no-preinstall: Ready for final review
Thu Jan 18 16:34:49 UTC 2018
After installation. The BSP builds fine
On Thu, Jan 18, 2018 at 11:33 AM, Sebastian Huber
> Is this after installation or during the BSP build?
> ----- Am 18. Jan 2018 um 17:19 schrieb Gedare Bloom gedare at rtems.org:
>> On Thu, Jan 18, 2018 at 10:34 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Thu, Jan 18, 2018 at 10:20 AM, Sebastian Huber
>>>> I fixed the cpuopts.h problem two minutes ago.
>>> Thanks.
>>> I just noticed that actually when I run tester on the installed tree I
>>> get a lot of timeouts. I'm not sure if this is my host problem.
>> I have a new problem:
>> build/config.log:err:
>> /home/gedare/development/rtems/5/lib/gcc/sparc-rtems5/7.2.0/../../../../sparc-rtems5/bin/ld:
>> cannot open linker script file linkcmds.base: No such file or
>> directory
>> That file does not appear to leave the source tree.
>> gedare:~/work/rtems/builds/b-erc32-5$ find . -name linkcmds.base
>> gedare::~/work/rtems/builds/b-erc32-5$ find . -name linkcmds
>> ./sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/linkcmds
>>>> ----- Gedare Bloom <gedare at rtems.org> schrieb:
>>>>> On Wed, Jan 17, 2018 at 2:24 AM, Sebastian Huber
>>>>> > Hello,
>>>>> > the no-preinstall branch is now in a good shape.
>>>>> > https://git.rtems.org/sebh/rtems.git/log/?h=no-preinstall
>>>>> > Please review this work. The next step would be to squash all commits on
>>>>> > this branch, write a proper commit message and push it to the master.
>>>>> Hello Sebastian,
>>>>> I checked it out, built erc32, ran erc32 from the build, installed the
>>>>> bsp, and ran it again fine using rtems-tools/tester.
>>>>> However, when I try to waf-configure examples-v2, I get a problem that
>>>>> rtems/score/cpuopts.h is not found. When I look in my installed tree,
>>>>> I do not find the file:
>>>>> $ find /opt/rtems-5 -name cpuopts.h
>>>>> $ find /opt/rtems-5 -name include
>>>>> ./sparc-rtems5/erc32/lib/include
>>>>> I do see it in my build tree:
>>>>> ~/work/rtems/builds/b-erc32-5$ find . -name cpuopts.h
>>>>> ./sparc-rtems5/c/erc32/include/rtems/score/cpuopts.h
>>>>> Relatedly, I don't see the bspopts.h file in the installed tree
>>>>> either. I do see it in the build tree, in a different location from
>>>>> the rest of the includes:
>>>>> ~/work/rtems/builds/b-erc32-5$ find . -name bspopts.h
>>>>> ./sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/include/bspopts.h
>>>>> I also took a quick look through the commits, and I have a small nit.
>>>>> Might I suggest "headers.sh" and "headers.am" instead of "header.sh"
>>>>> and "header.am"?
>>>>> -Gedare
>>>>> > Sebastian Huber, embedded brains GmbH
>>>>> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>> > Phone   : +49 89 189 47 41-16
>>>>> > Fax     : +49 89 189 47 41-09
>>>>> > E-Mail  : sebastian.huber at embedded-brains.de
>>>>> > PGP     : Public key available on request.
>>>>> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>>> > _______________________________________________
>>>>> > devel mailing list
>>>>> > devel at rtems.org
>>>>> > http://lists.rtems.org/mailman/listinfo/devel
