Contribute to project
Abhinav Jain
jainab.2009 at gmail.com
Fri Jan 26 08:37:24 UTC 2018
Sir,
Thanks a lot for guidance, I will go through the links provided by you.
Thanks and Regards
Abhinav Jain
On Jan 26, 2018 2:02 PM, "Amaan Cheval" <amaan.cheval at gmail.com> wrote:
> > I found some code here that you might find useful:
> > https://code.google.com/archive/p/rtems-mmu-support/
> What I linked was work from 2009, found here:
> https://devel.rtems.org/wiki/GSoC/2009/
> Here's more code, from 2011:
> https://code.google.com/archive/p/gsoc2011-rtems-mmu-support-project/
> (It was linked in the final report for GSoC 2011:
> https://www.rtems.org/gsoc2011_final_report)
> Code from 2013:
> https://github.com/heshamelmatary/rtems-gsoc2013/tree/low-level-libmm
> And a brief summary of the work in 2013 (by Hesham Moustafa
> AL-matary):
> https://www.rtems.org/gsoc2013_final_report
> Hope that helps :)
> On Fri, Jan 26, 2018 at 1:30 PM, Amaan Cheval <amaan.cheval at gmail.com>
> wrote:
> >> I was not able to find the code part and the work done in this project
> till now.
> > Besides that, perhaps searching the mailing list archives might prove
> > useful too:
> > https://www.google.com/search?q=gsoc+mmu+site%3Ahttps%3A%2F%
> 2Flists.rtems.org%2Fpipermail%2Fdevel%2F
> > Good luck :)
> > On Fri, Jan 26, 2018 at 8:41 AM, Abhinav Jain <jainab.2009 at gmail.com>
> wrote:
> >> Sir,
> >> Please guide me so that I can proceed further and start contributing to
> the
> >> project.
> >> Thanks and Regards
> >> Abhinav Jain
> >> On Jan 25, 2018 12:15 AM, "Abhinav Jain" <jainab.2009 at gmail.com> wrote:
> >>> Sir,
> >>> I have gone through the project page
> >>> (https://devel.rtems.org/wiki/Projects/MMU_Support#no1) and have
> understood
> >>> the basic concept and the aim of the project. The project seems very
> >>> interesting and I will be highly delighted to be a part of this.
> >>> Although I was able to get a brief about the project, I was not able to
> >>> find the code part and the work done in this project till now. Can you
> >>> please help me guiding how can I proceed with contributing to this
> project.
> >>> Thanks and Regards
> >>> Abhinav Jain
> >>> Mob: +91 9717743353
> >>> On Tue, Jan 23, 2018 at 10:23 PM, Abhinav Jain <jainab.2009 at gmail.com>
> >>> wrote:
> >>>> Sir,
> >>>> Thanks a lot for your guidance.
> >>>> Thanks and regards
> >>>> Abhinav jain
> >>>> On Jan 23, 2018 10:03 PM, "Gedare Bloom" <gedare at rtems.org> wrote:
> >>>>> Abhinav,
> >>>>> On Tue, Jan 23, 2018 at 11:22 AM, Abhinav Jain <
> >>>>> wrote:
> >>>>> > Hello!
> >>>>> > I have gone through the list of open source projects and found a
> >>>>> > project
> >>>>> > named "Memory Protection"(https://devel.rtems.org/ticket/2904)
> very
> >>>>> > interesting.
> >>>>> > Please elaborate more on the project and guide me how can I
> contribute
> >>>>> > to it
> >>>>> > and what all do I need to know before starting.
> >>>>> You should review the work that was done in previous years on this
> >>>>> topic. There have been a few efforts made toward it. Currently, the
> >>>>> most useful thing is to try defining a unified BSP framework for
> >>>>> initializing and updating any memory protection related hardware,
> e.g.
> >>>>> MPU/MMU. This is a pre-requisite to being able to define APIs that
> >>>>> could rely on memory protection in a reasonably portable way.
