source set binutils git://sourceware.org/git/binutils-gdb.git?fetch?reset=hard?branch=master?checkout=%{binutils_version}
-# archives.
diff --git a/rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg b/rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
index 12a8003..0000000
--- a/rtems/config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg
+++ /dev/null
@@ -1,29 +0,0 @@
-# GCC 4.3.1., Newlib 1.16.0
-%define gcc_version    4.3.2
-%define newlib_version 1.16.0
-%define mpfr_version   2.4.2
-%define mpc_version    0.8.2
-%define gmp_version    5.0.5
-%define with_threads 1
-%define with_plugin  0
-%define with_iconv   0
-# The RTEMS 4.9 patches
-%source set gcc ftp://ftp.gnu.org/pub/gnu/gcc/gcc-%{gcc_version}/gcc-core-%{gcc_version}.tar.bz2
-%patch  add gcc %{rtems_gcc_patches}/gcc-core-4.3.2-rtems4.9-20090825.diff
-%source add gcc ftp://ftp.gnu.org/pub/gnu/gcc/gcc-%{gcc_version}/gcc-g++-%{gcc_version}.tar.bz2
-%patch  add gcc %{rtems_newlib_patches}/newlib-1.16.0-rtems4.9-20090324.diff
-# The gcc/newlib build instructions. We use 4.7 Release 1.
-%include %{_configdir}/gcc-4.3-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg b/rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg
index b6e1a76..0000000
--- a/rtems/config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg
+++ /dev/null
@@ -1,52 +0,0 @@
-# GCC 4.4.7, Newlib 1.18.0
-# M32C C++ does not work.
-#   gcc-4.4.7/libstdc++-v3/src/mt_allocator.cc:76: error: cast from 'void*' to 'size_t' loses precision
-%if %{_target} == m32c-rtems4.10
-%define enable_cxx 0
-%endif
-%define gcc_version    4.4.7
-%define newlib_version 1.18.0
-%define mpc_version    0.8.1
-%define with_iconv   1
-%hash md5 gcc-core-%{gcc_version}.tar.bz2 3bda0831d654964ee152c46fa8d29e46
-%hash md5 gcc-g++-%{gcc_version}.tar.gz 421ba1dfe821f32998b28ee40e71dd37
-%hash md5 newlib-%{newlib_version}.tar.gz 3dae127d4aa659d72f8ea8c0ff2a7a20
-# Hash checksums of the libraries used in GCC.
-%hash md5 mpfr-%{mpfr_version}.tar.bz2 89e59fe665e2b3ad44a6789f40b059a0
-%hash md5 mpc-%{mpc_version}.tar.gz    5b34aa804d514cc295414a963aedb6bf
-%hash md5 gmp-%{gmp_version}.tar.bz2   041487d25e9c230b0c42b106361055fe
-# The RTEMS 4.10 patches
-%patch add gcc %{rtems_gcc_patches}/gcc-core-4.4.7-rtems4.10-20120314.diff
-%hash md5 gcc-core-4.4.7-rtems4.10-20120314.diff 084c9085c255b1f6a9204e239dde0579
-%if %{enable_cxx}
- %patch add gcc %{rtems_gcc_patches}/gcc-g++-4.4.7-rtems4.10-20120314.diff
- %hash md5 gcc-g++-4.4.7-rtems4.10-20120314.diff e187db20f6d98048368f9ef86f9126dc
-%endif
-%patch add newlib %{rtems_newlib_patches}/newlib-1.18.0-rtems4.10-20110518.diff
-%hash md5 newlib-1.18.0-rtems4.10-20110518.diff e6508b36490d841b00d5011ed11cdc16
-# The gcc/newlib build instructions. We use 4.4 Release 1.
-%include %{_configdir}/gcc-4.4-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg b/rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg
index 0f5d225..0000000
--- a/rtems/config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg
+++ /dev/null
@@ -1,26 +0,0 @@
-# GCC 4.5.3., Newlib 2.0.0
-%define gcc_version    4.5.3
-%define newlib_version 2.0.0
-%define mpfr_version   3.0.1
-# Libiberty strsignal fix
-%patch add gcc %{rtems_gcc_patches}/gcc-4.5.3-strsignal-1.diff
-# The gcc/newlib build instructions. We use 4.5 Release 1.
