[PATCH] Xilinx AXI I2C driver IP race condition causes clock glitch.
Tue Jan 23 02:30:29 UTC 2018
Setting the PIRQ to 0 before reading the data produces a short clock pulse.
Moving the write to after reading the data fixes the issue.
Close #3173
 cpukit/dev/i2c/xilinx-axi-i2c.c | 6 +++++-
 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/cpukit/dev/i2c/xilinx-axi-i2c.c b/cpukit/dev/i2c/xilinx-axi-i2c.c
index 45a1c90c37..11b0658161 100644
--- a/cpukit/dev/i2c/xilinx-axi-i2c.c
+++ b/cpukit/dev/i2c/xilinx-axi-i2c.c
@@ -512,8 +512,12 @@ xilinx_axi_i2c_read_rx_fifo(xilinx_axi_i2c_bus* bus)
         xilinx_axi_i2c_disable_clear_irq(bus, INT_TX_ERROR);
         xilinx_axi_i2c_set_cr(bus, CR_TXAK);
-        xilinx_axi_i2c_write_rx_pirq(bus, 0);
         xilinx_axi_i2c_read_rx_bytes(bus, level);
+         * Set the RX PIRQ to 0 after the RX data has been read. There is an
+         * observed timing issue and glitch if written before.
+        xilinx_axi_i2c_write_rx_pirq(bus, 0);
         break;
       case 0:
2.14.1
