[PATCH 19/29] jffs2: Fix page lock / f->sem deadlock
Thu Jul 5 07:49:39 UTC 2018
From: David Woodhouse <David.Woodhouse at intel.com>
With this fix, all code paths should now be obtaining the page lock before
f->sem.
Reported-by: Szabó Tamás <sztomi89 at gmail.com>
Tested-by: Thomas Betker <thomas.betker at rohde-schwarz.com>
Signed-off-by: David Woodhouse <David.Woodhouse at intel.com>
Cc: stable at vger.kernel.org
10	7	cpukit/libfs/src/jffs2/src/gc.c
diff --git a/cpukit/libfs/src/jffs2/src/gc.c b/cpukit/libfs/src/jffs2/src/gc.c
index 22963dc3a6..2c945e7621 100644
--- a/cpukit/libfs/src/jffs2/src/gc.c
+++ b/cpukit/libfs/src/jffs2/src/gc.c
@@ -1304,14 +1304,17 @@ static int jffs2_garbage_collect_dnode(struct jffs2_sb_info *c, struct jffs2_era
 		BUG_ON(start > orig_start);
-	/* First, use readpage() to read the appropriate page into the page cache */
-	/* Q: What happens if we actually try to GC the _same_ page for which commit_write()
-	 *    triggered garbage collection in the first place?
-	 * A: I _think_ it's OK. read_cache_page shouldn't deadlock, we'll write out the
-	 *    page OK. We'll actually write it out again in commit_write, which is a little
-	 *    suboptimal, but at least we're correct.
+	/* The rules state that we must obtain the page lock *before* f->sem, so
+	 * drop f->sem temporarily. Since we also hold c->alloc_sem, nothing's
+	 * actually going to *change* so we're safe; we only allow reading.
+	 * It is important to note that jffs2_write_begin() will ensure that its
+	 * page is marked Uptodate before allocating space. That means that if we
+	 * end up here trying to GC the *same* page that jffs2_write_begin() is
+	 * trying to write out, read_cache_page() will not deadlock. */
+	mutex_unlock(&f->sem);
 	pg_ptr = jffs2_gc_fetch_page(c, f, start, &pg);
+	mutex_lock(&f->sem);
 	if (IS_ERR(pg_ptr)) {
 		pr_warn("read_cache_page() returned error: %ld\n",
2.13.7