-%include %{_configdir}/gcc-4.5-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg b/rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg
index 668e356..0000000
--- a/rtems/config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg
+++ /dev/null
@@ -1,26 +0,0 @@
-%define newlib_version 2.1.0
diff --git a/rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg b/rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg
index 9d63a92..0000000
--- a/rtems/config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg
+++ /dev/null
@@ -1,43 +0,0 @@
-# GCC 4.6.3, Newlib 1.20.0
-# AVR C++ does not work.
-#   configure: error: unable to detect exception model
-%if %{_target} == avr-rtems4.11
-%endif
-%if %{_target} == m32c-rtems4.11
-%endif
-%define gcc_version    4.6.3
-%define newlib_version 1.20.0
-# The RTEMS 4.11 patches
-%patch add gcc gcc-core-4.6.3-rtems4.11-20120303.diff
-%patch add newlib newlib-1.20.0-rtems4.11-20121011.diff
-%include %{_configdir}/gcc-4.6-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg b/rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg
index 167d7c5..0000000
--- a/rtems/config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg
+++ /dev/null
@@ -1,52 +0,0 @@
-# GCC 4.7.2., Newlib 1.20.0
-%endif
-#   gcc-4.7.2/libstdc++-v3/src/mt_allocator.cc:76: error: cast from 'void*' to 'size_t' loses precision
-%endif
-# If arm-rtems4.11 add --enable-obsolete.
-%if %{_target} == arm-rtems4.11
-%define enable_obsolete 1
-%else
-%define enable_obsolete 0
-%endif
-%define gcc_version    4.7.2
-%patch add gcc %{rtems_gcc_patches}/gcc-4.7.2-rtems4.11-20121026.diff
-%patch add newlib %{rtems_newlib_patches}/newlib-1.20.0-rtems4.11-20121011.diff
-%include %{_configdir}/gcc-4.7-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg b/rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg
index 8914815..0000000
--- a/rtems/config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg
+++ /dev/null
@@ -1,32 +0,0 @@
-# GCC 4.7.2., Newlib 2.0.0
-%include %{_configdir}/versions.cfg
-# Incompatible with Texinfo 5
-%if %{__makeinfo_ver} >= 5.0
- %error Incomaptible version of makeinfo found!
-%endif
diff --git a/rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg b/rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg
index 518e28b..0000000
--- a/rtems/config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg
+++ /dev/null
@@ -1,32 +0,0 @@
-%define gcc_version    4.7.3
-%patch add gcc %{rtems_gcc_patches}/gcc-4.7.3-rtems4.11-20130414.diff
-%endif
diff --git a/rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg b/rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg
index 0fd1641..0000000
--- a/rtems/config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg
+++ /dev/null
@@ -1,26 +0,0 @@
-# GCC 4.8.x., Newlib 2.0.0
-%define gcc_version    4.8-20130303
-%source set gcc ftp://gcc.gnu.org/pub/gcc/snapshots/%{gcc_version}/gcc-%{gcc_version}.tar.bz2
-%include %{_configdir}/gcc-4.8-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg
index 7c545fd..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,37 +0,0 @@
-# GCC 4.8.0., Newlib CVS
-%define gcc_version    4.8.0
-%define newlib_version 31-May-2013
-%endif
-# Newlib is from CVS.
-%source set newlib cvs://pserver:anoncvs@sourceware.org/cvs/src?module=newlib?src-prefix=src?date=%{newlib_version}?reset
-# Joel's stack_t patch.
-%patch add newlib -p0 %{rtems_newlib_patches}/newlib-sys-signal-20130532.diff
-# The gcc/newlib build instructions. We use 4.8 Release 1.
diff --git a/rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg
index 32c6547..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,50 +0,0 @@
-# GCC 4.8.1., Newlib CVS
-%define gcc_version    4.8.1
-%define newlib_version 15-Sept-2013
-%ifn %{defined with_iconv}
-%endif
-%endif
-# Sebastian's atexit patch.
-%patch add gcc %{rtems_gcc_patches}/gcc-4.8.1-rtems4.11-20130709.diff
-# Chris's patch to use the POSIX thread model for C++.
