[PATCH 1/2] bsp/x86_64: Minimal bootable BSP
Amaan Cheval amaan.cheval at gmail.com
Mon Jul 9 11:12:56 UTC 2018
Current state:
  - Basic context initialization and switching code.
  - Stubbed console (empty functions).
  - Mostly functional linker script (may need tweaks if we ever want to move
    away from the large code model (see: CPU_CFLAGS).
  - Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for
    UEFI-awareness.
In short, the current state with this commit lets us boot, go through the system
initialization functions, and then call user application's Init task too.
Updates #2898.
 bsps/x86_64/amd64/config/amd64.cfg                 |  13 +
 bsps/x86_64/amd64/console/console.c                | 135 ++++++++
 bsps/x86_64/amd64/headers.am                       |   7 +
 bsps/x86_64/amd64/include/bsp.h                    |  51 +++
 bsps/x86_64/amd64/include/start.h                  |  47 +++
 bsps/x86_64/amd64/include/tm27.h                   |   1 +
 bsps/x86_64/amd64/start/bsp_specs                  |   9 +
 bsps/x86_64/amd64/start/bspstart.c                 |  32 ++
 bsps/x86_64/amd64/start/linkcmds                   | 281 ++++++++++++++++
 bsps/x86_64/amd64/start/start.c                    |  36 +++
 c/src/aclocal/rtems-cpu-subdirs.m4                 |   1 +
 c/src/lib/libbsp/x86_64/Makefile.am                |   7 +
 c/src/lib/libbsp/x86_64/acinclude.m4               |  10 +
 c/src/lib/libbsp/x86_64/amd64/Makefile.am          |  40 +++
 c/src/lib/libbsp/x86_64/amd64/configure.ac         |  19 ++
 c/src/lib/libbsp/x86_64/configure.ac               |  20 ++
 cpukit/configure.ac                                |   1 +
 cpukit/librpc/src/xdr/xdr_float.c                  |   3 +-
 cpukit/score/cpu/x86_64/Makefile.am                |  12 +
 cpukit/score/cpu/x86_64/cpu.c                      |  83 +++++
 cpukit/score/cpu/x86_64/headers.am                 |  16 +
 .../score/cpu/x86_64/include/machine/elf_machdep.h |   4 +
 cpukit/score/cpu/x86_64/include/rtems/asm.h        | 134 ++++++++
 cpukit/score/cpu/x86_64/include/rtems/score/cpu.h  | 359 +++++++++++++++++++++
 .../cpu/x86_64/include/rtems/score/cpuatomic.h     |  14 +
 .../score/cpu/x86_64/include/rtems/score/cpuimpl.h |  37 +++
 .../score/cpu/x86_64/include/rtems/score/x86_64.h  |  41 +++
 .../score/cpu/x86_64/x86_64-context-initialize.c   |  95 ++++++
 cpukit/score/cpu/x86_64/x86_64-context-switch.S    |  98 ++++++
 29 files changed, 1605 insertions(+), 1 deletion(-)
 create mode 100644 bsps/x86_64/amd64/config/amd64.cfg
 create mode 100644 bsps/x86_64/amd64/console/console.c
 create mode 100644 bsps/x86_64/amd64/headers.am
 create mode 100644 bsps/x86_64/amd64/include/bsp.h
 create mode 100644 bsps/x86_64/amd64/include/start.h
 create mode 100644 bsps/x86_64/amd64/include/tm27.h
 create mode 100644 bsps/x86_64/amd64/start/bsp_specs
 create mode 100644 bsps/x86_64/amd64/start/bspstart.c
 create mode 100644 bsps/x86_64/amd64/start/linkcmds
 create mode 100644 bsps/x86_64/amd64/start/start.c
 create mode 100644 c/src/lib/libbsp/x86_64/Makefile.am
 create mode 100644 c/src/lib/libbsp/x86_64/acinclude.m4
 create mode 100644 c/src/lib/libbsp/x86_64/amd64/Makefile.am
 create mode 100644 c/src/lib/libbsp/x86_64/amd64/configure.ac
 create mode 100644 c/src/lib/libbsp/x86_64/configure.ac
 create mode 100644 cpukit/score/cpu/x86_64/Makefile.am
 create mode 100644 cpukit/score/cpu/x86_64/cpu.c
 create mode 100644 cpukit/score/cpu/x86_64/headers.am
 create mode 100644 cpukit/score/cpu/x86_64/include/machine/elf_machdep.h
 create mode 100644 cpukit/score/cpu/x86_64/include/rtems/asm.h
 create mode 100644 cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
 create mode 100644 cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h
 create mode 100644 cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
 create mode 100644 cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
 create mode 100644 cpukit/score/cpu/x86_64/x86_64-context-initialize.c
 create mode 100644 cpukit/score/cpu/x86_64/x86_64-context-switch.S
diff --git a/bsps/x86_64/amd64/config/amd64.cfg b/bsps/x86_64/amd64/config/amd64.cfg
new file mode 100644
index 0000000000..3c4492d9d3
--- /dev/null
+++ b/bsps/x86_64/amd64/config/amd64.cfg
@@ -0,0 +1,13 @@
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = x86_64
+CFLAGS_OPTIMIZE_V += -O2 -g
+CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
+# We can't have the red zone because interrupts will not respect that area.
