[PATCH 16/20] dpaa: QMan portal only initialization
Fri Jan 19 13:54:06 UTC 2018
 linux/drivers/soc/fsl/qbman/qman_ccsr.c   | 66 ++++++++++++++++++++---
 linux/drivers/soc/fsl/qbman/qman_portal.c | 89 ++++++++++++++++++++-----------
 2 files changed, 116 insertions(+), 39 deletions(-)
diff --git a/linux/drivers/soc/fsl/qbman/qman_ccsr.c b/linux/drivers/soc/fsl/qbman/qman_ccsr.c
index 817bb5041..5377c30f0 100644
--- a/linux/drivers/soc/fsl/qbman/qman_ccsr.c
+++ b/linux/drivers/soc/fsl/qbman/qman_ccsr.c
@@ -49,6 +49,7 @@ EXPORT_SYMBOL(qm_channel_pool1);
 u16 qm_channel_caam = QMAN_CHANNEL_CAAM;
 EXPORT_SYMBOL(qm_channel_caam);
+#ifndef QORIQ_IS_HYPERVISOR_GUEST
 /* Register offsets */
 #define REG_QCSP_LIO_CFG(n)	(0x0000 + ((n) * 0x10))
 #define REG_QCSP_IO_CFG(n)	(0x0004 + ((n) * 0x10))
@@ -283,9 +284,11 @@ static const struct qman_error_info_mdata error_mdata[] = {
 /* Pointer to the start of the QMan's CCSR space */
 static u32 __iomem *qm_ccsr_start;
+#endif /* !QORIQ_IS_HYPERVISOR_GUEST */
 /* A SDQCR mask comprising all the available/visible pool channels */
 static u32 qm_pools_sdqcr;
 static inline u32 qm_ccsr_in(u32 offset)
 	return ioread32be(qm_ccsr_start + offset/4);
@@ -295,12 +298,14 @@ static inline void qm_ccsr_out(u32 offset, u32 val)
 	iowrite32be(val, qm_ccsr_start + offset/4);
 u32 qm_get_pools_sdqcr(void)
 	return qm_pools_sdqcr;
 enum qm_dc_portal {
 	qm_dc_portal_fman0 = 0,
 	qm_dc_portal_fman1 = 1
@@ -661,6 +666,20 @@ void qman_set_sdest(u16 channel, unsigned int cpu_idx)
 		qm_ccsr_out(REG_QCSP_IO_CFG(idx), after);
+#else /* QORIQ_IS_HYPERVISOR_GUEST */
+static unsigned int qm_get_fqid_maxcnt(void)
+	return 1U << 16;
+void qman_liodn_fixup(u16 channel)
+void qman_set_sdest(u16 channel, unsigned int cpu_idx)
 static int qman_resource_init(struct device *dev)
@@ -711,6 +730,7 @@ static int qman_resource_init(struct device *dev)
 	return 0;
 static int fsl_qman_probe(struct platform_device *pdev)
 	struct device *dev = &pdev->dev;
@@ -829,6 +849,7 @@ static int fsl_qman_probe(struct platform_device *pdev)
 	return 0;
 #ifndef __rtems__
 static const struct of_device_id fsl_qman_ids[] = {
@@ -857,27 +878,56 @@ static void
 qman_sysinit(void)
 	const char *fdt = bsp_fdt_get();
+	const char *name;
+	int node;
+	int ret;
 	struct {
 		struct platform_device pdev;
 		struct device_node of_node;
 	} dev;
-	const char *name;
-	int node;
-	int ret;
+#endif
 	name = "fsl,qman";
-	node = fdt_node_offset_by_compatible(fdt, 0, name);
-	if (node < 0)
-		panic("qman: no qman in FDT");
+	node = fdt_node_offset_by_compatible(fdt, -1, name);
+#ifdef QORIQ_IS_HYPERVISOR_GUEST
+	BSD_ASSERT(node < 0);
+	BSD_ASSERT(fdt_node_offset_by_compatible(fdt, -1,
+	    "fsl,qman-portal-3.1.2") >= 0);
+	qman_ip_rev = QMAN_REV31;
+	qm_channel_pool1 = QMAN_CHANNEL_POOL1_REV3;
+	qm_channel_caam = QMAN_CHANNEL_CAAM_REV3;
+	qm_fqalloc = devm_gen_pool_create(NULL, 0, -1, "qman-fqalloc");
+	BSD_ASSERT(!IS_ERR(qm_fqalloc));
+	qm_qpalloc = devm_gen_pool_create(NULL, 0, -1, "qman-qpalloc");
+	BSD_ASSERT(!IS_ERR(qm_qpalloc));
+	qm_cgralloc = devm_gen_pool_create(NULL, 0, -1, "qman-cgralloc");
+	BSD_ASSERT(!IS_ERR(qm_cgralloc));
+	ret = qman_resource_init(NULL);
+	BSD_ASSERT(ret == 0);
+	ret = qman_alloc_fq_table(qm_get_fqid_maxcnt());
+	ret = qman_wq_alloc();
+#else /* !QORIQ_IS_HYPERVISOR_GUEST */
+	BSD_ASSERT(node >= 0);
 	memset(&dev, 0, sizeof(dev));
 	dev.pdev.dev.of_node = &dev.of_node;
 	dev.of_node.offset = node;
 	dev.of_node.full_name = name;
 	ret = fsl_qman_probe(&dev.pdev);
-	if (ret != 0)
-		panic("qman: init failed");
+#endif /* QORIQ_IS_HYPERVISOR_GUEST */
 	qman_sysinit_portals();
diff --git a/linux/drivers/soc/fsl/qbman/qman_portal.c b/linux/drivers/soc/fsl/qbman/qman_portal.c
index a7295f904..b4338a282 100644
--- a/linux/drivers/soc/fsl/qbman/qman_portal.c