> >>>>> > Thanks and Regards
> >>>>> > Abhinav Jain
> >>>>> > On Sun, Jan 21, 2018 at 10:43 PM, Christian Mauderer
> >>>>> > <list at c-mauderer.de>
> >>>>> > wrote:
> >>>>> >> Am 21.01.2018 um 16:01 schrieb Abhinav Jain:
> >>>>> >> > Hello Christian Mauderer,
> >>>>> >> > I read about GSoC and I found it really interesting. It seems
> to be
> >>>>> >> > a
> >>>>> >> > great platform to get linked with the open source communities.
> But
> >>>>> >> > it
> >>>>> >> > seems that its registration starts sometime around March. Can I
> go
> >>>>> >> > forward with some of the projects till then?
> >>>>> >> > Please guide what should be further steps. I am really excited
> to
> >>>>> >> > start
> >>>>> >> > working and I hope it will be a great experience for me.
> >>>>> >> > Thanks and Regards
> >>>>> >> > Abhinav Jain
> >>>>> >> Hello Abhinav Jain,
> >>>>> >> yes, that's right. Registration is in a few months. I'm quite sure
> >>>>> >> that
> >>>>> >> there is a solution that you can start on a project and then
> continue
> >>>>> >> it
> >>>>> >> as a GSoC project. But note that there are quite clear rules from
> >>>>> >> Google, that only the work during GSoC can be evaluated. And
> there is
> >>>>> >> always only a limited number of slots for GSoC students so we
> can't
> >>>>> >> guarantee any acceptance even if you start before GSoC starts.
> >>>>> >> Independent on whether you would like to participate in GSoC
> later or
> >>>>> >> not I would suggest to start with
> >>>>> >> https://devel.rtems.org/wiki/GSoC/GettingStarted. Then pick a
> project
> >>>>> >> that you are interested in (either from the open projects page or
> >>>>> >> something other that you find interesting) and start to ask about
> it
> >>>>> >> on
> >>>>> >> the mailing list and whether someone would be ready to support you
> >>>>> >> now
> >>>>> >> and maybe be your mentor during GSoC.
> >>>>> >> Best regards
> >>>>> >> Christian
> >>>>> >> > On Sun, Jan 21, 2018 at 5:09 PM, Christian Mauderer
> >>>>> >> > <mailto:list at c-mauderer.de>> wrote:
> >>>>> >> > Am 21.01.2018 um 12:27 schrieb Abhinav Jain:
> >>>>> >> > > Sir
> >>>>> >> > > Thanks for your reply and guidance. It will be a great
> help
> >>>>> >> > if you
> >>>>> >> > > please provide me a direction so that I can proceed
> further.
> >>>>> >> > > Thanks and Regards
> >>>>> >> > > Abhinav Jain
> >>>>> >> > Hello Abhinav Jain,
> >>>>> >> > please keep that discussion on the mailing list so that
> others
> >>>>> >> > might
> >>>>> >> > can
> >>>>> >> > assist too except there is some specific reason for not
> having
> >>>>> >> > it
> >>>>> >> > public.
> >>>>> >> > If you are interested in GSoC, please start by reading the
> GSoC
> >>>>> >> > page
> >>>>> >> > (https://devel.rtems.org/wiki/GSoC
> >>>>> >> > <https://devel.rtems.org/wiki/GSoC>) and do the "GSoC
> Getting
> >>>>> >> > Started"
> >>>>> >> > (https://devel.rtems.org/wiki/GSoC/GettingStarted
> >>>>> >> > <https://devel.rtems.org/wiki/GSoC/GettingStarted>).
> >>>>> >> > If you just want to do some work out of GSoC occasionally,
> it
> >>>>> >> > would
> >>>>> >> > be
> >>>>> >> > good if you could provide more details, what exactly you
> would
> >>>>> >> > like
> >>>>> >> > to
> >>>>> >> > do. For example, you told that you have a Raspberry. If you
> >>>>> >> > have
> >>>>> >> > some
> >>>>> >> > goals with that board, feel free to tell them so that we can
> >>>>> >> > help
> >>>>> >> > you
> >>>>> >> > finding out what would be necessary to reach it.
