Gcov support in Covoar
Wed Jul 4 08:06:25 UTC 2018
On 4/7/18 5:55 pm, Vijay Kumar Banerjee wrote:
> On 4 July 2018 at 13:09, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 4/7/18 5:38 pm, Chris Johns wrote:
>     > On 4/7/18 4:52 pm, Vijay Kumar Banerjee wrote:
>     >> I'm starting this thread for discussions on the gcov support
>     >> in covoar.
>     >> Current status is that the code in it (like in GcovData.cc) remained untouched
>     >> for a long time and it had not been updated after the source tree reorganization
>     >> which is why it runs into segmentation
>     >> fault while trying to find the source files.
>     >> Joel was suggesting to copy the file gcov-io.h from the gcc
>     >> source after a license discussion here.
>     > What license the file's license?
>     Sorry .. What is the file's license?
> GPL version 3
This license is not suitable.
>     > We are aiming to have all code under the RTEMS Tools under a BSD or compatible
>     > license. Are there other options that have a more suitable license?
>     > Also, could you please explain how gcov fits into the coverage testing?
> gcov is a test coverage program by gcc that generates statement-by-statement
> profiling.
> (https://gcc.gnu.org/onlinedocs/gcc/Gcov-Intro.html)
Yes.
> once we're able to generate gcov reports we can run graphical tools like lcov or
> gcovr to generate html and xml reports with detailed coverage data.
> an example of lcov report:
> http://ltp.sourceforge.net/coverage/lcov/output/example/methods/iterate.c.gcov.html
Do you want to export gcov files from the other trace formats we handle?
How does this fit into the RTEMS Tester tool?
