[PATCH 03/29] linux: Simplify <linux/rbtree.h>
Thu Jul 5 07:49:23 UTC 2018
Remove the placeholder struct rb_node and use RBTree_Node directly via
some C pre-processor defines to adjust the member names.
Update #3465.
37	45	cpukit/include/linux/rbtree.h
2	2	cpukit/libfs/src/jffs2/src/readinode.c
diff --git a/cpukit/include/linux/rbtree.h b/cpukit/include/linux/rbtree.h
index 2268434939..e1da2c7b9a 100644
--- a/cpukit/include/linux/rbtree.h
+++ b/cpukit/include/linux/rbtree.h
@@ -17,40 +17,36 @@
 #include <rtems/score/rbtree.h>
-struct rb_node {
-  struct rb_node *rb_left;
-  struct rb_node *rb_right;
-  struct rb_node *rb_parent;
-  int rb_color;
-RTEMS_STATIC_ASSERT(
-  sizeof( struct rb_node ) == sizeof( RBTree_Node ),
-  rb_node_size
-  offsetof( struct rb_node, rb_left ) == offsetof( RBTree_Node, Node.rbe_left ),
-  rb_node_left
+#define rb_node RBTree_Node
-  offsetof( struct rb_node, rb_right ) == offsetof( RBTree_Node, Node.rbe_right ),
-  rb_node_right
+#define rb_left Node.rbe_left
-  offsetof( struct rb_node, rb_parent ) == offsetof( RBTree_Node, Node.rbe_parent ),
-  rb_node_parent
-  offsetof( struct rb_node, rb_color ) == offsetof( RBTree_Node, Node.rbe_color ),
-  rb_node_color
+#define rb_right Node.rbe_right
+ * Getting rid of this placeholder structure is a bit difficult.  The use of
+ * this placeholder struct may lead to bugs with link-time optimization due to
+ * a strict aliasing violation.
+ * A common use of this API is a direct access of the rb_node member to get the
+ * root node of the tree. So, this cannot be changed.
+ * The red-black tree implementation is provided by <sys/tree.h> and we have
+ * struct RBTree_Control {
+ *   struct RBTree_Node *rbh_root;
+ * The member name rbh_root is fixed by the <sys/tree.h> API.  To use
+ * RBTree_Control directly we would need two defines:
+ * #define rb_root RBTree_Control
+ * #define rb_node rbh_root
+ * We already have an rb_node define to RBTree_Node, see above.
 struct rb_root {
-  struct rb_node *rb_node;
+  RBTree_Node *rb_node;
@@ -70,32 +66,32 @@ RTEMS_STATIC_ASSERT(
 static inline void rb_insert_color( struct rb_node *node, struct rb_root *root)
-  _RBTree_Insert_color( (RBTree_Control *) root, (RBTree_Node *) node );
+  _RBTree_Insert_color( (RBTree_Control *) root, node );
 static inline void rb_erase( struct rb_node *node, struct rb_root *root )
-  _RBTree_Extract( (RBTree_Control *) root, (RBTree_Node *) node );
+  _RBTree_Extract( (RBTree_Control *) root, node );
 static inline struct rb_node *rb_next( struct rb_node *node )
-  return (struct rb_node *) _RBTree_Successor( (RBTree_Node *) node );
+  return _RBTree_Successor( node );
 static inline struct rb_node *rb_prev( struct rb_node *node )
-  return (struct rb_node *) _RBTree_Predecessor( (RBTree_Node *) node );
+  return _RBTree_Predecessor( node );
 static inline struct rb_node *rb_first( struct rb_root *root )
-  return (struct rb_node *) _RBTree_Minimum( (RBTree_Control *) root );
+  return _RBTree_Minimum( (RBTree_Control *) root );
 static inline struct rb_node *rb_last( struct rb_root *root )
-  return (struct rb_node *) _RBTree_Maximum( (RBTree_Control *) root );
+  return _RBTree_Maximum( (RBTree_Control *) root );
 static inline void rb_replace_node(
@@ -106,8 +102,8 @@ static inline void rb_replace_node(
   _RBTree_Replace_node(
-    (RBTree_Node *) victim,
-    (RBTree_Node *) replacement
+    victim,
+    replacement
@@ -117,17 +113,13 @@ static inline void rb_link_node(
   struct rb_node **link
-  _RBTree_Initialize_node( (RBTree_Node *) node );
-  _RBTree_Add_child(
-    (RBTree_Node *) node,
-    (RBTree_Node *) parent,
-    (RBTree_Node **) link
+  _RBTree_Initialize_node( node );
+  _RBTree_Add_child( node, parent, link );
 static inline struct rb_node *rb_parent( struct rb_node *node )
-  return (struct rb_node *) _RBTree_Parent( (RBTree_Node *) node );
+  return _RBTree_Parent( node );
 #endif /* _LINUX_RBTREE_H */
diff --git a/cpukit/libfs/src/jffs2/src/readinode.c b/cpukit/libfs/src/jffs2/src/readinode.c
index a166da9c69..9147169a0a 100644
--- a/cpukit/libfs/src/jffs2/src/readinode.c
+++ b/cpukit/libfs/src/jffs2/src/readinode.c
@@ -422,8 +422,8 @@ static void eat_last(struct rb_root *root, struct rb_node *node)
 		node->rb_left->__rb_parent_color = node->__rb_parent_color;
 #else /* __rtems__ */
-		node->rb_left->rb_parent = node->rb_parent;
-		node->rb_left->rb_color = node->rb_color;
+		node->rb_left->Node.rbe_parent = node->Node.rbe_parent;
+		node->rb_left->Node.rbe_color = node->Node.rbe_color;
 #endif /* __rtems__ */
2.13.7
