[PATCH] kernel: Do not build the RTEMS kernel by default when released.
Thu Jan 18 07:13:22 UTC 2018
Close #3275
 rtems/config/tools/rtems-kernel-4-1.cfg | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/rtems/config/tools/rtems-kernel-4-1.cfg b/rtems/config/tools/rtems-kernel-4-1.cfg
index a57ec61..35386b8 100644
--- a/rtems/config/tools/rtems-kernel-4-1.cfg
+++ b/rtems/config/tools/rtems-kernel-4-1.cfg
@@ -24,7 +24,7 @@ BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
 # Build if the RSB is released or optionally enable/disable building the RTEMS
 # kernel via the command line.
-%if %{rsb_released} || %{defined with_rtems}
+%if %{defined with_rtems}
  %define rtems_kernel_build 1
 %else
  %define rtems_kernel_build 0
2.14.1
