no-preinstall: Ready to merge
Mon Jan 22 22:35:08 UTC 2018
On 23/01/2018 01:49, Sebastian Huber wrote:
> Hello,
> I installed all BSPs of the master and then all BSPs of the no-preinstall
> branch.  The difference in installed BSP files is this:
> https://ftp.rtems.org/pub/rtems/people/sebh/tmp/headers-diff.txt
> There are no removals.  In the no-preinstall installation, there are more header
> files present (this is expected).  If someone has a problem with this, then we
> can fine tune this later.  For the preinstall removal this is not a blocking point.
> The squashed commit is at the top of the no-preinstall branch:
> https://git.rtems.org/sebh/rtems.git/log/?h=no-preinstall
I OK with this change being pushed to master.
It would be great if someone who experienced the original problem of the
'install' command failing on Linux during the preinstall phase could please run
a test build with a large number of jobs to see if the problem has been resolved.