+CPU_CFLAGS  = -mno-red-zone
+# This flag tells GCC to not assume values will fit in 32-bit registers. This
+# way we can avoid linker-time relocation errors spawning from values being
+# larger than their optimized container sizes.
+CPU_CFLAGS += -mcmodel=large
diff --git a/bsps/x86_64/amd64/console/console.c b/bsps/x86_64/amd64/console/console.c
index 0000000000..b272b679d7
--- /dev/null
+++ b/bsps/x86_64/amd64/console/console.c
@@ -0,0 +1,135 @@
+ * Copyright (c) 2018.
+ * Amaan Cheval <amaan.cheval at gmail.com>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <bsp.h>
+#include <rtems/bspIo.h>
+#include <rtems/libio.h>
+/*  console_initialize
+ *  This routine initializes the console IO driver.
+ *  Input parameters: NONE
+ *  Output parameters:  NONE
+ *  Return values:
+rtems_device_driver console_initialize(
+  rtems_device_major_number  major,
+  rtems_device_minor_number  minor,
+  void                      *arg
+  (void) major;
+  (void) minor;
+  (void) arg;
+  return RTEMS_SUCCESSFUL;
+ *  Open entry point
+rtems_device_driver console_open(
+  void                    * arg
+  (void) major;
+  (void) minor;
+  (void) arg;
+ *  Close entry point
+rtems_device_driver console_close(
+  void                    * arg
+  (void) major;
+  (void) minor;
+  (void) arg;
+ * read bytes from the serial port. We only have stdin.
+rtems_device_driver console_read(
+  void                    * arg
+  (void) major;
+  (void) minor;
+  (void) arg;
+ * write bytes to the serial port. Stdout and stderr are the same.
+rtems_device_driver console_write(
+  void                    * arg
+  (void) major;
+  (void) minor;
+  (void) arg;
+  return 0;
+ *  IO Control entry point
+rtems_device_driver console_control(
+  void                    * arg
+  (void) major;
+  (void) minor;
+  (void) arg;
+BSP_output_char_function_type     BSP_output_char = NULL;
+BSP_polling_getchar_function_type BSP_poll_char   = NULL;
diff --git a/bsps/x86_64/amd64/headers.am b/bsps/x86_64/amd64/headers.am
index 0000000000..f9f42e7fd3
--- /dev/null
+++ b/bsps/x86_64/amd64/headers.am
@@ -0,0 +1,7 @@
+## This file was generated by "./boostrap -H".
+include_HEADERS =
+include_HEADERS += ../../../../../../bsps/x86_64/amd64/include/bsp.h
+include_HEADERS += include/bspopts.h
+include_HEADERS += ../../../../../../bsps/x86_64/amd64/include/start.h
+include_HEADERS += ../../../../../../bsps/x86_64/amd64/include/tm27.h
diff --git a/bsps/x86_64/amd64/include/bsp.h b/bsps/x86_64/amd64/include/bsp.h
index 0000000000..2fa6da42a0
--- /dev/null
+++ b/bsps/x86_64/amd64/include/bsp.h
@@ -0,0 +1,51 @@
+/*  bsp.h
+ *  This include file contains all board IO definitions.
+ * Copyright (c) 1989-1999.
+ * On-Line Applications Research Corporation (OAR).
+ * are met:
+ * SUCH DAMAGE.
