[PATCH 22/29] mm, fs: get rid of PAGE_CACHE_* and page_cache_{get, release} macros
Thu Jul 5 07:49:42 UTC 2018
From: "Kirill A. Shutemov" <kirill.shutemov at linux.intel.com>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized.  And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE.  And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special.  They are
not.
The changes are pretty straight-forward:
 - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
 - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
 - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
 - page_cache_get() -> get_page();
 - page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below.  For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach.  I'll
fix them manually in a separate patch.  Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Signed-off-by: Kirill A. Shutemov <kirill.shutemov at linux.intel.com>
Acked-by: Michal Hocko <mhocko at suse.com>
Signed-off-by: Linus Torvalds <torvalds at linux-foundation.org>
4	4	cpukit/libfs/src/jffs2/src/debug.c
4	4	cpukit/libfs/src/jffs2/src/gc.c
4	4	cpukit/libfs/src/jffs2/src/nodelist.c
4	3	cpukit/libfs/src/jffs2/src/write.c
diff --git a/cpukit/libfs/src/jffs2/src/debug.c b/cpukit/libfs/src/jffs2/src/debug.c
index a5ff32240f..4ddaa42400 100644
--- a/cpukit/libfs/src/jffs2/src/debug.c
+++ b/cpukit/libfs/src/jffs2/src/debug.c
@@ -97,15 +97,15 @@ __jffs2_dbg_fragtree_paranoia_check_nolock(struct jffs2_inode_info *f)
 			   rather than mucking around with actually reading the node
 			   and checking the compression type, which is the real way
 			   to tell a hole node. */
-			if (frag->ofs & (PAGE_CACHE_SIZE-1) && frag_prev(frag)
-					&& frag_prev(frag)->size < PAGE_CACHE_SIZE && frag_prev(frag)->node) {
+			if (frag->ofs & (PAGE_SIZE-1) && frag_prev(frag)
+					&& frag_prev(frag)->size < PAGE_SIZE && frag_prev(frag)->node) {
 				JFFS2_ERROR("REF_PRISTINE node at 0x%08x had a previous non-hole frag in the same page. Tell dwmw2.\n",
 					ref_offset(fn->raw));
 				bitched = 1;
-			if ((frag->ofs+frag->size) & (PAGE_CACHE_SIZE-1) && frag_next(frag)
-					&& frag_next(frag)->size < PAGE_CACHE_SIZE && frag_next(frag)->node) {
+			if ((frag->ofs+frag->size) & (PAGE_SIZE-1) && frag_next(frag)
+					&& frag_next(frag)->size < PAGE_SIZE && frag_next(frag)->node) {
 				JFFS2_ERROR("REF_PRISTINE node at 0x%08x (%08x-%08x) had a following non-hole frag in the same page. Tell dwmw2.\n",
 				       ref_offset(fn->raw), frag->ofs, frag->ofs+frag->size);
 				bitched = 1;
diff --git a/cpukit/libfs/src/jffs2/src/gc.c b/cpukit/libfs/src/jffs2/src/gc.c
index 6206c47fb9..f557075ab8 100644
--- a/cpukit/libfs/src/jffs2/src/gc.c
+++ b/cpukit/libfs/src/jffs2/src/gc.c
@@ -554,7 +554,7 @@ static int jffs2_garbage_collect_live(struct jffs2_sb_info *c,  struct jffs2_era
 				goto upnout;
 		/* We found a datanode. Do the GC */
-		if((start >> PAGE_CACHE_SHIFT) < ((end-1) >> PAGE_CACHE_SHIFT)) {
+		if((start >> PAGE_SHIFT) < ((end-1) >> PAGE_SHIFT)) {
 			/* It crosses a page boundary. Therefore, it must be a hole. */
 			ret = jffs2_garbage_collect_hole(c, jeb, f, fn, start, end);
 		} else {
@@ -1200,8 +1200,8 @@ static int jffs2_garbage_collect_dnode(struct jffs2_sb_info *c, struct jffs2_era
 		struct jffs2_node_frag *frag;
 		uint32_t min, max;
-		min = start & ~(PAGE_CACHE_SIZE-1);
-		max = min + PAGE_CACHE_SIZE;
+		min = start & ~(PAGE_SIZE-1);
+		max = min + PAGE_SIZE;
 		frag = jffs2_lookup_node_frag(&f->fragtree, start);
@@ -1359,7 +1359,7 @@ static int jffs2_garbage_collect_dnode(struct jffs2_sb_info *c, struct jffs2_era
 		cdatalen = min_t(uint32_t, alloclen - sizeof(ri), end - offset);
 		datalen = end - offset;
-		writebuf = pg_ptr + (offset & (PAGE_CACHE_SIZE -1));
+		writebuf = pg_ptr + (offset & (PAGE_SIZE -1));
 		comprtype = jffs2_compress(c, f, writebuf, &comprbuf, &datalen, &cdatalen);
diff --git a/cpukit/libfs/src/jffs2/src/nodelist.c b/cpukit/libfs/src/jffs2/src/nodelist.c
index caf7a5614c..ee44024c92 100644
--- a/cpukit/libfs/src/jffs2/src/nodelist.c
+++ b/cpukit/libfs/src/jffs2/src/nodelist.c
@@ -92,7 +92,7 @@ uint32_t jffs2_truncate_fragtree(struct jffs2_sb_info *c, struct rb_root *list,
 	/* If the last fragment starts at the RAM page boundary, it is
 	 * REF_PRISTINE irrespective of its size. */
-	if (frag->node && (frag->ofs & (PAGE_CACHE_SIZE - 1)) == 0) {
+	if (frag->node && (frag->ofs & (PAGE_SIZE - 1)) == 0) {
 		dbg_fragtree2("marking the last fragment 0x%08x-0x%08x REF_PRISTINE.\n",
 			frag->ofs, frag->ofs + frag->size);
 		frag->node->raw->flash_offset = ref_offset(frag->node->raw) | REF_PRISTINE;
@@ -239,7 +239,7 @@ static int jffs2_add_frag_to_fragtree(struct jffs2_sb_info *c, struct rb_root *r
 		   If so, both 'this' and the new node get marked REF_NORMAL so
 		   the GC can take a look.
