[PATCH 27/29] mtd: Stop assuming mtd_erase() is asynchronous
Thu Jul 5 07:49:47 UTC 2018
From: Boris Brezillon <boris.brezillon at bootlin.com>
None of the mtd->_erase() implementations work in an asynchronous manner,
so let's simplify MTD users that call mtd_erase(). All they need to do
is check the value returned by mtd_erase() and assume that != 0 means
failure.
Signed-off-by: Boris Brezillon <boris.brezillon at bootlin.com>
Reviewed-by: Richard Weinberger <richard at nod.at>
5	31	cpukit/libfs/src/jffs2/src/erase.c
diff --git a/cpukit/libfs/src/jffs2/src/erase.c b/cpukit/libfs/src/jffs2/src/erase.c
index 323848cc75..973d3ab87e 100644
--- a/cpukit/libfs/src/jffs2/src/erase.c
+++ b/cpukit/libfs/src/jffs2/src/erase.c
@@ -23,14 +23,6 @@
 #include <linux/pagemap.h>
 #include "nodelist.h"
-struct erase_priv_struct {
-	struct jffs2_eraseblock *jeb;
-	struct jffs2_sb_info *c;
-#ifndef __ECOS
-static void jffs2_erase_callback(struct erase_info *);
-#endif
 static void jffs2_erase_failed(struct jffs2_sb_info *c, struct jffs2_eraseblock *jeb, uint32_t bad_offset);
 static void jffs2_erase_succeeded(struct jffs2_sb_info *c, struct jffs2_eraseblock *jeb);
 static void jffs2_mark_erased_block(struct jffs2_sb_info *c, struct jffs2_eraseblock *jeb);
@@ -53,7 +45,7 @@ static void jffs2_erase_block(struct jffs2_sb_info *c,
 	jffs2_dbg(1, "%s(): erase block %#08x (range %#08x-%#08x)\n",
 		  __func__,
 		  jeb->offset, jeb->offset, jeb->offset + c->sector_size);
-	instr = kmalloc(sizeof(struct erase_info) + sizeof(struct erase_priv_struct), GFP_KERNEL);
+	instr = kmalloc(sizeof(struct erase_info), GFP_KERNEL);
 	if (!instr) {
 		pr_warn("kmalloc for struct erase_info in jffs2_erase_block failed. Refiling block for later\n");
 		mutex_lock(&c->erase_free_sem);
@@ -72,15 +64,13 @@ static void jffs2_erase_block(struct jffs2_sb_info *c,
 	instr->mtd = c->mtd;
 	instr->addr = jeb->offset;
 	instr->len = c->sector_size;
-	instr->callback = jffs2_erase_callback;
-	instr->priv = (unsigned long)(&instr[1]);
-	((struct erase_priv_struct *)instr->priv)->jeb = jeb;
-	((struct erase_priv_struct *)instr->priv)->c = c;
 	ret = mtd_erase(c->mtd, instr);
-	if (!ret)
+	if (!ret) {
+		jffs2_erase_succeeded(c, jeb);
+		kfree(instr);
 		return;
 	bad_offset = instr->fail_addr;
 	kfree(instr);
@@ -216,22 +206,6 @@ static void jffs2_erase_failed(struct jffs2_sb_info *c, struct jffs2_eraseblock
 	wake_up(&c->erase_wait);
-#ifndef __ECOS
-static void jffs2_erase_callback(struct erase_info *instr)
-	struct erase_priv_struct *priv = (void *)instr->priv;
-	if(instr->state != MTD_ERASE_DONE) {
-		pr_warn("Erase at 0x%08llx finished, but state != MTD_ERASE_DONE. State is 0x%x instead.\n",
-			(unsigned long long)instr->addr, instr->state);
-		jffs2_erase_failed(priv->c, priv->jeb, instr->fail_addr);
-	} else {
-		jffs2_erase_succeeded(priv->c, priv->jeb);
-	kfree(instr);
-#endif /* !__ECOS */
 /* Hmmm. Maybe we should accept the extra space it takes and make
    this a standard doubly-linked list? */
 static inline void jffs2_remove_node_refs_from_ino_list(struct jffs2_sb_info *c,
2.13.7
