[PATCH 13/29] jffs2: Drop bogus if in comment
Thu Jul 5 07:49:33 UTC 2018
From: Geert Uytterhoeven <geert+renesas at glider.be>
Signed-off-by: Geert Uytterhoeven <geert+renesas at glider.be>
Cc: David Woodhouse <dwmw2 at infradead.org>
Cc: linux-mtd at lists.infradead.org
Signed-off-by: Brian Norris <computersforpeace at gmail.com>
1	1	cpukit/libfs/src/jffs2/src/readinode.c
diff --git a/cpukit/libfs/src/jffs2/src/readinode.c b/cpukit/libfs/src/jffs2/src/readinode.c
index 70da35a246..3314a61885 100644
--- a/cpukit/libfs/src/jffs2/src/readinode.c
+++ b/cpukit/libfs/src/jffs2/src/readinode.c
@@ -226,7 +226,7 @@ static int jffs2_add_tn_to_tree(struct jffs2_sb_info *c,
 	dbg_readinode("insert fragment %#04x-%#04x, ver %u at %08x\n", tn->fn->ofs, fn_end, tn->version, ref_offset(tn->fn->raw));
-	/* If a node has zero dsize, we only have to keep if it if it might be the
+	/* If a node has zero dsize, we only have to keep it if it might be the
 	   node with highest version -- i.e. the one which will end up as f->metadata.
 	   Note that such nodes won't be REF_UNCHECKED since there are no data to
 	   check anyway. */
2.13.7
