RTEMS Tester and Log Files
Mon Jan 22 06:43:42 UTC 2018
On 21/01/18 22:37, Chris Johns wrote:
> On 19/1/18 6:06 pm, Sebastian Huber wrote:
>> Hello,
>> the RTEMS Tester works quite well if it can run the tests step by step. I have a
>> board were I can run reliably all tests at once with a custom script. I cannot
>> run tests individually due to an instability in the debug support. This produces
>> a large text file with the test output of all tests. Is there an option to
>> simply feed this file to the rtems-test program and generate the report
>> (optionally send it via e-mail)?
> There currently is no option. This is a great idea and really good feature to
> have. Please raise a ticket and assign it to me.
> Does the log have delimiters to identify the next test? I am not sure is the
> test BEGIN message is enough to cover the states.
> Could you please upload the log somewhere I can get it?
Thanks, I created a ticket for this:
https://devel.rtems.org/ticket/3276
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