+++ b/linux/drivers/soc/fsl/qbman/qman_portal.c
@@ -403,7 +403,7 @@ qman_get_dedicated_portal(int cpu)
 	if (p == NULL)
 		return (NULL);
-	list_del(&pcfg->node);
+	list_del_init(&pcfg->node);
 	irq_sources = QM_PIRQ_EQCI | QM_PIRQ_EQRI | QM_PIRQ_MRI | QM_PIRQ_CSCI
 	    | QM_PIRQ_DQRI;
@@ -433,9 +433,10 @@ do_init_pcfg(struct device_node *dn, struct qm_portal_config *pcfg,
 	ret = of_address_to_resource(dn, 0, &res);
 	if (ret != 0)
 		panic("qman: no portal CE address");
-#if QORIQ_CHIP_IS_T_VARIANT(QORIQ_CHIP_VARIANT)
-	pcfg->addr_virt[0] = (__iomem void *)
-	    ((uintptr_t)&qoriq_qman_portal[0][0] + (uintptr_t)res.start);
+	pcfg->addr_virt[0] = (__iomem void *)(uintptr_t)res.start;
+	printk("qman[0] %llx\n", res.start);
+#if QORIQ_CHIP_IS_T_VARIANT(QORIQ_CHIP_VARIANT) && \
+    !defined(QORIQ_IS_HYPERVISOR_GUEST)
 	BSD_ASSERT((uintptr_t)pcfg->addr_virt[0] >=
 	    (uintptr_t)&qoriq_qman_portal[0][0]);
 	BSD_ASSERT((uintptr_t)pcfg->addr_virt[0] <
@@ -445,9 +446,10 @@ do_init_pcfg(struct device_node *dn, struct qm_portal_config *pcfg,
 	ret = of_address_to_resource(dn, 1, &res);
 	if (ret != 0)
 		panic("qman: no portal CI address");
-	pcfg->addr_virt[1] = (__iomem void *)
+	pcfg->addr_virt[1] = (__iomem void *)(uintptr_t)res.start;
+	printk("qman[1] %llx\n", res.start);
 	BSD_ASSERT((uintptr_t)pcfg->addr_virt[1] >=
 	    (uintptr_t)&qoriq_qman_portal[1][0]);
 	BSD_ASSERT((uintptr_t)pcfg->addr_virt[1] <
@@ -472,7 +474,7 @@ do_init_pcfg(struct device_node *dn, struct qm_portal_config *pcfg,
 		portal = init_pcfg(pcfg);
 		if (portal == NULL)
-			panic("qman: cannot create portal");
+			panic("qman: cannot create portal (1)");
 		qman_portal_update_sdest(pcfg, val);
 	} else {
@@ -490,42 +492,67 @@ qman_sysinit_portals(void)
 	int cpu_count = (int)rtems_get_processor_count();
 	int i;
 	int node;
-	int parent;
-	memset(&dn, 0, sizeof(dn));
-	name = "fsl,qman-portal";
-	if (node < 0)
-		panic("qman: no portals in FDT");
-	parent = fdt_parent_offset(fdt, node);
-	if (parent < 0)
-		panic("qman: no parent of portals in FDT");
-	node = fdt_first_subnode(fdt, parent);
-	dn.full_name = name;
-	dn.offset = node;
 	qoriq_clear_ce_portal(&qoriq_qman_portal[0][0],
 	    sizeof(qoriq_qman_portal[0]));
 	qoriq_clear_ci_portal(&qoriq_qman_portal[1][0],
 	    sizeof(qoriq_qman_portal[1]));
 #endif
+	memset(&dn, 0, sizeof(dn));
+	name = "fsl,qman-portal";
+	node = -1;
+	dn.full_name = name;
 	i = 0;
-	while (node >= 0 && i < MAX_QMAN_PORTALS) {
-		if (fdt_node_check_compatible(fdt, node, name) == 0) {
-			do_init_pcfg(&dn, &qman_configs[i], cpu_count);
-			++i;
-		node = fdt_next_subnode(fdt, node);
+	while (i < MAX_QMAN_PORTALS) {
+		node = fdt_node_offset_by_compatible(fdt, node, name);
+		if (node < 0)
+			break;
 		dn.offset = node;
+		do_init_pcfg(&dn, &qman_configs[i], cpu_count);
+		++i;
 	if (i < cpu_count)
-		panic("qman: not enough portals in FDT");
+		panic("qman: not enough affine portals");
+	 * We try to use the "cell-index" for the affine portal processor
+	 * index.  This is not always possible, so equip the remaining
+	 * processors with portals from the free list.  Ignore the
+	 * "libbsd,dequeue" property.
+	for (i = 0; i < cpu_count; ++i) {
+		struct qman_portal *p;
+		p = affine_portals[i];
+		if (p == NULL) {
+			struct qm_portal_config *pcfg;
+			struct qman_portal *portal;
+			if (list_empty(&qman_free_portals))
+				panic("qman: no free affine portal");
+			pcfg = list_first_entry(&qman_free_portals,
+			    struct qm_portal_config, node);
+			pcfg->cpu = i;
+			pcfg->pools = qm_get_pools_sdqcr();
+			portal = init_pcfg(pcfg);
+			if (portal == NULL)
+				panic("qman: cannot create portal (2)");
+			qman_portal_update_sdest(pcfg, i);
 	/* all assigned portals are initialized now */
 	qman_init_cgr_all();
2.12.3