-%patch add gcc %{rtems_gcc_patches}/gcc-rtems-thread-model-posix-1.diff
diff --git a/rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg b/rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg
index 2c6e5e5..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg
+++ /dev/null
@@ -1,39 +0,0 @@
-# GCC 4.8.2., Newlib 2.1.0
-%define gcc_version    4.8.2
-%endif
-# Hash checksums.
-%hash md5 mpfr-%{mpfr_version}.tar.bz2    bfbecb2eacb6d48432ead5cfc3f7390a
-%hash md5 mpc-%{mpc_version}.tar.gz       e98267ebd5648a39f881d66797122fb6
-%hash md5 gcc-%{gcc_version}.tar.bz2      a3d7d63b9cb6b6ea049469a0c4a43c9d
-%hash md5 newlib-%{newlib_version}.tar.gz c6559d83ecce4728a52f0ce7ec80de97
-%hash  md5 newlib-sys-signal-20130532.diff 34af05f28a4921e47c053528f5a8b9fb
diff --git a/rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg
index c9e89b2..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.2-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GCC 4.8.2., Newlib CVS
-%define newlib_version 12-Jul-2014
-%include tools/rtems-gcc-4.8-newlib-cvs-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.20.0-20150323-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.20.0-20150323-1.cfg
index 06d2963..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-2.20.0-20150323-1.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
-# GCC 4.8.3, Newlib 2.2.0-1 (actually a snapshot)
-%define gcc_version    4.8.3
-%define newlib_version 2.2.0.20150323
-%hash md5 gcc-%{gcc_version}.tar.bz2 7c60f24fab389f77af203d2516ee110f
-%hash md5 newlib-%{newlib_version}.tar.gz a5107ff59e53a5731bdd0e245cbd1ad8
-%include tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg
index d4ea2c7..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GCC 4.8.3., Newlib CVS
-%define newlib_version 19-Aug-2014
diff --git a/rtems/config/tools/rtems-gcc-4.8.3-newlib-git-1.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-git-1.cfg
index 3a9e094..0000000
--- a/rtems/config/tools/rtems-gcc-4.8.3-newlib-git-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GCC 4.8.3., Newlib GIT
-%define newlib_version ef23a12ff8f840cc571e47870cd5f4ad6bca4553
-%include tools/rtems-gcc-4.8-newlib-git-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg b/rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg
index 3e6854e..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg
+++ /dev/null
@@ -1,40 +0,0 @@
-# GCC 4.9.0., Newlib 2.1.0
-%define gcc_version    4.9.0
-%endif
-# Hash checksums.
-%hash md5 gcc-%{gcc_version}.tar.bz2      9709b49ae0e904cbb0a6a1b62853b556
-# The gcc/newlib build instructions. We use 4.9 Release 1.
-%include %{_configdir}/gcc-4.9-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.9.0-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.9.0-newlib-cvs-1.cfg
index c8ba8b7..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.0-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,11 +0,0 @@
-# GCC 4.9.0., Newlib CVS
-%include tools/rtems-gcc-4.9-newlib-cvs-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg b/rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg
index 5fdfcdd..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.1-newlib-cvs-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GCC 4.9.1., Newlib CVS
-%define gcc_version    4.9.1
-%hash md5 gcc-%{gcc_version}.tar.bz2 fddf71348546af523353bd43d34919c1
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-1-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-1-1.cfg
index 6e1bca4..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-1-1.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
-# GCC 4.9.2., Newlib 2.2.0-1
-%define gcc_version    4.9.2
-%define newlib_version 2.2.0-1
-%hash md5 gcc-%{gcc_version}.tar.bz2 4df8ee253b7f3863ad0b86359cd39c43
-%hash md5 newlib-%{newlib_version}.tar.gz 94114fdc1d8391cdbc2653d89249cccf
-%include tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-20150423-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-20150423-1.cfg
index d5fdcca..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.2.0-20150423-1.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
-# GCC 4.9.2, Newlib 2.2.0-1 (actually a snapshot)
-%define newlib_version 2.2.0.20150423
-%hash md5 newlib-%{newlib_version}.tar.gz c819de85d4cb4be540ebf6d405f42296
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.20.0-20150323-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.20.0-20150323-1.cfg
index 4b6cd29..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-2.20.0-20150323-1.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
diff --git a/rtems/config/tools/rtems-gcc-4.9.2-newlib-git-1.cfg b/rtems/config/tools/rtems-gcc-4.9.2-newlib-git-1.cfg
index b339b8f..0000000
--- a/rtems/config/tools/rtems-gcc-4.9.2-newlib-git-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GCC 4.9.2., Newlib GIT
-%include tools/rtems-gcc-4.9-newlib-git-1.cfg
diff --git a/rtems/config/tools/rtems-gdb-6.8-1.cfg b/rtems/config/tools/rtems-gdb-6.8-1.cfg
index 9159352..0000000
--- a/rtems/config/tools/rtems-gdb-6.8-1.cfg
+++ /dev/null
@@ -1,19 +0,0 @@
-# GDB 6.8.
