[PATCH 08/29] jffs2: avoid soft-lockup in jffs2_reserve_space_gc()
Thu Jul 5 07:49:28 UTC 2018
We triggered soft-lockup under stress test on 2.6.34 kernel.
BUG: soft lockup - CPU#1 stuck for 60009ms! [lockf2.test:14488]
[<bf09a4d4>] (jffs2_do_reserve_space+0x420/0x440 [jffs2])
[<bf09a528>] (jffs2_reserve_space_gc+0x34/0x78 [jffs2])
[<bf0a1350>] (jffs2_garbage_collect_dnode.isra.3+0x264/0x478 [jffs2])
[<bf0a2078>] (jffs2_garbage_collect_pass+0x9c0/0xe4c [jffs2])
[<bf09a670>] (jffs2_reserve_space+0x104/0x2a8 [jffs2])
[<bf09dc48>] (jffs2_write_inode_range+0x5c/0x4d4 [jffs2])
[<bf097d8c>] (jffs2_write_end+0x198/0x2c0 [jffs2])
[<c00e00a4>] (generic_file_buffered_write+0x158/0x200)
[<c00e14f4>] (__generic_file_aio_write+0x3a4/0x414)
[<c00e15c0>] (generic_file_aio_write+0x5c/0xbc)
[<c012334c>] (do_sync_write+0x98/0xd4)
[<c0123a84>] (vfs_write+0xa8/0x150)
[<c0123d74>] (sys_write+0x3c/0xc0)]
Fix this by adding a cond_resched() in the while loop.
[akpm at linux-foundation.org: don't initialize `ret']
Signed-off-by: Li Zefan <lizefan at huawei.com>
Cc: David Woodhouse <dwmw2 at infradead.org>
Cc: Artem Bityutskiy <artem.bityutskiy at linux.intel.com>
Cc: <stable at vger.kernel.org>
Signed-off-by: Andrew Morton <akpm at linux-foundation.org>
Signed-off-by: Brian Norris <computersforpeace at gmail.com>
9	4	cpukit/libfs/src/jffs2/src/nodemgmt.c
diff --git a/cpukit/libfs/src/jffs2/src/nodemgmt.c b/cpukit/libfs/src/jffs2/src/nodemgmt.c
index 6cb8dc4d6f..012a4f30d0 100644
--- a/cpukit/libfs/src/jffs2/src/nodemgmt.c
+++ b/cpukit/libfs/src/jffs2/src/nodemgmt.c
@@ -214,20 +214,25 @@ out:
 int jffs2_reserve_space_gc(struct jffs2_sb_info *c, uint32_t minsize,
 			   uint32_t *len, uint32_t sumsize)
-	int ret = -EAGAIN;
+	int ret;
 	minsize = PAD(minsize);
 	jffs2_dbg(1, "%s(): Requested 0x%x bytes\n", __func__, minsize);
-	spin_lock(&c->erase_completion_lock);
-	while(ret == -EAGAIN) {
+	while (true) {
+		spin_lock(&c->erase_completion_lock);
 		ret = jffs2_do_reserve_space(c, minsize, len, sumsize);
 		if (ret) {
 			jffs2_dbg(1, "%s(): looping, ret is %d\n",
 				  __func__, ret);
+		spin_unlock(&c->erase_completion_lock);
+		if (ret == -EAGAIN)
+			cond_resched();
+		else
+			break;
-	spin_unlock(&c->erase_completion_lock);
 	if (!ret)
 		ret = jffs2_prealloc_raw_node_refs(c, c->nextblock, 1);
2.13.7
