[PATCH 20/20] sdk_dpaa: Add MAC-less driver test program
Fri Jan 19 13:54:10 UTC 2018
 libbsd.py                  |   1 +
 libbsd_waf.py              |  10 ++
 testsuite/dpaa/test_main.c | 227 +++++++++++++++++++++++++++++++++++++++++++++
 3 files changed, 238 insertions(+)
 create mode 100644 testsuite/dpaa/test_main.c
diff --git a/libbsd.py b/libbsd.py
index 7b0b5537b..dd2fc51c1 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -4370,6 +4370,7 @@ def in_cksum(mm):
 def tests(mm):
     mod = builder.Module('tests')
+    mod.addTest(mm.generator['test']('dpaa', ['test_main']))
     mod.addTest(mm.generator['test']('nfs01', ['test_main'], netTest = True))
     mod.addTest(mm.generator['test']('foobarclient', ['test_main'],
                                      runTest = False, netTest = True))
diff --git a/libbsd_waf.py b/libbsd_waf.py
index 4ea3e8c86..1777aa2cf 100644
--- a/libbsd_waf.py
+++ b/libbsd_waf.py
@@ -2634,6 +2634,16 @@ def build(bld):
                 lib = ["m", "z"],
                 install_path = None)
+    test_dpaa = ['testsuite/dpaa/test_main.c']
+    bld.program(target = "dpaa.exe",
+                features = "cprogram",
+                cflags = cflags,
+                includes = includes,
+                source = test_dpaa,
+                use = ["bsd"],
+                lib = ["m", "z"],
+                install_path = None)
     test_evdev01 = ['testsuite/evdev01/init.c']
     bld.program(target = "evdev01.exe",
diff --git a/testsuite/dpaa/test_main.c b/testsuite/dpaa/test_main.c
new file mode 100644
index 000000000..8d515f427
--- /dev/null
+++ b/testsuite/dpaa/test_main.c
@@ -0,0 +1,227 @@
+ * Copyright (c) 2010, 2018 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/param.h>
+#include <assert.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <sysexits.h>
+#include <machine/rtems-bsd-commands.h>
+#include <rtems/console.h>
+#include <rtems/ftpd.h>
+#include <rtems/media.h>
+#include <rtems/shell.h>
+#include <rtems/telnetd.h>
+#define TEST_NAME "LIBBSD DPAA 1"
+struct rtems_ftpd_configuration rtems_ftpd_configuration = {
+	/* FTPD task priority */
+	.priority = 100,
+	/* Maximum buffersize for hooks */
+	.max_hook_filesize = 0,
+	/* Well-known port */
+	.port = 21,
+	/* List of hooks */
+	.hooks = NULL,
+	/* Root for FTPD or NULL for "/" */
+	.root = NULL,
+	/* Max. connections depending on processor count */
+	.tasks_count = 4,
+	/* Idle timeout in seconds  or 0 for no (infinite) timeout */
+	.idle = 5 * 60,
+	/* Access: 0 - r/w, 1 - read-only, 2 - write-only, 3 - browse-only */
+	.access = 0
+static void
+telnet_shell(char *name, void *arg)
+	rtems_shell_env_t env;
+	memset(&env, 0, sizeof(env));
+	env.devname = name;
+	env.taskname = "TLNT";
+	env.login_check = NULL;
+	env.forever = false;
+	rtems_shell_main_loop(&env);
+rtems_telnetd_config_table rtems_telnetd_config = {
+	.command = telnet_shell,
+	.arg = NULL,
+	.priority = 0,
+	.stack_size = 0,
+	.login_check = NULL,
+	.keep_stdio = false
+static void
+ifconfig(char *ifname, char *self_ip, char *netmask)
+	int exit_code;
+	char *ifcfg[] = {
+		"ifconfig",
+		ifname,
+		"inet",
+		self_ip,
+		"netmask",
+		netmask,
+		NULL
+	exit_code = rtems_bsd_command_ifconfig(RTEMS_BSD_ARGC(ifcfg), ifcfg);
+	assert(exit_code == EX_OK);
+static void
+route(char *ifname, char *gateway_ip)
+	int exit_code;
+	char *dflt_route[] = {
+		"route",
+		"add",
+		"-host",
+		gateway_ip,
+		"-iface",
+		ifname,
+		NULL
+	char *dflt_route2[] = {
+		"route",
+		"add",
+		"default",
+		gateway_ip,
+		NULL
+	exit_code = rtems_bsd_command_route(RTEMS_BSD_ARGC(dflt_route), dflt_route);
+	assert(exit_code == EXIT_SUCCESS);
+	exit_code = rtems_bsd_command_route(RTEMS_BSD_ARGC(dflt_route2), dflt_route2);
+#define MAC_LESS_IFACE "ml0"
+static void
+test_main(void)
+	rtems_status_code sc;
+	int rv;
+	ifconfig(MAC_LESS_IFACE, "10.1.1.2", "255.255.255.0");
+	route(MAC_LESS_IFACE, "10.1.1.1");
+	rv = rtems_initialize_ftpd();
+	assert(rv == 0);
+	sc = rtems_telnetd_initialize();
+	assert(sc == RTEMS_SUCCESSFUL);
+	sc = rtems_shell_init("SHLL", 16 * 1024, 1, CONSOLE_DEVICE_NAME,
+	    false, true, NULL);
+	exit(0);
+#define DEFAULT_EARLY_INITIALIZATION
+static void
+early_initialization(void)
+	int i;
+	for (i = 0; i < 5; ++i) {
+		sleep(1);
+		printf("start %i\n", i);
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_MAXIMUM_DRIVERS 32
+#define DEFAULT_NETWORK_NO_INTERFACE_0
+#include <rtems/bsd/test/default-network-init.h>
+#define CONFIGURE_SHELL_COMMANDS_INIT
+#include <bsp/irq-info.h>
+#include <rtems/netcmds-config.h>
+#define CONFIGURE_SHELL_USER_COMMANDS \
+  &bsp_interrupt_shell_command, \
+  &rtems_shell_ARP_Command, \
+  &rtems_shell_HOSTNAME_Command, \
+  &rtems_shell_PING_Command, \
+  &rtems_shell_ROUTE_Command, \
+  &rtems_shell_NETSTAT_Command, \
+  &rtems_shell_SYSCTL_Command, \
+  &rtems_shell_IFCONFIG_Command, \
+  &rtems_shell_VMSTAT_Command
+#define CONFIGURE_SHELL_COMMAND_CPUINFO
+#define CONFIGURE_SHELL_COMMAND_CPUUSE
+#define CONFIGURE_SHELL_COMMAND_PERIODUSE
+#define CONFIGURE_SHELL_COMMAND_STACKUSE
+#define CONFIGURE_SHELL_COMMAND_PWD
+#define CONFIGURE_SHELL_COMMAND_LS
+#define CONFIGURE_SHELL_COMMAND_LN
+#define CONFIGURE_SHELL_COMMAND_LSOF
+#define CONFIGURE_SHELL_COMMAND_CHDIR
+#define CONFIGURE_SHELL_COMMAND_CD
+#define CONFIGURE_SHELL_COMMAND_MKDIR
+#define CONFIGURE_SHELL_COMMAND_RMDIR
+#define CONFIGURE_SHELL_COMMAND_CAT
+#define CONFIGURE_SHELL_COMMAND_MV
+#define CONFIGURE_SHELL_COMMAND_MALLOC_INFO
+#include <rtems/shellconfig.h>
2.12.3
