Gcov support in Covoar
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Thu Jul 5 20:30:58 UTC 2018
I think that the whole gcov support needs to be reworked.
I was looking into how llvm outputs their gcov data in gcda file
format here
https://github.com/llvm-mirror/compiler-rt/blob/master/lib/profile/GCDAProfiling.c
I need some help in understanding the workflow of how covoar
gets the trace input and how that is dumped into a gcda file.
What files are involved in the process (other than GcovData.cc and
GcovFunctionData.cc ) and what are their roles ?
I feel that this is very difficult to be able to do the whole work within
the GSoC period and the work will go on post GSoC as well.
So we need to set milestones specific to GSoC and then continue
from there post GSoC.
On 5 July 2018 at 00:50, Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Jul 4, 2018, 1:46 PM Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> On 4 July 2018 at 22:37, Joel Sherrill <joel at rtems.org> wrote:
>>> On Wed, Jul 4, 2018, 3:06 AM Chris Johns <chrisj at rtems.org> wrote:
>>>> On 4/7/18 5:55 pm, Vijay Kumar Banerjee wrote:
>>>> > On 4 July 2018 at 13:09, Chris Johns <chrisj at rtems.org
>>>> > <mailto:chrisj at rtems.org>> wrote:
>>>> > On 4/7/18 5:38 pm, Chris Johns wrote:
>>>> > > On 4/7/18 4:52 pm, Vijay Kumar Banerjee wrote:
>>>> > >> I'm starting this thread for discussions on the gcov support
>>>> > >> in covoar.
>>>> > >> Current status is that the code in it (like in GcovData.cc)
>>>> remained untouched
>>>> > >> for a long time and it had not been updated after the source
>>>> tree reorganization
>>>> > >> which is why it runs into segmentation
>>>> > >> fault while trying to find the source files.
>>>> > >> Joel was suggesting to copy the file gcov-io.h from the gcc
>>>> > >> source after a license discussion here.
>>>> > > What license the file's license?
>>>> > Sorry .. What is the file's license?
>>>> > GPL version 3
>>>> This license is not suitable.
>>> It has the runtime exception and is the only file that defines the
>>> format of gcno and (need to double-check) gcda file. It does not
>>> contaminate anything.
>>> I don't see anyway to interpret gcno or write gcda data otherwise.
>>> How does llvm address this? Don't that have the same issue?
>>> llvm defines it in GCOV.h file in llvm/ProfileData/ under the license
>> it's mentioned there that it's distributed under University of Illinois
>> Open Source License
>> https://github.com/llvm-mirror/llvm/blob/master/
>> include/llvm/ProfileData/GCOV.h
>> <https://github.com/llvm-mirror/llvm/blob/master/include/llvm/ProfileData/GCOV.h>
> That would be the preferred way to get this header. Is it technically
> acceptable?
> Chris.. license acceptable to you?
>> Ultimately we have two file formats that we have to deal with that GCC
>>> for sure defines and llvm might also.
>>>> > > We are aiming to have all code under the RTEMS Tools under a
>>>> BSD or compatible
>>>> > > license. Are there other options that have a more suitable
>>>> license?
>>> Llvm would be the only option but this has the rules time exception like
>>> the RTEMS historical license so it non-viral.
>>> A hack would be to ensure they are installed with the RTEMS GCC by the
>>> RSB. But that would be lifting a file out of the GCC source and one from
>>> the build tree that are normally not installed. We could ask about GCC
>>> doing that.
>>>> > > Also, could you please explain how gcov fits into the coverage
>>>> testing?
>>>> > gcov is a test coverage program by gcc that generates
>>>> statement-by-statement
>>>> > profiling.
>>>> > (https://gcc.gnu.org/onlinedocs/gcc/Gcov-Intro.html)
>>>> Yes.
>>>> > once we're able to generate gcov reports we can run graphical tools
>>>> like lcov or
>>>> > gcovr to generate html and xml reports with detailed coverage data.
>>>> > an example of lcov report:
>>>> > http://ltp.sourceforge.net/coverage/lcov/output/example/
>>>> methods/iterate.c.gcov.html
>>>> Do you want to export gcov files from the other trace formats we handle?
>>> Gcov reads gcda files for execution information. Rather than the
>>> executable being instrumented and writing this during execution (libgcov),
>>> covoar generates gcda files for unmodified executables using simulator
>>> trace information. But you have to read gcno files and write gcda files.
>>>> How does this fit into the RTEMS Tester tool?
>>> If you want to run gcov or lcov on uninstrumented executables, then
>>> covoar has to read gcno and write gcda files. And we have to then run gcov
>>> or lcov as normal.
>>> It is the path to another report format.
>>>> Chris
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180706/198dd1f2/attachment-0001.html>
