[PATCH] rtems: Remove unused configuration files.
    Sebastian Huber
    Mon Jan 22 10:11:28 UTC 2018
On 22/01/18 01:06, Joel Sherrill wrote:
>     I am open to any ideas that improve how we use and manage the RSB.
> I don't want to move away from release branches or including the versions
> in the files.
> Having the versions in the files makes it easy to upgrade all but one
> or two
> architectures.
If you use the versions in the files, then each update creates orphan
files. If you remove these files, then you do basically a rename with a
modification. In addition, you have to search and replace the version in
the *.bset files. It would be much easier to use *.cfg files without a
version, e.g.
tools/rtems-gcc.cfg
tools/rtems-gcc-m32.cfg
tools/rtems-gcc-or1k.cfg
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
