jffs2 changes and Coverity issue in porting code
Fri Jul 6 05:19:03 UTC 2018
Hello Joel,
On 05/07/18 17:52, Joel Sherrill wrote:
> Hi
> By any chance, do any of the jffs2 updates pick up changes
> to that method in the porting layer which Coverity thought
> had an issue?
> I know the code is the same across multiple OSes and you
> didn't invent or modify it porting jffs2 to RTEMS. Just curious
> if the situation might have changed.
you mean this one:
https://lists.rtems.org/pipermail/devel/2014-November/009331.html
The eCos upstream seems to be dead. So, we have to fix this on our own.
Would it be possible to run Coverity with the latest RTEMS?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
