[PATCH 09/20] linux/of_address.h: of_address_to_resource()
Fri Jan 19 13:53:59 UTC 2018
Translate address in of_address_to_resource().
 linux/drivers/net/ethernet/freescale/fman/fman.c | 28 +++++++-----------------
 linux/drivers/soc/fsl/qbman/qman_ccsr.c          |  3 ---
 rtemsbsd/powerpc/include/linux/device.h          |  2 +-
 rtemsbsd/sys/powerpc/compat.c                    | 22 ++++++-------------
 4 files changed, 16 insertions(+), 39 deletions(-)
diff --git a/linux/drivers/net/ethernet/freescale/fman/fman.c b/linux/drivers/net/ethernet/freescale/fman/fman.c
index 0b7230a9b..4c8d85350 100644
--- a/linux/drivers/net/ethernet/freescale/fman/fman.c
+++ b/linux/drivers/net/ethernet/freescale/fman/fman.c
@@ -2788,6 +2788,8 @@ static struct fman *read_dts_node(struct platform_device *of_dev)
 #else /* __rtems__ */
 	const char *fdt = bsp_fdt_get();
 	struct device_node *fm_node;
+	struct device_node muram_node_storage;
+	struct device_node *muram_node;
 #endif /* __rtems__ */
 	u32 val, range[2];
 	int err, irq;
@@ -2891,6 +2893,12 @@ static struct fman *read_dts_node(struct platform_device *of_dev)
 			__func__);
 		goto fman_node_put;
+#else /* __rtems__ */
+	memset(&muram_node_storage, 0, sizeof(muram_node_storage));
+	muram_node = &muram_node_storage;
+	muram_node->offset = fdt_node_offset_by_compatible(fdt,
+	    fm_node->offset, "fsl,fman-muram");
+#endif /* __rtems__ */
 	err = of_address_to_resource(muram_node, 0,
 				     &fman->dts_params.muram_res);
@@ -2900,27 +2908,7 @@ static struct fman *read_dts_node(struct platform_device *of_dev)
 			__func__, err);
 		goto fman_node_put;
-#else /* __rtems__ */
-		int node = fdt_node_offset_by_compatible(fdt,
-		    fm_node->offset, "fsl,fman-muram");
-		struct device_node muram_node = {
-			.offset = node
-		struct resource res;
-		err = of_address_to_resource(&muram_node, 0, &res);
-		if (err != 0) {
-			pr_err("could not find MURAM node\n");
-			goto fman_node_put;
-		fman->dts_params.muram_res.start = phys_base_addr + res.start;
-		fman->dts_params.muram_res.end = phys_base_addr + res.end - 1;
-#endif /* __rtems__ */
-#ifndef __rtems__
 	of_node_put(muram_node);
 	err = devm_request_irq(&of_dev->dev, irq, fman_irq, 0, "fman", fman);
 	if (err < 0) {
diff --git a/linux/drivers/soc/fsl/qbman/qman_ccsr.c b/linux/drivers/soc/fsl/qbman/qman_ccsr.c
index b26bfdd6b..817bb5041 100644
--- a/linux/drivers/soc/fsl/qbman/qman_ccsr.c
+++ b/linux/drivers/soc/fsl/qbman/qman_ccsr.c
@@ -872,9 +872,6 @@ qman_sysinit(void)
 	memset(&dev, 0, sizeof(dev));
 	dev.pdev.dev.of_node = &dev.of_node;
-#if QORIQ_CHIP_IS_T_VARIANT(QORIQ_CHIP_VARIANT)
-	dev.pdev.dev.base = (uintptr_t)&qoriq;
-#endif
 	dev.of_node.offset = node;
 	dev.of_node.full_name = name;
diff --git a/rtemsbsd/powerpc/include/linux/device.h b/rtemsbsd/powerpc/include/linux/device.h
index 4a6bc301e..f4c344a17 100644
--- a/rtemsbsd/powerpc/include/linux/device.h
+++ b/rtemsbsd/powerpc/include/linux/device.h
@@ -79,7 +79,7 @@ static inline void __iomem *
 devm_ioremap(struct device *dev, resource_size_t offset, resource_size_t size)
-	return (void __iomem *)(dev->base + (uintptr_t)offset);
+	return (void __iomem *)(uintptr_t)offset;
 #define	devm_alloc_percpu(dev, type) \
diff --git a/rtemsbsd/sys/powerpc/compat.c b/rtemsbsd/sys/powerpc/compat.c
index 8113eb207..45f06e5d1 100644
--- a/rtemsbsd/sys/powerpc/compat.c
+++ b/rtemsbsd/sys/powerpc/compat.c
@@ -329,6 +329,7 @@ of_address_to_resource(struct device_node *dn, int index,
     struct resource *res)
 	const void *fdt = bsp_fdt_get();
+	int node;
 	int ac;
 	int sc;
 	int len;
@@ -336,16 +337,17 @@ of_address_to_resource(struct device_node *dn, int index,
 	int i;
 	memset(res, 0, sizeof(*res));
+	node = dn->offset;
-	ac = get_address_cells(fdt, dn->offset);
+	ac = get_address_cells(fdt, node);
 	if (ac < 0)
 		return (-EINVAL);
-	sc = get_size_cells(fdt, dn->offset);
+	sc = get_size_cells(fdt, node);
 	if (sc < 0)
 		return (-EINVAL);
-	p = fdt_getprop(fdt, dn->offset, "reg", &len);
+	p = fdt_getprop(fdt, node, "reg", &len);
 	if (p == NULL)
 		return (-EINVAL);
@@ -354,19 +356,9 @@ of_address_to_resource(struct device_node *dn, int index,
 	if (i + ac + sc > len)
 		return (-EINVAL);
-	while (ac > 0) {
-		res->start = (res->start << 32) | fdt32_to_cpu(p[i]);
-		++i;
-		--ac;
-	while (sc > 0) {
-		res->end = (res->end << 32) | fdt32_to_cpu(p[i]);
-		++i;
-		--sc;
+	res->start = translate_address(fdt, node, ac, sc, &p[i]);
+	res->end = of_read_number(&p[i + ac], sc);
 	res->end += res->start;
 	return (0);
2.12.3
