jffs2 changes and Coverity issue in porting code
Joel Sherrill
joel at rtems.org
Fri Jul 6 12:44:13 UTC 2018
On Fri, Jul 6, 2018, 12:19 AM Sebastian Huber <
> Hello Joel,
> On 05/07/18 17:52, Joel Sherrill wrote:
> > Hi
> > By any chance, do any of the jffs2 updates pick up changes
> > to that method in the porting layer which Coverity thought
> > had an issue?
> > I know the code is the same across multiple OSes and you
> > didn't invent or modify it porting jffs2 to RTEMS. Just curious
> > if the situation might have changed.
> you mean this one:
> https://lists.rtems.org/pipermail/devel/2014-November/009331.html
> The eCos upstream seems to be dead. So, we have to fix this on our own.
> Would it be possible to run Coverity with the latest RTEMS?
I will try to do this next week. All the computers at OAR are down.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180706/0237d19d/attachment.html>
