[PATCH 16/29] jffs2: fix unbalanced locking
Thu Jul 5 07:49:36 UTC 2018
From: Brian Norris <computersforpeace at gmail.com>
Li Zefan reported an unbalanced locking issue, found by his
internal debugging feature on runtime. The particular case he was
looking at doesn't lead to a deadlock, as the structure that this lock
is embedded in is freed on error. But we should straighten out the error
handling.
Because several callers of jffs2_do_read_inode_internal() /
jffs2_do_read_inode() already handle the locking/unlocking and inode
clearing at their own level, let's just push any unlocks/clearing down
to the caller. This consistency is much easier to verify.
Reported-by: Li Zefan <lizefan at huawei.com>
Cc: David Woodhouse <dwmw2 at infradead.org>
Cc: Artem Bityutskiy <artem.bityutskiy at linux.intel.com>
Cc: Andrew Morton <akpm at linux-foundation.org>
Signed-off-by: Brian Norris <computersforpeace at gmail.com>
4	23	cpukit/libfs/src/jffs2/src/readinode.c
diff --git a/cpukit/libfs/src/jffs2/src/readinode.c b/cpukit/libfs/src/jffs2/src/readinode.c
index 3314a61885..69ab7709f8 100644
--- a/cpukit/libfs/src/jffs2/src/readinode.c
+++ b/cpukit/libfs/src/jffs2/src/readinode.c
@@ -1212,17 +1212,13 @@ static int jffs2_do_read_inode_internal(struct jffs2_sb_info *c,
 		JFFS2_ERROR("failed to read from flash: error %d, %zd of %zd bytes read\n",
 			ret, retlen, sizeof(*latest_node));
 		/* FIXME: If this fails, there seems to be a memory leak. Find it. */
-		mutex_unlock(&f->sem);
-		jffs2_do_clear_inode(c, f);
-		return ret?ret:-EIO;
+		return ret ? ret : -EIO;
 	crc = crc32(0, latest_node, sizeof(*latest_node)-8);
 	if (crc != je32_to_cpu(latest_node->node_crc)) {
 		JFFS2_ERROR("CRC failed for read_inode of inode %u at physical location 0x%x\n",
 			f->inocache->ino, ref_offset(rii.latest_ref));
 		return -EIO;
@@ -1259,16 +1255,11 @@ static int jffs2_do_read_inode_internal(struct jffs2_sb_info *c,
 			 * keep in RAM to facilitate quick follow symlink
 			 * operation. */
 			uint32_t csize = je32_to_cpu(latest_node->csize);
-			if (csize > JFFS2_MAX_NAME_LEN) {
+			if (csize > JFFS2_MAX_NAME_LEN)
 				return -ENAMETOOLONG;
 			f->target = kmalloc(csize + 1, GFP_KERNEL);
 			if (!f->target) {
 				JFFS2_ERROR("can't allocate %u bytes of memory for the symlink target path cache\n", csize);
 				return -ENOMEM;
@@ -1280,8 +1271,6 @@ static int jffs2_do_read_inode_internal(struct jffs2_sb_info *c,
 					ret = -EIO;
 				kfree(f->target);
 				f->target = NULL;
 				return ret;
@@ -1298,15 +1287,11 @@ static int jffs2_do_read_inode_internal(struct jffs2_sb_info *c,
 		if (f->metadata) {
 			JFFS2_ERROR("Argh. Special inode #%u with mode 0%o had metadata node\n",
 			       f->inocache->ino, jemode_to_cpu(latest_node->mode));
 			return -EIO;
 		if (!frag_first(&f->fragtree)) {
 			JFFS2_ERROR("Argh. Special inode #%u with mode 0%o has no fragments\n",
 			return -EIO;
 		/* ASSERT: f->fraglist != NULL */
@@ -1314,8 +1299,6 @@ static int jffs2_do_read_inode_internal(struct jffs2_sb_info *c,
 			JFFS2_ERROR("Argh. Special inode #%u with mode 0x%x had more than one node\n",
 			/* FIXME: Deal with it - check crc32, check for duplicate node, check times and discard the older one */
 			return -EIO;
 		/* OK. We're happy */
@@ -1409,10 +1392,8 @@ int jffs2_do_crccheck_inode(struct jffs2_sb_info *c, struct jffs2_inode_cache *i
 	f->inocache = ic;
 	ret = jffs2_do_read_inode_internal(c, f, &n);
-	if (!ret) {
+	mutex_unlock(&f->sem);
+	jffs2_do_clear_inode(c, f);
 	jffs2_xattr_do_crccheck_inode(c, ic);
 	kfree (f);
 	return ret;
2.13.7
