[PATCH 03/20] linux/sort.h: New file
    Sebastian Huber
    Fri Jan 19 13:53:53 UTC 2018
 rtemsbsd/powerpc/include/linux/sort.h | 49 +++++++++++++++++++++++++++++++++++
 1 file changed, 49 insertions(+)
 create mode 100644 rtemsbsd/powerpc/include/linux/sort.h
diff --git a/rtemsbsd/powerpc/include/linux/sort.h b/rtemsbsd/powerpc/include/linux/sort.h
new file mode 100644
index 000000000..7628af57d
--- /dev/null
+++ b/rtemsbsd/powerpc/include/linux/sort.h
@@ -0,0 +1,49 @@
+ * Copyright (c) 2018 embedded brains GmbH
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+ * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+ * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+ * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#ifndef _LINUX_SORT_H
+#define	_LINUX_SORT_H
+#include <stdlib.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+static inline void sort(void *base, size_t nel, size_t width,
+    int (*compar)(const void *, const void *),
+    void (*unused)(void *, void *, int))
+	(void)unused;
+	qsort(base, nel, width, compar);
+#ifdef __cplusplus
+#endif /* _LINUX_SORT_H */
2.12.3