+#ifndef LIBBSP_X86_64_AMD64_BSP_H
+#define LIBBSP_X86_64_AMD64_BSP_H
+#include <bspopts.h>
+#include <bsp/default-initial-extension.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/bsps/x86_64/amd64/include/start.h b/bsps/x86_64/amd64/include/start.h
index 0000000000..eee249e3a6
--- /dev/null
+++ b/bsps/x86_64/amd64/include/start.h
@@ -0,0 +1,47 @@
+ * are met:
+ * SUCH DAMAGE.
+#ifndef LIBBSP_AMD64_START_H
+#define LIBBSP_AMD64_START_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @brief Entry point for generated ELF.
+ * The linkcmds script sets this function as the entry point, to be jumped into
+ * the bootloader. It calls boot_card and kicks the whole RTEMS initialization
+ * process off.
+void _start(void);
+#ifdef __cplusplus
+#endif /* LIBBSP_AMD64_START_H */
diff --git a/bsps/x86_64/amd64/include/tm27.h b/bsps/x86_64/amd64/include/tm27.h
index 0000000000..0dfa7bf628
--- /dev/null
+++ b/bsps/x86_64/amd64/include/tm27.h
@@ -0,0 +1 @@
+#include <rtems/tm27-default.h>
diff --git a/bsps/x86_64/amd64/start/bsp_specs b/bsps/x86_64/amd64/start/bsp_specs
index 0000000000..87638cc027
--- /dev/null
+++ b/bsps/x86_64/amd64/start/bsp_specs
@@ -0,0 +1,9 @@
+%rename endfile old_endfile
+%rename startfile old_startfile
+*startfile:
+%{!qrtems: %(old_startfile)} \
+%{!nostdlib: %{qrtems: crti.o%s crtbegin.o%s}}
+*endfile:
+%{!qrtems: %(old_endfile)} %{qrtems: crtend.o%s crtn.o%s}
diff --git a/bsps/x86_64/amd64/start/bspstart.c b/bsps/x86_64/amd64/start/bspstart.c
index 0000000000..784748ce3f
--- /dev/null
+++ b/bsps/x86_64/amd64/start/bspstart.c
@@ -0,0 +1,32 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <bsp.h>
+#include <bsp/bootcard.h>
+void bsp_start(void)
diff --git a/bsps/x86_64/amd64/start/linkcmds b/bsps/x86_64/amd64/start/linkcmds
index 0000000000..46b1ccbfe7
--- /dev/null
+++ b/bsps/x86_64/amd64/start/linkcmds
@@ -0,0 +1,281 @@
+/* Copyright (C) 2014-2018 Free Software Foundation, Inc.
+   Copying and distribution of this script, with or without modification,
+   are permitted in any medium without royalty provided the copyright
+   notice and this notice are preserved.  */
+ * Copy of default linker script generated with:
+ *      x86_64-rtems5-ld --verbose
+ * Changes:
+ *   - Added HeapSize, RamBase, RamSize, WorkBase
+ *   - rtemssroset section
+ *   - rtemsstack section
+OUTPUT_FORMAT("elf64-x86-64", "elf64-x86-64",
+          "elf64-x86-64")
+OUTPUT_ARCH(i386:x86-64)
+ENTRY(_start)
+HeapSize = DEFINED(HeapSize)  ? HeapSize  :
+           DEFINED(_HeapSize) ? _HeapSize : 0x0;
+RamBase = DEFINED(RamBase)    ? RamBase   :
+          DEFINED(_RamBase)   ? _RamBase  : 0x0;
+/* XXX: Defaulting to 4GiB.
