[PATCH 05/29] fs/jffs2: use rbtree postorder iteration helper instead of opencoding
Thu Jul 5 07:49:25 UTC 2018
Use rbtree_postorder_for_each_entry_safe() to destroy the rbtree instead
of opencoding an alternate postorder iteration that modifies the tree
Signed-off-by: Cody P Schafer <cody at linux.vnet.ibm.com>
Cc: Michel Lespinasse <walken at google.com>
Cc: Jan Kara <jack at suse.cz>
Cc: David Woodhouse <dwmw2 at infradead.org>
Signed-off-by: Andrew Morton <akpm at linux-foundation.org>
Signed-off-by: Linus Torvalds <torvalds at linux-foundation.org>
2	26	cpukit/libfs/src/jffs2/src/nodelist.c
3	23	cpukit/libfs/src/jffs2/src/readinode.c
diff --git a/cpukit/libfs/src/jffs2/src/nodelist.c b/cpukit/libfs/src/jffs2/src/nodelist.c
index f0ad570b6f..caf7a5614c 100644
--- a/cpukit/libfs/src/jffs2/src/nodelist.c
+++ b/cpukit/libfs/src/jffs2/src/nodelist.c
@@ -566,25 +566,10 @@ struct jffs2_node_frag *jffs2_lookup_node_frag(struct rb_root *fragtree, uint32_
    they're killed. */
 void jffs2_kill_fragtree(struct rb_root *root, struct jffs2_sb_info *c)
-	struct jffs2_node_frag *frag;
-	struct jffs2_node_frag *parent;
-	if (!root->rb_node)
-		return;
+	struct jffs2_node_frag *frag, *next;
 	dbg_fragtree("killing\n");
-	frag = (rb_entry(root->rb_node, struct jffs2_node_frag, rb));
-	while(frag) {
-		if (frag->rb.rb_left) {
-			frag = frag_left(frag);
-			continue;
-		if (frag->rb.rb_right) {
-			frag = frag_right(frag);
-			continue;
+	rbtree_postorder_for_each_entry_safe(frag, next, root, rb) {
 		if (frag->node && !(--frag->node->frags)) {
 			/* Not a hole, and it's the final remaining frag
 			   of this node. Free the node */
@@ -593,17 +578,8 @@ void jffs2_kill_fragtree(struct rb_root *root, struct jffs2_sb_info *c)
 			jffs2_free_full_dnode(frag->node);
-		parent = frag_parent(frag);
-		if (parent) {
-			if (frag_left(parent) == frag)
-				parent->rb.rb_left = NULL;
-			else
-				parent->rb.rb_right = NULL;
 		jffs2_free_node_frag(frag);
-		frag = parent;
 		cond_resched();
diff --git a/cpukit/libfs/src/jffs2/src/readinode.c b/cpukit/libfs/src/jffs2/src/readinode.c
index 9147169a0a..70da35a246 100644
--- a/cpukit/libfs/src/jffs2/src/readinode.c
+++ b/cpukit/libfs/src/jffs2/src/readinode.c
@@ -552,33 +552,13 @@ static int jffs2_build_inode_fragtree(struct jffs2_sb_info *c,
 static void jffs2_free_tmp_dnode_info_list(struct rb_root *list)
-	struct rb_node *this;
-	struct jffs2_tmp_dnode_info *tn;
-	this = list->rb_node;
+	struct jffs2_tmp_dnode_info *tn, *next;
-	/* Now at bottom of tree */
-	while (this) {
-		if (this->rb_left)
-			this = this->rb_left;
-		else if (this->rb_right)
-			this = this->rb_right;
-		else {
-			tn = rb_entry(this, struct jffs2_tmp_dnode_info, rb);
+	rbtree_postorder_for_each_entry_safe(tn, next, list, rb) {
 			jffs2_free_full_dnode(tn->fn);
 			jffs2_free_tmp_dnode_info(tn);
-			this = rb_parent(this);
-			if (!this)
-				break;
-			if (this->rb_left == &tn->rb)
-				this->rb_left = NULL;
-			else if (this->rb_right == &tn->rb)
-				this->rb_right = NULL;
-			else BUG();
 	*list = RB_ROOT;
2.13.7
