lpc40xx BSPs do not build on master
Tue Jan 16 15:38:41 UTC 2018
On Tue, Jan 16, 2018 at 3:29 AM, Sebastian Huber <
> On 15/01/18 18:53, Joel Sherrill wrote:
>> Hi
>> I'm not sure what broke but neither lpc40xx_ea_ram nor lpc40xx_ea_rom
>> build.
> I cannot reproduce this problem. Which error do you get?
Hmmm... I neglected to mention that I am using gcc master also. Sorry.
One of the configure conftest.c probes is failing with an object
architecture
variant mismatch.
configure:3595: arm-rtems5-gcc -mthumb -march=armv7-m -mfpu=fpv4-sp-d16
-mfloat-abi=hard -mtune=cortex-m4 -O2 -g -ffunction-sections
-fdata-sections   conftest.c  >&5
/data/home/joel/test-gcc/install-master/bin/../lib/gcc/arm-rtems5/8.0.0/../../../../arm-rtems5/bin/ld:
error: /tmp/cckWAYRI.o uses VFP register arguments, a.out does not
failed to merge target specific data of file /tmp/cckWAYRI.o
warning: cannot find entry symbol _start; defaulting to 0000000000008018
collect2: error: ld returned 1 exit status
With gcc 8.0 trying to head to a freeze, I wonder if you could take a look
at it Sebastian.
--joel
> Address : Dornierstr. 4, D-82178 Puchheim, G
> <https://maps.google.com/?q=ess+:+Dornierstr.+4,+D-82178+Puchheim,+G&entry=gmail&source=g>
> ermany
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180116/bc2260d0/attachment-0002.html>
