Build Failures on Master
Wed Jan 31 21:58:24 UTC 2018
On 01/02/2018 03:14, Joel Sherrill wrote:
> On Wed, Jan 31, 2018 at 5:40 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>
> wrote:
>     On 31/01/18 12:09, Sebastian Huber wrote:
>         On 27/01/18 23:49, Joel Sherrill wrote:
>             Hi
>             This bsp builder test report shows about 25 build failures.
>             https://lists.rtems.org/pipermail/build/2018-January/000333.html
>             <https://lists.rtems.org/pipermail/build/2018-January/000333.html>
>         The problems seem to be an issue with the BSP builder:
>         ../configure --target=powerpc-rtems5 --enable-rtemsbsp=qoriq_e6500_64 ss555
https://git.rtems.org/rtems-tools/tree/tester/rtems/rtems-bsps-powerpc.ini#n45
No ',' at the end of the line. An easy mistake and so I would like to add an
error check to the BSP builder.
I will sort this out. I would like to use this as a test case to add a check for
spaces in BSP names.