-%define gdb_version 6.8
-# RTEMS Build Set patches.
-%source set gdb http://ftp.gnu.org/gnu/gdb/gdb-6.8a.tar.bz2
-%patch  add gdb %{rtems_gdb_patches}/gdb-6.8-rtems4.9-20091111.diff
-# The gdb build instructions. We use 6.xx Release 1.
-%include %{_configdir}/gdb-6-1.cfg
diff --git a/rtems/config/tools/rtems-gdb-7.3.1-1.cfg b/rtems/config/tools/rtems-gdb-7.3.1-1.cfg
index 9d8bd32..0000000
--- a/rtems/config/tools/rtems-gdb-7.3.1-1.cfg
+++ /dev/null
@@ -1,18 +0,0 @@
-# GDB 7.3.
-%define gdb_version 7.3.1
-%hash md5 gdb-%{gdb_version}.tar.bz2 b89a5fac359c618dda97b88645ceab47
-%patch add gdb %{rtems_gdb_patches}/gdb-7.3.1-rtems4.10-20120918.diff
-%hash md5 gdb-7.3.1-rtems4.10-20120918.diff 81607fc7366fe2ee0a2c8f991929acdc
-# The gdb build instructions. We use 7.xx Release 1.
-%include %{_configdir}/gdb-7-1.cfg
diff --git a/rtems/config/tools/rtems-gdb-7.5-1.cfg b/rtems/config/tools/rtems-gdb-7.5-1.cfg
index 7853d40..0000000
--- a/rtems/config/tools/rtems-gdb-7.5-1.cfg
+++ /dev/null
@@ -1,15 +0,0 @@
-# GDB 7.5.
-%define gdb_version 7.5
-%patch add gdb %{rtems_gdb_patches}/gdb-7.5-rtems4.11-20121003.diff
diff --git a/rtems/config/tools/rtems-gdb-7.6.1-1.cfg b/rtems/config/tools/rtems-gdb-7.6.1-1.cfg
index 4841256..0000000
--- a/rtems/config/tools/rtems-gdb-7.6.1-1.cfg
+++ /dev/null
@@ -1,13 +0,0 @@
-# GDB 7.6.1.
-%define gdb_version 7.6.1
diff --git a/rtems/config/tools/rtems-gdb-7.6.2-1.cfg b/rtems/config/tools/rtems-gdb-7.6.2-1.cfg
index 523e55f..0000000
--- a/rtems/config/tools/rtems-gdb-7.6.2-1.cfg
+++ /dev/null
@@ -1,17 +0,0 @@
-# GDB 7.6.2.
-%define gdb_version 7.6.2
-%if %{_build_os} == freebsd
- %patch add gdb -p0 %{rtems_gdb_patches}/patch-gdb-python-python-config.py
-%endif
diff --git a/rtems/config/tools/rtems-gdb-7.7.1-1.cfg b/rtems/config/tools/rtems-gdb-7.7.1-1.cfg
index 2e49f38..0000000
--- a/rtems/config/tools/rtems-gdb-7.7.1-1.cfg
+++ /dev/null
@@ -1,26 +0,0 @@
-# GDB 7.7.1.
-%define gdb_version 7.7.1
-# Clean up the sim-arange inline code so it builds.
