[PATCH 06/29] jffs2: use generic posix ACL infrastructure
Thu Jul 5 07:49:26 UTC 2018
Also don't bother to set up a .get_acl method for symlinks as we do not
support access control (ACLs or even mode bits) for symlinks in Linux.
Signed-off-by: Christoph Hellwig <hch at lst.de>
Signed-off-by: Al Viro <viro at zeniv.linux.org.uk>
2	5	cpukit/libfs/src/jffs2/src/acl.h
diff --git a/cpukit/libfs/src/jffs2/src/acl.h b/cpukit/libfs/src/jffs2/src/acl.h
index 9b477246f2..2e2b5745c3 100644
--- a/cpukit/libfs/src/jffs2/src/acl.h
+++ b/cpukit/libfs/src/jffs2/src/acl.h
@@ -27,17 +27,14 @@ struct jffs2_acl_header {
 #ifdef CONFIG_JFFS2_FS_POSIX_ACL
 struct posix_acl *jffs2_get_acl(struct inode *inode, int type);
-extern int jffs2_acl_chmod(struct inode *);
+int jffs2_set_acl(struct inode *inode, struct posix_acl *acl, int type);
 extern int jffs2_init_acl_pre(struct inode *, struct inode *, umode_t *);
 extern int jffs2_init_acl_post(struct inode *);
-extern const struct xattr_handler jffs2_acl_access_xattr_handler;
-extern const struct xattr_handler jffs2_acl_default_xattr_handler;
 #else
 #define jffs2_get_acl				(NULL)
-#define jffs2_acl_chmod(inode)			(0)
+#define jffs2_set_acl				(NULL)
 #define jffs2_init_acl_pre(dir_i,inode,mode)	(0)
 #define jffs2_init_acl_post(inode)		(0)
2.13.7
