no-preinstall: Ready to merge
Joel Sherrill
joel at rtems.org
Mon Jan 22 23:50:13 UTC 2018
On Mon, Jan 22, 2018 at 4:35 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 23/01/2018 01:49, Sebastian Huber wrote:
> > Hello,
> > I installed all BSPs of the master and then all BSPs of the no-preinstall
> > branch. The difference in installed BSP files is this:
> > https://ftp.rtems.org/pub/rtems/people/sebh/tmp/headers-diff.txt
> > There are no removals. In the no-preinstall installation, there are
> more header
> > files present (this is expected). If someone has a problem with this,
> then we
> > can fine tune this later. For the preinstall removal this is not a
> blocking point.
> > The squashed commit is at the top of the no-preinstall branch:
> > https://git.rtems.org/sebh/rtems.git/log/?h=no-preinstall
> I OK with this change being pushed to master.
> It would be great if someone who experienced the original problem of the
> 'install' command failing on Linux during the preinstall phase could
> please run
> a test build with a large number of jobs to see if the problem has been
> resolved.
I think that was a not so subtle jab at me. Do you want me to test before
or after
Sebastian pushes the branch.
I am ok pushing it and cleaning up problems as we get more users.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180122/96f92858/attachment-0002.html>
