Build Failures on Master
Wed Jan 31 23:55:46 UTC 2018
On 01/02/2018 09:14, Joel Sherrill wrote:
> I did another build overnight and I don't see it in the list archives by date.
> But when I
> go by author, I see it. There are failures in it that I can't reproduce by hand.
> https://lists.rtems.org/pipermail/build/2018-January/000376.html
> <https://lists.rtems.org/pipermail/build/2018-January/000376.html>
> Specifically I tried the first one on the list and it build for me this morning.
> This
> is listed as a failure but not when I build by hand.
> /home/joel/rtems-work/rtems/configure --target=arm-rtems5\
>>       --enable-rtemsbsp=arm1136jfs --prefix=/home/joel/rtems-work/bsps\
>>       --enable-debug
> Can anyone explain the difference?
The path to the tools is the same?
You will need to look in the complete log for the BSP builder, locate the error
and see what is happening.
I currently do not capture the surrounding area of the error from the log and
keep it, I just assumed this would be a manual process.
