no-preinstall: Ready for final review
Thu Jan 18 16:19:59 UTC 2018
On Thu, Jan 18, 2018 at 10:34 AM, Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Jan 18, 2018 at 10:20 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> I fixed the cpuopts.h problem two minutes ago.
> Thanks.
> I just noticed that actually when I run tester on the installed tree I
> get a lot of timeouts. I'm not sure if this is my host problem.
I have a new problem:
build/config.log:err:
/home/gedare/development/rtems/5/lib/gcc/sparc-rtems5/7.2.0/../../../../sparc-rtems5/bin/ld:
cannot open linker script file linkcmds.base: No such file or
directory
That file does not appear to leave the source tree.
gedare:~/work/rtems/builds/b-erc32-5$ find . -name linkcmds.base
gedare::~/work/rtems/builds/b-erc32-5$ find . -name linkcmds
./sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/linkcmds
>> ----- Gedare Bloom <gedare at rtems.org> schrieb:
>>> On Wed, Jan 17, 2018 at 2:24 AM, Sebastian Huber
>>> > Hello,
>>> > the no-preinstall branch is now in a good shape.
>>> > https://git.rtems.org/sebh/rtems.git/log/?h=no-preinstall
>>> > Please review this work. The next step would be to squash all commits on
>>> > this branch, write a proper commit message and push it to the master.
>>> Hello Sebastian,
>>> I checked it out, built erc32, ran erc32 from the build, installed the
>>> bsp, and ran it again fine using rtems-tools/tester.
>>> However, when I try to waf-configure examples-v2, I get a problem that
>>> rtems/score/cpuopts.h is not found. When I look in my installed tree,
>>> I do not find the file:
>>> $ find /opt/rtems-5 -name cpuopts.h
>>> $ find /opt/rtems-5 -name include
>>> ./sparc-rtems5/erc32/lib/include
>>> I do see it in my build tree:
>>> ~/work/rtems/builds/b-erc32-5$ find . -name cpuopts.h
>>> ./sparc-rtems5/c/erc32/include/rtems/score/cpuopts.h
>>> Relatedly, I don't see the bspopts.h file in the installed tree
>>> either. I do see it in the build tree, in a different location from
>>> the rest of the includes:
>>> ~/work/rtems/builds/b-erc32-5$ find . -name bspopts.h
>>> ./sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/include/bspopts.h
>>> I also took a quick look through the commits, and I have a small nit.
>>> Might I suggest "headers.sh" and "headers.am" instead of "header.sh"
>>> and "header.am"?
>>> -Gedare
>>> > Sebastian Huber, embedded brains GmbH
>>> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> > Phone   : +49 89 189 47 41-16
>>> > Fax     : +49 89 189 47 41-09
>>> > E-Mail  : sebastian.huber at embedded-brains.de
>>> > PGP     : Public key available on request.
>>> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