> >>>>> >> > Oh, and by the way: Most people have a quite informal
> >>>>> >> > communication
> >>>>> >> > style on this mailing list. So no need for any "Sir" in the
> >>>>> >> > salutation.
> >>>>> >> > Regards
> >>>>> >> > Christian
> >>>>> >> > > On Sun, Jan 21, 2018 at 3:41 PM, Christian Mauderer
> >>>>> >> > <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >>>>> >> > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
> >>>>> >> > wrote:
> >>>>> >> > > Am 21.01.2018 um 07:21 schrieb Abhinav Jain:
> >>>>> >> > > > Sir/Madam
> >>>>> >> > > > May I get the liberty to bring it to your kind
> notice
> >>>>> >> > that I
> >>>>> >> > am second
> >>>>> >> > > > year engineering student from Delhi, India. I am
> >>>>> >> > pursuing my
> >>>>> >> > engineering
> >>>>> >> > > > in Instrumentation and Control and for around a
> year I
> >>>>> >> > have
> >>>>> >> > been working
> >>>>> >> > > > in Linux Kernel Development, I have been writing
> small
> >>>>> >> > drivers and have
> >>>>> >> > > > a good knowledge of the operating system. For around
> >>>>> >> > 2-3
> >>>>> >> > months, I am
> >>>>> >> > > > developing some projects using Raspberry Pi.
> >>>>> >> > > > In the process, I read about your organization and
> came
> >>>>> >> > to
> >>>>> >> > know that you
> >>>>> >> > > > are working in a field that interests me a lot and I
> >>>>> >> > would
> >>>>> >> > like to be a
> >>>>> >> > > > part of your projects. I want to be a contributor
> and
> >>>>> >> > will
> >>>>> >> > try to give
> >>>>> >> > > > best from my side.
> >>>>> >> > > > I request you to please assign me some task as per
> my
> >>>>> >> > abilities so that
> >>>>> >> > > > I can start working on it.
> >>>>> >> > > > Thanks and Regards
> >>>>> >> > > > Abhinav Jain
> >>>>> >> > > > Mob: - +91 9717743353
> >>>>> >> > > Hello Abhinav Jain,
> >>>>> >> > > if you are a student, you could think about
> participating
> >>>>> >> > in
> >>>>> >> > GSoC:
> >>>>> >> > > Basically it's a program where Google pays students
> for
> >>>>> >> > doing
> >>>>> >> > open
> >>>>> >> > > source work during the semester break. It's always a
> >>>>> >> > great
> >>>>> >> > opportunity
> >>>>> >> > > for becoming a community member:
> >>>>> >> > <https://devel.rtems.org/wiki/GSoC>>
> >>>>> >> > > Independent whether you are interested in GSoC, you
> might
> >>>>> >> > want
> >>>>> >> > to take a
> >>>>> >> > > look at the open project page in the wiki. There is a
> >>>>> >> > collection of
> >>>>> >> > > projects which need some work. Note that although
> these
> >>>>> >> > projects are
> >>>>> >> > > mostly targeted at GSoC they could be processed out of
> >>>>> >> > GSoC
> >>>>> >> > context too:
> >>>>> >> > > https://devel.rtems.org/wiki/Developer/OpenProjects
> >>>>> >> > <https://devel.rtems.org/wiki/Developer/OpenProjects>
> >>>>> >> > <https://devel.rtems.org/wiki/Developer/OpenProjects>>
> >>>>> >> > > Best regards
> >>>>> >> > > Christian Mauderer
> >>>>> > _______________________________________________
> >>>>> > devel mailing list
> >>>>> > devel at rtems.org
> >>>>> > http://lists.rtems.org/mailman/listinfo/devel
> >> devel mailing list
> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180126/73ac7402/attachment-0001.html>
