[PATCH] posix: Check for new <pthread.h> prototypes
Sebastian Huber
Tue Jul 3 09:53:02 UTC 2018
Update #3342.
Update #3343.
cpukit/configure.ac | 23 +++++++++++++++++++++++
cpukit/include/rtems/posix/pthreadimpl.h | 2 +-
cpukit/posix/src/mutexgetprioceiling.c | 10 +++++++---
cpukit/posix/src/psxtransschedparam.c | 2 +-
cpukit/posix/src/pthreadsetschedparam.c | 12 ++++++++----
5 files changed, 40 insertions(+), 9 deletions(-)
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 235241643e..0361128e1d 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -115,6 +115,29 @@ RTEMS_CHECK_FUNC([pthread_getattr_np],[
#define _GNU_SOURCE
#include <pthread.h>])
+AC_LANG_PUSH(C)
+AC_MSG_CHECKING([for pthread_mutex_getprioceiling(const pthread_mutex_t *, ...)])
+AC_COMPILE_IFELSE([AC_LANG_SOURCE([
+#include <pthread.h>
+int pthread_mutex_getprioceiling(const pthread_mutex_t *__restrict, int *);
+AC_MSG_RESULT([yes])
+AC_DEFINE(HAVE_PTHREAD_MUTEX_GETCEILING_CONST, [], [pthread_mutex_getprioceiling(const pthread_mutex_t *, ...)])
+AC_MSG_RESULT([no])
+AC_MSG_CHECKING([for pthread_setschedparam(..., const struct sched_param *)])
+int pthread_setschedparam(pthread_t, int, const struct sched_param *);
+AC_DEFINE(HAVE_PTHREAD_SETSCHEDPARAM_CONST, [], [pthread_setschedparam(..., const struct sched_param *)])
+AC_LANG_POP(C)
# Mandated by POSIX, not declared in some versions of newlib.
AC_CHECK_DECLS([getrusage],,,[#include sys/resource.h])
diff --git a/cpukit/include/rtems/posix/pthreadimpl.h b/cpukit/include/rtems/posix/pthreadimpl.h
index 3e2351e57e..e6ed1b8990 100644
--- a/cpukit/include/rtems/posix/pthreadimpl.h
+++ b/cpukit/include/rtems/posix/pthreadimpl.h
@@ -97,7 +97,7 @@ int _POSIX_Thread_Translate_to_sched_policy(
int _POSIX_Thread_Translate_sched_param(
int policy,
- struct sched_param *param,
+ const struct sched_param *param,
Thread_CPU_budget_algorithms *budget_algorithm,
Thread_CPU_budget_algorithm_callout *budget_callout
diff --git a/cpukit/posix/src/mutexgetprioceiling.c b/cpukit/posix/src/mutexgetprioceiling.c
index 544c8fbf33..3ac90d888e 100644
--- a/cpukit/posix/src/mutexgetprioceiling.c
+++ b/cpukit/posix/src/mutexgetprioceiling.c
@@ -26,8 +26,12 @@
- pthread_mutex_t *mutex,
- int *prioceiling
+#ifdef HAVE_PTHREAD_MUTEX_GETCEILING_CONST
+ const pthread_mutex_t *mutex,
+#else
+ pthread_mutex_t *mutex,
+#endif
+ int *prioceiling
POSIX_Mutex_Control *the_mutex;
@@ -38,7 +42,7 @@ int pthread_mutex_getprioceiling(
return EINVAL;
- the_mutex = _POSIX_Mutex_Get( mutex );
+ the_mutex = _POSIX_Mutex_Get( RTEMS_DECONST( pthread_mutex_t *, mutex ) );
POSIX_MUTEX_VALIDATE_OBJECT( the_mutex, flags );
_POSIX_Mutex_Acquire( the_mutex, &queue_context );
diff --git a/cpukit/posix/src/psxtransschedparam.c b/cpukit/posix/src/psxtransschedparam.c
index 86d8ff0894..0b4ce2823e 100644
--- a/cpukit/posix/src/psxtransschedparam.c
+++ b/cpukit/posix/src/psxtransschedparam.c
@@ -42,7 +42,7 @@ int _POSIX_Thread_Translate_to_sched_policy(
int policy,
diff --git a/cpukit/posix/src/pthreadsetschedparam.c b/cpukit/posix/src/pthreadsetschedparam.c
index b6854a080c..7c5b6f109d 100644
--- a/cpukit/posix/src/pthreadsetschedparam.c
+++ b/cpukit/posix/src/pthreadsetschedparam.c
@@ -33,7 +33,7 @@
static int _POSIX_Set_sched_param(
Thread_Control *the_thread,
int policy,
Thread_CPU_budget_algorithms budget_algorithm,
Thread_CPU_budget_algorithm_callout budget_callout,
Thread_queue_Context *queue_context
@@ -113,9 +113,13 @@ static int _POSIX_Set_sched_param(
- pthread_t thread,
- int policy,
+ pthread_t thread,
+ int policy,
+#ifdef HAVE_PTHREAD_SETSCHEDPARAM_CONST
+#else
+ struct sched_param *param
+#endif
Thread_CPU_budget_algorithms budget_algorithm;
2.13.7
