[PATCH 20/29] Fix directory hardlinks from deleted directories
Thu Jul 5 07:49:40 UTC 2018
From: David Woodhouse <David.Woodhouse at intel.com>
When a directory is deleted, we don't take too much care about killing off
all the dirents that belong to it — on the basis that on remount, the scan
will conclude that the directory is dead anyway.
This doesn't work though, when the deleted directory contained a child
directory which was moved *out*. In the early stages of the fs build
we can then end up with an apparent hard link, with the child directory
appearing both in its true location, and as a child of the original
directory which are this stage of the mount process we don't *yet* know
is defunct.
To resolve this, take out the early special-casing of the "directories
shall not have hard links" rule in jffs2_build_inode_pass1(), and let the
normal nlink processing happen for directories as well as other inodes.
Then later in the build process we can set ic->pino_nlink to the parent
inode#, as is required for directories during normal operaton, instead
of the nlink. And complain only *then* about hard links which are still
in evidence even after killing off all the unreachable paths.
Reported-by: Liu Song <liu.song11 at zte.com.cn>
Signed-off-by: David Woodhouse <David.Woodhouse at intel.com>
Cc: stable at vger.kernel.org
57	18	cpukit/libfs/src/jffs2/src/build.c
5	1	cpukit/libfs/src/jffs2/src/nodelist.h
diff --git a/cpukit/libfs/src/jffs2/src/build.c b/cpukit/libfs/src/jffs2/src/build.c
index cbc424283c..d35bc83bbb 100644
--- a/cpukit/libfs/src/jffs2/src/build.c
+++ b/cpukit/libfs/src/jffs2/src/build.c
@@ -52,7 +52,8 @@ next_inode(int *i, struct jffs2_inode_cache *ic, struct jffs2_sb_info *c)
 static void jffs2_build_inode_pass1(struct jffs2_sb_info *c,
-				    struct jffs2_inode_cache *ic)
+				    struct jffs2_inode_cache *ic,
+				    int *dir_hardlinks)
 	struct jffs2_full_dirent *fd;
@@ -71,19 +72,21 @@ static void jffs2_build_inode_pass1(struct jffs2_sb_info *c,
 			dbg_fsbuild("child \"%s\" (ino #%u) of dir ino #%u doesn't exist!\n",
 				  fd->name, fd->ino, ic->ino);
 			jffs2_mark_node_obsolete(c, fd->raw);
+			/* Clear the ic/raw union so it doesn't cause problems later. */
+			fd->ic = NULL;
 			continue;
+		/* From this point, fd->raw is no longer used so we can set fd->ic */
+		fd->ic = child_ic;
+		child_ic->pino_nlink++;
+		/* If we appear (at this stage) to have hard-linked directories,
+		 * set a flag to trigger a scan later */
 		if (fd->type == DT_DIR) {
-			if (child_ic->pino_nlink) {
-				JFFS2_ERROR("child dir \"%s\" (ino #%u) of dir ino #%u appears to be a hard link\n",
-					    fd->name, fd->ino, ic->ino);
-				/* TODO: What do we do about it? */
-			} else {
-				child_ic->pino_nlink = ic->ino;
-		} else
-			child_ic->pino_nlink++;
+			child_ic->flags |= INO_FLAGS_IS_DIR;
+			if (child_ic->pino_nlink > 1)
+				*dir_hardlinks = 1;
 		dbg_fsbuild("increased nlink for child \"%s\" (ino #%u)\n", fd->name, fd->ino);
 		/* Can't free scan_dents so far. We might need them in pass 2 */
@@ -97,8 +100,7 @@ static void jffs2_build_inode_pass1(struct jffs2_sb_info *c,
 static int jffs2_build_filesystem(struct jffs2_sb_info *c)
-	int ret;
-	int i;
+	int ret, i, dir_hardlinks = 0;
 	struct jffs2_inode_cache *ic;
 	struct jffs2_full_dirent *dead_fds = NULL;
@@ -122,7 +124,7 @@ static int jffs2_build_filesystem(struct jffs2_sb_info *c)
 	/* Now scan the directory tree, increasing nlink according to every dirent found. */