-%patch add gdb %{rtems_gdb_patches}/gdb-sim-arange-inline.diff
-%hash  md5 gdb-sim-arange-inline.diff 11bb2936ea29afeaa023077191fd4705
-%patch add gdb %{rtems_gdb_patches}/gdb-sim-cgen-inline.diff
-%hash  md5 gdb-sim-cgen-inline.diff e6f7d6d7295cdba99f51aab514ea9778
- %hash  md5 patch-gdb-python-python-config.py c0260fcca4c1a5509635049c0094eee3
-%endif
diff --git a/rtems/config/tools/rtems-gdb-7.8.2-1.cfg b/rtems/config/tools/rtems-gdb-7.8.2-1.cfg
index 9a5f3cb..0000000
--- a/rtems/config/tools/rtems-gdb-7.8.2-1.cfg
+++ /dev/null
@@ -1,29 +0,0 @@
-# GDB 7.8.2
-%define gdb_version 7.8.2
-%define gdb_src_ext xz
-%hash md5 gdb-%{gdb_version}.tar.xz a80cf252ed2e775d4e4533341bbf2459
-%endif
diff --git a/rtems/config/tools/rtems-kernel-4.10.2.cfg b/rtems/config/tools/rtems-kernel-4.10.2.cfg
index 63bd400..0000000
--- a/rtems/config/tools/rtems-kernel-4.10.2.cfg
+++ /dev/null
@@ -1,16 +0,0 @@
-# RTEMS 4.10.2
-%define rtems_kernel_version     4.10.2
-%define rtems_kernel_compression bz2
-%hash md5 rtems-%{rtems_kernel_version}.tar.bz2 158566d0f1330d4eaba5a60e757d3dd0
-# The RTEMS build instructions. We use 4.xx Release 1.
-%include tools/rtems-kernel-4-1.cfg
diff --git a/rtems/config/tools/rtems-kernel-4.9.6-1.cfg b/rtems/config/tools/rtems-kernel-4.9.6-1.cfg
index eb70459..0000000
--- a/rtems/config/tools/rtems-kernel-4.9.6-1.cfg
+++ /dev/null
@@ -1,14 +0,0 @@
-# RTEMS 4.9.6
-%define rtems_kernel_version     4.9.6
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg b/rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg
index 3c0bed5..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-7.5.1-1.cfg
+++ /dev/null
@@ -1,11 +0,0 @@
-# MIPS STX39 GDB 7.5.1.
-%undefine _target
-%define _target mipstx39-rtems%{rtems_version}
-# The gdb build instructions for RTEMS 7.5.1.
-%include tools/rtems-gdb-7.5.1-1.cfg
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg b/rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
index 836c0bb..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-7.6-1.cfg
+++ /dev/null
@@ -1,11 +0,0 @@
-# MIPS STX39 GDB 7.6.
-%undefine _target
-# The gdb build instructions for RTEMS 7.6.
-%include tools/rtems-gdb-7.6-1.cfg
diff --git a/rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg b/rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
index 0e65b5e..0000000
--- a/rtems/config/tools/rtems-mipstx39-gdb-7.7-1.cfg
+++ /dev/null
@@ -1,11 +0,0 @@
-# MIPS STX39 GDB 7.7.
-%undefine _target
-# The gdb build instructions for RTEMS 7.7.
-%include tools/rtems-gdb-7.7-1.cfg
diff --git a/rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg b/rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg
index 92f9520..0000000
--- a/rtems/config/tools/rtems-nios2-binutils-2.20-1.cfg
+++ /dev/null
@@ -1,26 +0,0 @@
-# RTEMS NIOS2 Binutils 2.21.
-%disable select
-%define host_force_32bit
-# Source
-%source set binutils http://ftp.rtems.org/pub/rtems/people/chrisj/nios/nios2-binutils-2.20.tar.bz2
-%hash   md5 nios2-binutils-2.20.tar.bz2 42ce11b421a1d35fc7b17ee051ccf92a
-%patch  add binutils %{rtems_binutils_patches}/nios2/nios2-binutils-2.20-rtems-20110703.diff
-%hash   md5 nios2-binutils-2.20-rtems-20110703.diff edaa78cdf7b87866c976232ccb1704ac
diff --git a/rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg b/rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg
index 28342cd..0000000
--- a/rtems/config/tools/rtems-nios2-gcc-4.1-newlib-1.19.0-1.cfg
+++ /dev/null
@@ -1,179 +0,0 @@
-# RTEMS NIOS2 GCC 4.1., Newlib 1.19.0
-# This configuration has special support for the NIOS2.