+RamSize = DEFINED(RamSize)    ? RamSize   :
+          DEFINED(_RamSize)   ? _RamSize  : 0xFFFFFFFF;
+SECTIONS
+  /* Read-only sections, merged into text segment: */
+  PROVIDE (__executable_start = SEGMENT_START("text-segment", 0x400000)); . = SEGMENT_START("text-segment", 0x400000) + SIZEOF_HEADERS;
+  .interp         : { *(.interp) }
+  .note.gnu.build-id : { *(.note.gnu.build-id) }
+  .hash           : { *(.hash) }
+  .gnu.hash       : { *(.gnu.hash) }
+  .dynsym         : { *(.dynsym) }
+  .dynstr         : { *(.dynstr) }
+  .gnu.version    : { *(.gnu.version) }
+  .gnu.version_d  : { *(.gnu.version_d) }
+  .gnu.version_r  : { *(.gnu.version_r) }
+  .rela.dyn       :
+      *(.rela.init)
+      *(.rela.text .rela.text.* .rela.gnu.linkonce.t.*)
+      *(.rela.fini)
+      *(.rela.rodata .rela.rodata.* .rela.gnu.linkonce.r.*)
+      *(.rela.data .rela.data.* .rela.gnu.linkonce.d.*)
+      *(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
+      *(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*)
+      *(.rela.ctors)
+      *(.rela.dtors)
+      *(.rela.got)
+      *(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*)
+      *(.rela.ldata .rela.ldata.* .rela.gnu.linkonce.l.*)
+      *(.rela.lbss .rela.lbss.* .rela.gnu.linkonce.lb.*)
+      *(.rela.lrodata .rela.lrodata.* .rela.gnu.linkonce.lr.*)
+      *(.rela.ifunc)
+  .rela.plt       :
+      *(.rela.plt)
+      PROVIDE_HIDDEN (__rela_iplt_start = .);
+      *(.rela.iplt)
+      PROVIDE_HIDDEN (__rela_iplt_end = .);
+  .rtemsroset : {
+    /* for pre rtems-libbsd FreeBSD code */
+    __start_set_sysctl_set = .;
+    *(set_sysctl_*);
+    __stop_set_sysctl_set = .;
+    *(set_domain_*);
+    *(set_pseudo_*);
+    KEEP (*(SORT(.rtemsroset.*)))
+  } =0x90909090
+  .init           :
+    KEEP (*(SORT_NONE(.init)))
+  .plt            : { *(.plt) *(.iplt) }
+.plt.got        : { *(.plt.got) }
+.plt.sec        : { *(.plt.sec) }
+  .text           :
+    *(.text.unlikely .text.*_unlikely .text.unlikely.*)
+    *(.text.exit .text.exit.*)
+    *(.text.startup .text.startup.*)
+    *(.text.hot .text.hot.*)
+    *(.text .stub .text.* .gnu.linkonce.t.*)
+    /* .gnu.warning sections are handled specially by elf32.em.  */
+    *(.gnu.warning)
+  .fini           :
+    KEEP (*(SORT_NONE(.fini)))
+  PROVIDE (__etext = .);
+  PROVIDE (_etext = .);
+  PROVIDE (etext = .);
+  .rodata         : { *(.rodata .rodata.* .gnu.linkonce.r.*) }
+  .rodata1        : { *(.rodata1) }
+  .eh_frame_hdr : { *(.eh_frame_hdr) *(.eh_frame_entry .eh_frame_entry.*) }
+  .eh_frame       : ONLY_IF_RO { KEEP (*(.eh_frame)) *(.eh_frame.*) }
+  .gcc_except_table   : ONLY_IF_RO { *(.gcc_except_table
+  .gcc_except_table.*) }
+  .gnu_extab   : ONLY_IF_RO { *(.gnu_extab*) }
+  /* These sections are generated by the Sun/Oracle C++ compiler.  */
+  .exception_ranges   : ONLY_IF_RO { *(.exception_ranges
+  .exception_ranges*) }
+  /* Adjust the address for the data segment.  We want to adjust up to
+     the same address within the page on the next page up.  */
+  . = DATA_SEGMENT_ALIGN (CONSTANT (MAXPAGESIZE), CONSTANT (COMMONPAGESIZE));
+  /* Exception handling  */
+  .eh_frame       : ONLY_IF_RW { KEEP (*(.eh_frame)) *(.eh_frame.*) }
+  .gnu_extab      : ONLY_IF_RW { *(.gnu_extab) }
+  .gcc_except_table   : ONLY_IF_RW { *(.gcc_except_table .gcc_except_table.*) }
+  .exception_ranges   : ONLY_IF_RW { *(.exception_ranges .exception_ranges*) }
+  /* Thread Local Storage sections  */
+  .tdata      : {
+    _TLS_Data_begin = .;
+    *(.tdata .tdata.* .gnu.linkonce.td.*)
+    _TLS_Data_end = .;
+  .tbss           : {
+    _TLS_BSS_begin = .;
+    *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
+    _TLS_BSS_end = .;
+  _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
