Contribute to project
Abhinav Jain jainab.2009 at gmail.com
Wed Jan 31 17:47:33 UTC 2018
Sir,
Thanks for the guidance. The mail is very informative and I will follow the
way suggested by you.
Thanks and regards
Abhinav Jain
On Jan 31, 2018 5:41 PM, "Sebastian Huber" <
> The MMU support is a very challenging project. The scope of the project
> and potential use cases must be determined. You need a lot of experience to
> design good APIs and it helps if you know the APIs for this kind of stuff
> on other systems like QNX, Linux, FreeBSD, etc. For the architecture
> support a lot of background knowledge is required at least on PowerPC,
> ARMv5..8, SPARC, Nios2, MIPS, etc. For example, changing the TLB1 based MMU
> during application run-time on PowerPC (including SMP support, cache
> consistency) is not easy. There are some optimization problems involved if
> you want to determine a good cover with memory areas (alignment
> restrictions, limited number of areas in the MMU/MPU if not page based,
> e.g. 16).
> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim,+Germany&entry=gmail&source=g>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180131/e3272e49/attachment-0002.html>