-%disable select
-%define gcc_version    4.1
-%define newlib_version 1.19.0
-%define newlib_cfg     normalc
-%define enable_cxx   1
-%patch add gcc %{rtems_gcc_patches}/nios2/nios2-gcc-4.1-rtems-20110818.diff
-%patch add newlib %{rtems_newlib_patches}/nios2/nios2-newlib-1.19.0-rtems-20110720.diff
-Name:      %{_target}-gcc-%{gcc_version}-newlib-%{newlib_version}-%{release}
-Summary:   GCC v%{gcc_version} and Newlib v%{newlib_version} for target %{_target} on host %{_host}
-Version:   %{gcc_version}
-Release:   %{release}
-URL: 	   http://gcc.gnu.org/
-BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
-# Supports Candian Cross (Cxc).
-%define allow_cxc
-# Source
-# GCC core and G++
-%source set gcc http://ftp.rtems.org/pub/rtems/people/chrisj/nios/nios2-gcc-4.1.tar.bz2
-%hash   md5 nios2-gcc-4.1.tar.bz2 717e5a25fda68d96d09353bcfa149cff
-# Newlib
-%source set newlib ftp://sourceware.org/pub/newlib/newlib-%{newlib_version}.tar.gz
-%hash   md5 newlib-%{newlib_version}.tar.gz 0966e19f03217db9e9076894b47e6601
-# The GCC library directory
-%global _gcclibdir %{_prefix}/lib
-# Prepare the source code.
-%prep
-  # save the build top directory and cd back to it rather than
-  # using 'cd ..' because some shells change $PWD to a symlink's
-  # target location and 'cd ..' fails.
-  build_top=$(pwd)
-  # gcc
-  source_dir_gcc="gcc-%{gcc_version}"
-  %source setup gcc -q -b -n gcc-%{gcc_version}
-  %patch setup gcc -p1
-  cd ${build_top}
-  # newlib
-  source_dir_newlib="newlib-%{newlib_version}"
-  %source setup newlib -q -b -n newlib-%{newlib_version}
-  %patch setup newlib -p1
-  cd ${build_top}
-  # Link newlib into the gcc source tree
-  %{__rmfile} ${source_dir_gcc}/newlib
-  %{__ln_s} $PWD/${source_dir_newlib}/newlib ${source_dir_gcc}/newlib
-  echo "%{gcc_version_message}" > gcc-%{gcc_version}/gcc/DEV-PHASE
-  # Fix timestamps
-  cd ${source_dir_gcc}
-  contrib/gcc_update --touch
-  cd ${build_top}
-%build
-  %{build_directory}
-  mkdir -p ${build_dir}
-  cd ${build_dir}
-  languages="c"
-%if %{enable_cxx}
-  languages="$languages,c++"
-%endif
-  %{host_build_flags}
-  ../${source_dir_gcc}/configure \
-    --prefix=%{_prefix} \
-    --bindir=%{_bindir} \
-    --exec_prefix=%{_exec_prefix} \
-    --includedir=%{_includedir} \
-    --libdir=%{_gcclibdir} \
-    --libexecdir=%{_libexecdir} \
-    --mandir=%{_mandir} \
-    --infodir=%{_infodir} \
-    --datadir=%{_datadir} \
-    --build=%_build --host=%_host \
-    --target=%{_target} \
-    --disable-libstdcxx-pch \
-    --with-gnu-as --with-gnu-ld --verbose \
-    --with-newlib \
-    --with-system-zlib \
-    --disable-nls --without-included-gettext \
-    --disable-win32-registry \
-    --enable-version-specific-runtime-libs \
-    %{?with_lto:--enable-lto}%{!?with_lto:--disable-lto} \
-    %{?with_threads:--enable-threads}%{!?with_threads:--disable-threads} \
-    %{?with_plugin:--enable-plugin}%{!?with_plugin:--disable-plugin} \
-    %{?enable_obsolete:--enable-obsolete} \
-    --enable-languages="$languages"
-  if test "%_host" != "%_build" ; then
-    # Bug in gcc-3.2.1:
-    # Somehow, gcc doesn't get syslimits.h right for Cdn-Xs
-    mkdir -p gcc/include
-    cp ../${source_dir_gcc}/gcc/gsyslimits.h gcc/include/syslimits.h
-  fi
-  # jobs > 1 is broken with this version of gcc
-  %{__make} -w N2GNU_BUILD_NEWLIB="%{newlib_cfg}" all
-  cd ..
