[PATCH] MAINTAINERS: Add myself to Write After Approval.
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Jan 23 16:13:47 UTC 2018
Hello Gedare,
I discussed it with Sebastian and he thought that it wouldn't be a
problem if I push that patch. Therefore: pushed.
Regards
Christian
Am 23.01.2018 um 08:51 schrieb Christian Mauderer:
> Hello Gedare,
> thanks for the approval. I'll coordinate that with Sebastian or just
> wait till the merge.
> Regards
> Christian
> Am 23.01.2018 um 00:38 schrieb Gedare Bloom:
>> Ahem, ask Sebastian to also put it on the no-preinstall branch. I'm
>> not quite sure the state of the master "freeze" at this point. You
>> could also wait until after the merge happens.
>> On Mon, Jan 22, 2018 at 6:37 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> Approved!
>>> On Mon, Jan 22, 2018 at 3:58 AM, Christian Mauderer
>>> <christian.mauderer at embedded-brains.de> wrote:
>>>> From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
>>>>  MAINTAINERS | 1 +
>>>>  1 file changed, 1 insertion(+)
>>>> diff --git a/MAINTAINERS b/MAINTAINERS
>>>> index 35a149a932..2d91ecb149 100644
>>>> --- a/MAINTAINERS
>>>> +++ b/MAINTAINERS
>>>> @@ -49,6 +49,7 @@ Daniel Hellstrom           daniel at gaisler.com
>>>>  Ben Gras                   beng at rtems.org
>>>>  Martin Galvan              martin.galvan at tallertechnologies.com
>>>>  Pavel Pisa                 ppisa at pikron.com
>>>> +Christian Mauderer         christian.mauderer at embedded-brains.de
>>>>  Localized Write Permission
>>>> 2.13.6
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
