[PATCH] rtems: Remove unused configuration files.
Mon Jan 22 22:26:04 UTC 2018
On 22/01/2018 21:11, Sebastian Huber wrote:
> On 22/01/18 01:06, Joel Sherrill wrote:
>>     I am open to any ideas that improve how we use and manage the RSB.
>> I don't want to move away from release branches or including the versions
>> in the files.
>> Having the versions in the files makes it easy to upgrade all but one or two
>> architectures.
> If you use the versions in the files, then each update creates orphan files. If
> you remove these files, then you do basically a rename with a modification. In
> addition, you have to search and replace the version in the *.bset files. It
> would be much easier to use *.cfg files without a version, e.g.
> tools/rtems-gcc.cfg
> tools/rtems-gcc-m32.cfg
> tools/rtems-gcc-or1k.cfg
Yes, I agree. I feel such a change on master is ok and the branches should be
left as they are for now and if a situation arises where it is profitable to do
we can consider it.