 	for_each_inode(i, c, ic) {
 		if (ic->scan_dents) {
-			jffs2_build_inode_pass1(c, ic);
+			jffs2_build_inode_pass1(c, ic, &dir_hardlinks);
 			cond_resched();
@@ -158,6 +160,20 @@ static int jffs2_build_filesystem(struct jffs2_sb_info *c)
 	dbg_fsbuild("pass 2a complete\n");
+	if (dir_hardlinks) {
+		/* If we detected directory hardlinks earlier, *hopefully*
+		 * they are gone now because some of the links were from
+		 * dead directories which still had some old dirents lying
+		 * around and not yet garbage-collected, but which have
+		 * been discarded above. So clear the pino_nlink field
+		 * in each directory, so that the final scan below can
+		 * print appropriate warnings. */
+		for_each_inode(i, c, ic) {
+			if (ic->flags & INO_FLAGS_IS_DIR)
+				ic->pino_nlink = 0;
 	dbg_fsbuild("freeing temporary data structures\n");
 	/* Finally, we can scan again and free the dirent structs */
@@ -165,6 +181,33 @@ static int jffs2_build_filesystem(struct jffs2_sb_info *c)
 		while(ic->scan_dents) {
 			fd = ic->scan_dents;
 			ic->scan_dents = fd->next;
+			/* We do use the pino_nlink field to count nlink of
+			 * directories during fs build, so set it to the
+			 * parent ino# now. Now that there's hopefully only
+			 * one. */
+			if (fd->type == DT_DIR) {
+				if (!fd->ic) {
+					/* We'll have complained about it and marked the coresponding
+					   raw node obsolete already. Just skip it. */
+					continue;
+				/* We *have* to have set this in jffs2_build_inode_pass1() */
+				BUG_ON(!(fd->ic->flags & INO_FLAGS_IS_DIR));
+				/* We clear ic->pino_nlink ∀ directories' ic *only* if dir_hardlinks
+				 * is set. Otherwise, we know this should never trigger anyway, so
+				 * we don't do the check. And ic->pino_nlink still contains the nlink
+				 * value (which is 1). */
+				if (dir_hardlinks && fd->ic->pino_nlink) {
+					JFFS2_ERROR("child dir \"%s\" (ino #%u) of dir ino #%u is also hard linked from dir ino #%u\n",
+						    fd->name, fd->ino, ic->ino, fd->ic->pino_nlink);
+					/* Should we unlink it from its previous parent? */
+				/* For directories, ic->pino_nlink holds that parent inode # */
+				fd->ic->pino_nlink = ic->ino;
 			jffs2_free_full_dirent(fd);
 		ic->scan_dents = NULL;
@@ -243,11 +286,7 @@ static void jffs2_build_remove_unlinked_inode(struct jffs2_sb_info *c,
 			/* Reduce nlink of the child. If it's now zero, stick it on the
 			   dead_fds list to be cleaned up later. Else just free the fd */
-			if (fd->type == DT_DIR)
-				child_ic->pino_nlink = 0;
-			else
-				child_ic->pino_nlink--;
+			child_ic->pino_nlink--;
 			if (!child_ic->pino_nlink) {
 				dbg_fsbuild("inode #%u (\"%s\") now has no links; adding to dead_fds list.\n",
diff --git a/cpukit/libfs/src/jffs2/src/nodelist.h b/cpukit/libfs/src/jffs2/src/nodelist.h
index a94d3ef32b..143f60dbcb 100644
--- a/cpukit/libfs/src/jffs2/src/nodelist.h
+++ b/cpukit/libfs/src/jffs2/src/nodelist.h
@@ -194,6 +194,7 @@ struct jffs2_inode_cache {
 #define INO_STATE_CLEARING	6	/* In clear_inode() */
 #define INO_FLAGS_XATTR_CHECKED	0x01	/* has no duplicate xattr_ref */
+#define INO_FLAGS_IS_DIR	0x02	/* is a directory */
 #define RAWNODE_CLASS_INODE_CACHE	0
 #define RAWNODE_CLASS_XATTR_DATUM	1
@@ -249,7 +250,10 @@ struct jffs2_readinode_info
-	struct jffs2_raw_node_ref *raw;
+	union {
+		struct jffs2_raw_node_ref *raw;
+		struct jffs2_inode_cache *ic; /* Just during part of build */
 	struct jffs2_full_dirent *next;
 	uint32_t version;
 	uint32_t ino; /* == zero for unlink */
2.13.7
