TEST BUILD strings
Sebastian Huber
Fri Jan 19 09:25:57 UTC 2018
Hello,
the new test header is really great, e.g.
*** BEGIN OF TEST BLOCK 8 ***
*** TEST VERSION: 5.0.0.32d50688c655fbdc4cedcf9c06972b48e1ee498f
*** TEST STATE: EXPECTED-PASS
*** TEST BUILD: legacy-net
*** TEST TOOLS: 7.2.0 20170814 (RTEMS 5, RSB
a293ddc992ab2cf757b6dfea58ef3697494b5e95, Newlib 2.5.0.20170922)
The TEST BUILD string is determined by:
#if RTEMS_POSIX
#define TEST_BUILD_DEFAULT ""
#define TEST_BUILD_POSIX "posix "
#else
#endif
#if RTEMS_SMP
#define TEST_BUILD_SMP "smp "
#else
#endif
#if RTEMS_MULTIPROCESSING
#define TEST_BUILD_MP "mp "
#else
#endif
#if RTEMS_PARAVIRT
#define TEST_BUILD_PARAVIRT "paravirt "
#else
#endif
#if RTEMS_NETWORKING
#define TEST_BUILD_NETWORKING "legacy-net "
#else
#endif
#if RTEMS_DEBUG
#define TEST_BUILD_DEBUG "debug "
#else
#endif
#if RTEMS_PROFILING
#define TEST_BUILD_PROFILING "profiling "
#else
#endif
#ifndef TEST_BUILD_DEFAULT
#define TEST_BUILD_DEFAULT "default"
#endif
I would like to change the names to use the name of the define, e.g.
debug -> RTEMS_DEBUG
legacy-net -> RTEMS_NETWORKING
etc.
This makes it easier to get the connection from the test output to the
RTEMS build options.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
