[PATCH 2/2] 5: Add versions to file names
Wed Jan 31 22:03:39 UTC 2018
Looks good.
Thank you and sorry for the confusion.
On 31/01/2018 19:33, Sebastian Huber wrote:
>  rtems/config/5/rtems-default.bset                                     | 4 ++--
>  rtems/config/5/rtems-epiphany.bset                                    | 4 ++--
>  rtems/config/5/rtems-m32c.bset                                        | 4 ++--
>  rtems/config/5/rtems-or1k.bset                                        | 4 ++--
>  rtems/config/5/rtems-riscv32.bset                                     | 4 ++--
>  rtems/config/5/rtems-riscv64.bset                                     | 4 ++--
>  rtems/config/tools/{rtems-binutils.cfg => rtems-binutils-2.30.cfg}    | 0
>  .../tools/{rtems-gcc-m32c.cfg => rtems-gcc-4.8.3-newlib-3.0.0.cfg}    | 0
>  .../tools/{rtems-gcc-or1k.cfg => rtems-gcc-4.9.3-newlib-3.0.0.cfg}    | 0
>  .../config/tools/{rtems-gcc.cfg => rtems-gcc-7.3.0-newlib-3.0.0.cfg}  | 0
>  10 files changed, 12 insertions(+), 12 deletions(-)
>  rename rtems/config/tools/{rtems-binutils.cfg => rtems-binutils-2.30.cfg} (100%)
>  rename rtems/config/tools/{rtems-gcc-m32c.cfg => rtems-gcc-4.8.3-newlib-3.0.0.cfg} (100%)
>  rename rtems/config/tools/{rtems-gcc-or1k.cfg => rtems-gcc-4.9.3-newlib-3.0.0.cfg} (100%)
>  rename rtems/config/tools/{rtems-gcc.cfg => rtems-gcc-7.3.0-newlib-3.0.0.cfg} (100%)
> diff --git a/rtems/config/5/rtems-default.bset b/rtems/config/5/rtems-default.bset
> index bb1a123..dcafbdc 100644
> --- a/rtems/config/5/rtems-default.bset
> +++ b/rtems/config/5/rtems-default.bset
> @@ -10,8 +10,8 @@
>  5/rtems-autotools
>  devel/expat-2.1.0-1
> -tools/rtems-binutils
> -tools/rtems-gcc
> +tools/rtems-binutils-2.30
> +tools/rtems-gcc-7.3.0-newlib-3.0.0
>  tools/rtems-gdb-8.0.1-1
>  tools/rtems-tools-5-1
>  tools/rtems-kernel-5
> diff --git a/rtems/config/5/rtems-epiphany.bset b/rtems/config/5/rtems-epiphany.bset
> index f2c7230..b7ac799 100644
> --- a/rtems/config/5/rtems-epiphany.bset
> +++ b/rtems/config/5/rtems-epiphany.bset
> @@ -33,7 +33,7 @@
>  5/rtems-autotools
>  devel/expat-2.1.0-1
> -tools/rtems-gcc
>  tools/rtems-gdb-7.8.1-1
> diff --git a/rtems/config/5/rtems-m32c.bset b/rtems/config/5/rtems-m32c.bset
> index 4f0284d..addce75 100644
> --- a/rtems/config/5/rtems-m32c.bset
> +++ b/rtems/config/5/rtems-m32c.bset
> @@ -40,7 +40,7 @@
>  5/rtems-autotools
>  devel/expat-2.1.0-1
> -tools/rtems-gcc-m32c
> +tools/rtems-gcc-4.8.3-newlib-3.0.0
> diff --git a/rtems/config/5/rtems-or1k.bset b/rtems/config/5/rtems-or1k.bset
> index b7a52e1..15be88e 100644
> --- a/rtems/config/5/rtems-or1k.bset
> +++ b/rtems/config/5/rtems-or1k.bset
> @@ -32,7 +32,7 @@
>  5/rtems-autotools
>  devel/expat-2.1.0-1
> -tools/rtems-gcc-or1k
> +tools/rtems-gcc-4.9.3-newlib-3.0.0
>  tools/rtems-gdb-7.11-2
> diff --git a/rtems/config/5/rtems-riscv32.bset b/rtems/config/5/rtems-riscv32.bset
> index 78eab87..c4e99f2 100644
> --- a/rtems/config/5/rtems-riscv32.bset
> +++ b/rtems/config/5/rtems-riscv32.bset
> @@ -10,7 +10,7 @@
>  5/rtems-autotools
>  devel/expat-2.1.0-1
> -tools/rtems-gcc
> diff --git a/rtems/config/5/rtems-riscv64.bset b/rtems/config/5/rtems-riscv64.bset
> index df44a05..c2fb727 100644
> --- a/rtems/config/5/rtems-riscv64.bset
> +++ b/rtems/config/5/rtems-riscv64.bset
> @@ -10,7 +10,7 @@
>  5/rtems-autotools
>  devel/expat-2.1.0-1
> -tools/rtems-gcc
> diff --git a/rtems/config/tools/rtems-binutils.cfg b/rtems/config/tools/rtems-binutils-2.30.cfg
> similarity index 100%
> rename from rtems/config/tools/rtems-binutils.cfg
> rename to rtems/config/tools/rtems-binutils-2.30.cfg
> diff --git a/rtems/config/tools/rtems-gcc-m32c.cfg b/rtems/config/tools/rtems-gcc-4.8.3-newlib-3.0.0.cfg
> rename from rtems/config/tools/rtems-gcc-m32c.cfg
> rename to rtems/config/tools/rtems-gcc-4.8.3-newlib-3.0.0.cfg
> diff --git a/rtems/config/tools/rtems-gcc-or1k.cfg b/rtems/config/tools/rtems-gcc-4.9.3-newlib-3.0.0.cfg
> rename from rtems/config/tools/rtems-gcc-or1k.cfg
> rename to rtems/config/tools/rtems-gcc-4.9.3-newlib-3.0.0.cfg
> diff --git a/rtems/config/tools/rtems-gcc.cfg b/rtems/config/tools/rtems-gcc-7.3.0-newlib-3.0.0.cfg
> rename from rtems/config/tools/rtems-gcc.cfg
> rename to rtems/config/tools/rtems-gcc-7.3.0-newlib-3.0.0.cfg
