[PATCH 2/2] 5: Add versions to file names
Wed Jan 31 08:33:30 UTC 2018
 rtems/config/5/rtems-default.bset                                     | 4 ++--
 rtems/config/5/rtems-epiphany.bset                                    | 4 ++--
 rtems/config/5/rtems-m32c.bset                                        | 4 ++--
 rtems/config/5/rtems-or1k.bset                                        | 4 ++--
 rtems/config/5/rtems-riscv32.bset                                     | 4 ++--
 rtems/config/5/rtems-riscv64.bset                                     | 4 ++--
 rtems/config/tools/{rtems-binutils.cfg => rtems-binutils-2.30.cfg}    | 0
 .../tools/{rtems-gcc-m32c.cfg => rtems-gcc-4.8.3-newlib-3.0.0.cfg}    | 0
 .../tools/{rtems-gcc-or1k.cfg => rtems-gcc-4.9.3-newlib-3.0.0.cfg}    | 0
 .../config/tools/{rtems-gcc.cfg => rtems-gcc-7.3.0-newlib-3.0.0.cfg}  | 0
 10 files changed, 12 insertions(+), 12 deletions(-)
 rename rtems/config/tools/{rtems-binutils.cfg => rtems-binutils-2.30.cfg} (100%)
 rename rtems/config/tools/{rtems-gcc-m32c.cfg => rtems-gcc-4.8.3-newlib-3.0.0.cfg} (100%)
 rename rtems/config/tools/{rtems-gcc-or1k.cfg => rtems-gcc-4.9.3-newlib-3.0.0.cfg} (100%)
 rename rtems/config/tools/{rtems-gcc.cfg => rtems-gcc-7.3.0-newlib-3.0.0.cfg} (100%)
diff --git a/rtems/config/5/rtems-default.bset b/rtems/config/5/rtems-default.bset
index bb1a123..dcafbdc 100644
--- a/rtems/config/5/rtems-default.bset
+++ b/rtems/config/5/rtems-default.bset
@@ -10,8 +10,8 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
-tools/rtems-binutils
-tools/rtems-gcc
+tools/rtems-binutils-2.30
+tools/rtems-gcc-7.3.0-newlib-3.0.0
 tools/rtems-gdb-8.0.1-1
 tools/rtems-tools-5-1
 tools/rtems-kernel-5
diff --git a/rtems/config/5/rtems-epiphany.bset b/rtems/config/5/rtems-epiphany.bset
index f2c7230..b7ac799 100644
--- a/rtems/config/5/rtems-epiphany.bset
+++ b/rtems/config/5/rtems-epiphany.bset
@@ -33,7 +33,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
-tools/rtems-gcc
 tools/rtems-gdb-7.8.1-1
diff --git a/rtems/config/5/rtems-m32c.bset b/rtems/config/5/rtems-m32c.bset
index 4f0284d..addce75 100644
--- a/rtems/config/5/rtems-m32c.bset
+++ b/rtems/config/5/rtems-m32c.bset
@@ -40,7 +40,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
-tools/rtems-gcc-m32c
+tools/rtems-gcc-4.8.3-newlib-3.0.0
diff --git a/rtems/config/5/rtems-or1k.bset b/rtems/config/5/rtems-or1k.bset
index b7a52e1..15be88e 100644
--- a/rtems/config/5/rtems-or1k.bset
+++ b/rtems/config/5/rtems-or1k.bset
@@ -32,7 +32,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
-tools/rtems-gcc-or1k
+tools/rtems-gcc-4.9.3-newlib-3.0.0
 tools/rtems-gdb-7.11-2
diff --git a/rtems/config/5/rtems-riscv32.bset b/rtems/config/5/rtems-riscv32.bset
index 78eab87..c4e99f2 100644
--- a/rtems/config/5/rtems-riscv32.bset
+++ b/rtems/config/5/rtems-riscv32.bset
@@ -10,7 +10,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
-tools/rtems-gcc
diff --git a/rtems/config/5/rtems-riscv64.bset b/rtems/config/5/rtems-riscv64.bset
index df44a05..c2fb727 100644
--- a/rtems/config/5/rtems-riscv64.bset
+++ b/rtems/config/5/rtems-riscv64.bset
@@ -10,7 +10,7 @@
 5/rtems-autotools
 devel/expat-2.1.0-1
-tools/rtems-gcc
diff --git a/rtems/config/tools/rtems-binutils.cfg b/rtems/config/tools/rtems-binutils-2.30.cfg
similarity index 100%
rename from rtems/config/tools/rtems-binutils.cfg
rename to rtems/config/tools/rtems-binutils-2.30.cfg
diff --git a/rtems/config/tools/rtems-gcc-m32c.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-3.0.0.cfg
rename from rtems/config/tools/rtems-gcc-m32c.cfg
rename to rtems/config/tools/rtems-gcc-4.8.3-newlib-3.0.0.cfg
diff --git a/rtems/config/tools/rtems-gcc-or1k.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-3.0.0.cfg
rename from rtems/config/tools/rtems-gcc-or1k.cfg
rename to rtems/config/tools/rtems-gcc-4.9.3-newlib-3.0.0.cfg
diff --git a/rtems/config/tools/rtems-gcc.cfg b/rtems/config/tools/rtems-gcc-7.3.0-newlib-3.0.0.cfg
rename from rtems/config/tools/rtems-gcc.cfg
rename to rtems/config/tools/rtems-gcc-7.3.0-newlib-3.0.0.cfg
2.12.3
