jffs2 changes and Coverity issue in porting code
Joel Sherrill
joel at rtems.org
Thu Jul 5 15:52:36 UTC 2018
Hi
By any chance, do any of the jffs2 updates pick up changes
to that method in the porting layer which Coverity thought
had an issue?
I know the code is the same across multiple OSes and you
didn't invent or modify it porting jffs2 to RTEMS. Just curious
if the situation might have changed.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180705/cf300ca6/attachment-0001.html>
