no-preinstall: Ready to merge
Wed Jan 24 08:16:13 UTC 2018
On 23/01/18 16:24, Joel Sherrill wrote:
> On Mon, Jan 22, 2018 at 6:23 PM, Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
>     On Mon, Jan 22, 2018 at 5:59 PM, Chris Johns <chrisj at rtems.org
>     <mailto:chrisj at rtems.org>> wrote:
>         On 23/01/2018 10:50, Joel Sherrill wrote:
>         > On Mon, Jan 22, 2018 at 4:35 PM, Chris Johns
>         <chrisj at rtems.org <mailto:chrisj at rtems.org>
>         > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
>         >     On 23/01/2018 01:49, Sebastian Huber wrote:
>         >     > Hello,
>         >     > I installed all BSPs of the master and then all BSPs
>         of the no-preinstall
>         >     > branch.  The difference in installed BSP files is this:
>         https://ftp.rtems.org/pub/rtems/people/sebh/tmp/headers-diff.txt
>         <https://ftp.rtems.org/pub/rtems/people/sebh/tmp/headers-diff.txt>
>         <https://ftp.rtems.org/pub/rtems/people/sebh/tmp/headers-diff.txt>>
>         >     > There are no removals.  In the no-preinstall
>         installation, there are more header
>         >     > files present (this is expected). If someone has a
>         problem with this, then we
>         >     > can fine tune this later.  For the preinstall removal
>         this is not a blocking point.
>         >     > The squashed commit is at the top of the no-preinstall
>         branch:
>         https://git.rtems.org/sebh/rtems.git/log/?h=no-preinstall
>         <https://git.rtems.org/sebh/rtems.git/log/?h=no-preinstall>
>         <https://git.rtems.org/sebh/rtems.git/log/?h=no-preinstall>>
>         >     I OK with this change being pushed to master.
>         >     It would be great if someone who experienced the
>         original problem of the
>         >     'install' command failing on Linux during the preinstall
>         phase could please run
>         >     a test build with a large number of jobs to see if the
>         problem has been
>         >     resolved.
>         > I think that was a not so subtle jab at me.
>         Not really, it was to anyone effected and willing to help
>         test. I seem to
>         remember other reports of this happening.
>     Thanks Chris for the help fetching this. I have started a build of
>     all BSPs
>     on the no-preinstall branch on rtbf64c. I could pretty reliably
>     get failures
>     on this machine with preinstall and make -j.
>     I will report in the morning.
> No issues using make -j with the number of jobs being 8 on a machine with
> 12 cores (6 real). Same failures as master. powerpc-qoriq_core_0 and
> powerpc-qoriq_core_1 did not build.
I fixed the qoriq problems yesterday.
If there are no serious objections, then I will push this commit tomorrow:
https://git.rtems.org/sebh/rtems.git/commit/?h=no-preinstall&id=9a1b498cd50bc5b8841d3e513c8b048274b71ea8
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
