[GSoC - x86_64] Minimal BSP to review
Fri Jul 6 01:01:11 UTC 2018
On Thu, Jul 5, 2018 at 10:02 AM, Amaan Cheval <amaan.cheval at gmail.com> wrote:
> Hi!
> Yeah, the individual commits aren't logical at all. I just thought we
> could review the actual code contents (in the "files changed" tab) on
> Github (https://github.com/AmaanC/rtems-gsoc18/pull/1/files). Is this
> what you meant by "final patchset"?
> Once this PR is polished up sufficiently, I can submit the squashed,
> rebased commits to devel - that way we maintain the commit history for
> how things progressed temporally, and still have the logical commits
> we want upstream.
> If you'd prefer, I can squash on Github too (it just means I'd then
> for a brief period not have the "daily" commit branch we aim to have
> for GSoC, as I'd have to rebase to make changes instead of adding new
> commits to the daily branch to indicate more "work done"). Let me know
> if you prefer this!
You can do your squash/fixup on a new branch, and then restart your
daily when needed. It is OK for the merger period to have less code
activity.
I took a quick look and commented on your github.
> Thanks for catching the missing copyright in linkcmds!
> On Thu, Jul 5, 2018 at 7:16 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Hello Amaan,
>> I think it is quite confusing to review the individual commit. I will review
>> the final patch set.
>> Just one thing:
>> x86_64-rtems5-ld --verbose | head -n 20
>> GNU ld (GNU Binutils) 2.30
>>   Supported emulations:
>>    elf_x86_64
>>    elf_i386
>>    elf_iamcu
>>    elf32_x86_64
>>    elf_l1om
>>    elf_k1om
>> using internal linker script:
>> /* Script for -z combreloc: combine and sort reloc sections */
>> /* Copyright (C) 2014-2018 Free Software Foundation, Inc.
>>    Copying and distribution of this script, with or without modification,
>>    are permitted in any medium without royalty provided the copyright
>>    notice and this notice are preserved.  */
>> OUTPUT_FORMAT("elf64-x86-64", "elf64-x86-64",
>>               "elf64-x86-64")
>> OUTPUT_ARCH(i386:x86-64)
>> ENTRY(_start)
>> SEARCH_DIR("/build/rtems/5/x86_64-rtems5/lib");
>> Please add the FSF notice to your file if necessary.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
