[PATCH] rfs: Fix for 64-bit targets
Tue Jan 23 16:30:29 UTC 2018
On Tue, Jan 23, 2018 at 10:41 AM, Sebastian Huber
> There were a lot of other 64-bit target problems. Backporting this patch alone doesn’t help.
OK. The only target affected is sparc64 anyway, and no one is using it
right now as far as I know.
> ----- Gedare Bloom <gedare at rtems.org> schrieb:
>> Please also open tickets for 4.11, 4.10 and apply there.
>> On Mon, Jan 22, 2018 at 6:34 AM, Sebastian Huber
>> > The RTEMS_BLKIO_SETBLKSIZE IO control expects an uint32_t parameter and
>> > not a size_t which is 64-bits on 64-bit targets.
>> > Update #3082.
>> >  cpukit/libfs/src/rfs/rtems-rfs-buffer.c | 2 +-
>> >  cpukit/libfs/src/rfs/rtems-rfs-buffer.h | 2 +-
>> >  2 files changed, 2 insertions(+), 2 deletions(-)
>> > diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
>> > index d99a351a7f..c1c780bc48 100644
>> > --- a/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
>> > +++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer.c
>> > @@ -411,7 +411,7 @@ rtems_rfs_buffer_sync (rtems_rfs_file_system* fs)
>> >  int
>> > -rtems_rfs_buffer_setblksize (rtems_rfs_file_system* fs, size_t size)
>> > +rtems_rfs_buffer_setblksize (rtems_rfs_file_system* fs, uint32_t size)
>> >    int rc;
>> > diff --git a/cpukit/libfs/src/rfs/rtems-rfs-buffer.h b/cpukit/libfs/src/rfs/rtems-rfs-buffer.h
>> > index f5fe9d48e2..1c603e1827 100644
>> > --- a/cpukit/libfs/src/rfs/rtems-rfs-buffer.h
>> > +++ b/cpukit/libfs/src/rfs/rtems-rfs-buffer.h
>> > @@ -268,7 +268,7 @@ int rtems_rfs_buffer_sync (rtems_rfs_file_system* fs);
>> >   * @retval 0 Successful operation.
>> >   * @retval error_code An error occurred.
>> > -int rtems_rfs_buffer_setblksize (rtems_rfs_file_system* fs, size_t size);
>> > +int rtems_rfs_buffer_setblksize (rtems_rfs_file_system* fs, uint32_t size);
>> >   * Release any chained buffers.
>> > 2.12.3
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