-%install
-  %{__rmdir} $SB_BUILD_ROOT
-  cd ${build_dir}
-  # Filter the doc stuff we do not want so it builds without error on
-  # hosts that do not have tex to pdf converters installed.
-  for m in $(find . -name Makefile)
-  do
-    mv $m $m.orig
-    echo "Doc filteirng $m.orig -> $m"
-    cat $m.orig | sed -e 's/ pdf / /g' \
-                      -e 's/ pdf$/ /g' \
-                      -e 's/ install-pdf / /g' \
-                      -e 's/ install-pdf$/ /g' \
-                      -e 's/ install-html / /g' \
-                      -e 's/ install-html$/ /g' \
-                      -e 's/ html / /g' \
-                      -e 's/ html$/ /g' > $m
-  done
-  %{__make} -w DESTDIR=$SB_BUILD_ROOT N2GNU_BUILD_NEWLIB="%{newlib_cfg}" install
-  cd ..
-  # libiberty doesn't honor --libdir, but always installs to a
-  # magically guessed _libdir
-  %{__rmfile} ${SB_BUILD_ROOT}%{_libdir}/libiberty.a
-  # We use the version from binutils
-  %{__rmfile} $SB_BUILD_ROOT%{_bindir}/%{_target}-c++filt%{_exeext}
-  # We don't ship info/dir
-  %{__rmfile} $SB_BUILD_ROOT%{_infodir}/dir
-  # Don't want libffi's man-pages
-  %{__rmfile} $SB_BUILD_ROOT%{_mandir}/man3/*ffi*
-  # Clean the symlinks away incase the source is a repo
diff --git a/rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg b/rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg
index 1af43ba..0000000
--- a/rtems/config/tools/rtems-nios2-gdb-7.0-1.cfg
+++ /dev/null
@@ -1,19 +0,0 @@
-# GDB 7.0.
-%disable select
-%define gdb_version 7.0
-%define without_python
-%source set gdb http://ftp.rtems.org/pub/rtems/people/chrisj/nios/nios2-gdb-7.0.tar.bz2
diff --git a/rtems/config/tools/rtems-tools-git-1.cfg b/rtems/config/tools/rtems-tools-git-1.cfg
index 3573c73..0000000
--- a/rtems/config/tools/rtems-tools-git-1.cfg
+++ /dev/null
@@ -1,53 +0,0 @@
-# RTEMS Tools GIT Version 1.
-# This configuration file configure's, builds and install's RTEMS Tools.
-Name:      rtems-tools-%{rtems_tools_version}-%{release}
-Summary:   RTEMS Tools %{rtems_tools_version} for host %{_host}
-Version:   %{rtems_tools_version}
-URL: 	   http://www.rtems.org/
-%prep
-  build_top=$(pwd)
-  source_dir_rtems_tools="%{name}"
-  %source setup rtems-tools -q -D -n %{name}
-  %patch setup rtems-tools -p1
-  cd ${build_top}
-%build
-  build_top=$(pwd)
-  # Provide the host for a Cxc build.
-  if test "%{_build}" != "%{_host}" ; then
-    RT_HOST="-host=%{_host}"
-  else
-    RT_HOST=
-  fi
-  cd ${source_dir_rtems_tools}
-  ./waf configure ${RT_HOST} --prefix=%{_prefix}
-  ./waf
-  cd ${build_top}
-%install
-  build_top=$(pwd)
-  ./waf --destdir=$SB_BUILD_ROOT install
-  cd ${build_top}
2.14.1