-		if (lastend && (lastend-1) >> PAGE_CACHE_SHIFT == newfrag->ofs >> PAGE_CACHE_SHIFT) {
+		if (lastend && (lastend-1) >> PAGE_SHIFT == newfrag->ofs >> PAGE_SHIFT) {
 			if (this->node)
 				mark_ref_normal(this->node->raw);
 			mark_ref_normal(newfrag->node->raw);
@@ -384,7 +384,7 @@ int jffs2_add_full_dnode_to_inode(struct jffs2_sb_info *c, struct jffs2_inode_in
 	/* If we now share a page with other nodes, mark either previous
 	   or next node REF_NORMAL, as appropriate.  */
-	if (newfrag->ofs & (PAGE_CACHE_SIZE-1)) {
+	if (newfrag->ofs & (PAGE_SIZE-1)) {
 		struct jffs2_node_frag *prev = frag_prev(newfrag);
 		mark_ref_normal(fn->raw);
@@ -393,7 +393,7 @@ int jffs2_add_full_dnode_to_inode(struct jffs2_sb_info *c, struct jffs2_inode_in
 			mark_ref_normal(prev->node->raw);
-	if ((newfrag->ofs+newfrag->size) & (PAGE_CACHE_SIZE-1)) {
+	if ((newfrag->ofs+newfrag->size) & (PAGE_SIZE-1)) {
 		struct jffs2_node_frag *next = frag_next(newfrag);
 		if (next) {
diff --git a/cpukit/libfs/src/jffs2/src/write.c b/cpukit/libfs/src/jffs2/src/write.c
index 1b14cc650d..ac3ec295d5 100644
--- a/cpukit/libfs/src/jffs2/src/write.c
+++ b/cpukit/libfs/src/jffs2/src/write.c
@@ -174,8 +174,8 @@ struct jffs2_full_dnode *jffs2_write_dnode(struct jffs2_sb_info *c, struct jffs2
 	   beginning of a page and runs to the end of the file, or if
 	   it's a hole node, mark it REF_PRISTINE, else REF_NORMAL.
-	if ((je32_to_cpu(ri->dsize) >= PAGE_CACHE_SIZE) ||
-	    ( ((je32_to_cpu(ri->offset)&(PAGE_CACHE_SIZE-1))==0) &&
+	if ((je32_to_cpu(ri->dsize) >= PAGE_SIZE) ||
+	    ( ((je32_to_cpu(ri->offset)&(PAGE_SIZE-1))==0) &&
 	      (je32_to_cpu(ri->dsize)+je32_to_cpu(ri->offset) ==  je32_to_cpu(ri->isize)))) {
 		flash_ofs |= REF_PRISTINE;
 	} else {
@@ -368,7 +368,8 @@ int jffs2_write_inode_range(struct jffs2_sb_info *c, struct jffs2_inode_info *f,
 			break;
 		mutex_lock(&f->sem);
-		datalen = min_t(uint32_t, writelen, PAGE_CACHE_SIZE - (offset & (PAGE_CACHE_SIZE-1)));
+		datalen = min_t(uint32_t, writelen,
+				PAGE_SIZE - (offset & (PAGE_SIZE-1)));
 		cdatalen = min_t(uint32_t, alloclen - sizeof(*ri), datalen);
 		comprtype = jffs2_compress(c, f, buf, &comprbuf, &datalen, &cdatalen);
2.13.7
