no-preinstall: Architecture-specific header files
Mon Jan 22 21:03:54 UTC 2018
On 19/1/18 6:21 pm, Sebastian Huber wrote:
> Hello,
> the architecture-specific header files are currently in:
> cpukit/score/cpu/@RTEMS_CPU@
> For example:
> cpukit/score/cpu/sparc/rtems/score/cpu.h
> The new include directory for architecture-specific header files after the
> preinstall removal is:
> cpukit/score/cpu/@RTEMS_CPU@/include
> For example:
> cpukit/score/cpu/sparc/include/rtems/score/cpu.h
> There are two problems with this.
> 1. It introduces yet another sub-directory and makes the path longer.
> 2. It moves header files which are in this place since 1999. Using
> cpukit/score/cpu/@RTEMS_CPU@ as the include directory would avoid this.
Thank you for raising this. It is bit inconsistent.
> This should be the last time we move header files around. It is very easy to
> move include directories in the no-preinstall branch.
> Other options for architecture-specific header files are:
If this has source files and maybe private headers we should not add use this path.
> cpukit/@RTEMS_CPU@/include
> cpukit/arch/@RTEMS_CPU@/include
> cpukit/cpu/@RTEMS_CPU@/include
> cpukit/include/@RTEMS_CPU@
I think this is a good place but I am concerned about 2 -I paths, one a sub path
of another. Is that a problem?
> include/@RTEMS_CPU@
> The general include files are now in:
> cpukit/include
> Another option would be:
> include
> What do you think?
I am not sure.