+  _TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin : _TLS_BSS_begin;
+  _TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
+  _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
+  _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
+  _TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
+  .preinit_array     :
+    PROVIDE_HIDDEN (__preinit_array_start = .);
+    KEEP (*(.preinit_array))
+    PROVIDE_HIDDEN (__preinit_array_end = .);
+  .init_array     :
+    PROVIDE_HIDDEN (__init_array_start = .);
+    KEEP (*(SORT_BY_INIT_PRIORITY(.init_array.*) SORT_BY_INIT_PRIORITY(.ctors.*)))
+    KEEP (*(.init_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .ctors))
+    PROVIDE_HIDDEN (__init_array_end = .);
+  .fini_array     :
+    PROVIDE_HIDDEN (__fini_array_start = .);
+    KEEP (*(SORT_BY_INIT_PRIORITY(.fini_array.*) SORT_BY_INIT_PRIORITY(.dtors.*)))
+    KEEP (*(.fini_array EXCLUDE_FILE (*crtbegin.o *crtbegin?.o *crtend.o *crtend?.o ) .dtors))
+    PROVIDE_HIDDEN (__fini_array_end = .);
+  .ctors          :
+    /* gcc uses crtbegin.o to find the start of
+       the constructors, so we make sure it is
+       first.  Because this is a wildcard, it
+       doesn't matter if the user does not
+       actually link against crtbegin.o; the
+       linker won't look for a file to match a
+       wildcard.  The wildcard also means that it
+       doesn't matter which directory crtbegin.o
+       is in.  */
+    KEEP (*crtbegin.o(.ctors))
+    KEEP (*crtbegin?.o(.ctors))
+    /* We don't want to include the .ctor section from
+       the crtend.o file until after the sorted ctors.
+       The .ctor section from the crtend file contains the
+       end of ctors marker and it must be last */
+    KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
+    KEEP (*(SORT(.ctors.*)))
+    KEEP (*(.ctors))
+  .dtors          :
+    KEEP (*crtbegin.o(.dtors))
+    KEEP (*crtbegin?.o(.dtors))
+    KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
+    KEEP (*(SORT(.dtors.*)))
+    KEEP (*(.dtors))
+  .jcr            : { KEEP (*(.jcr)) }
+  .data.rel.ro : { *(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*) *(.data.rel.ro .data.rel.ro.* .gnu.linkonce.d.rel.ro.*) }
+  .dynamic        : { *(.dynamic) }
+  .got            : { *(.got) *(.igot) }
+  . = DATA_SEGMENT_RELRO_END (SIZEOF (.got.plt) >= 24 ? 24 : 0, .);
+  .got.plt        : { *(.got.plt)  *(.igot.plt) }
+  .data           :
+    *(.data .data.* .gnu.linkonce.d.*)
+    SORT(CONSTRUCTORS)
+  .data1          : { *(.data1) }
+  _edata = .; PROVIDE (edata = .);
+  __bss_start = .;
+  .bss            :
+   *(.dynbss)
+   *(.bss .bss.* .gnu.linkonce.b.*)
+   *(COMMON)
+   /* Align here to ensure that the .bss section occupies space up to
+      _end.  Align after .bss to ensure correct alignment even if the
+      .bss section disappears because there are no input sections.
+      FIXME: Why do we need it? When there is no .bss section, we don't
+      pad the .data section.  */
+   . = ALIGN(. != 0 ? 64 / 8 : 1);
+  .lbss   :
+    *(.dynlbss)
+    *(.lbss .lbss.* .gnu.linkonce.lb.*)
+    *(LARGE_COMMON)
+  . = ALIGN(64 / 8);
+  . = SEGMENT_START("ldata-segment", .);
+  .lrodata   ALIGN(CONSTANT (MAXPAGESIZE)) + (. & (CONSTANT (MAXPAGESIZE) - 1)) :
+    *(.lrodata .lrodata.* .gnu.linkonce.lr.*)
+  .ldata   ALIGN(CONSTANT (MAXPAGESIZE)) + (. & (CONSTANT (MAXPAGESIZE) - 1)) :
+    *(.ldata .ldata.* .gnu.linkonce.l.*)
+  _end = .; PROVIDE (end = .);
+  .rtemsstack (NOLOAD) :
+    *(SORT(.rtemsstack.*))
+  WorkAreaBase = .;
+  . = DATA_SEGMENT_END (.);
+  /* Stabs debugging sections.  */
+  .stab          0 : { *(.stab) }
+  .stabstr       0 : { *(.stabstr) }
+  .stab.excl     0 : { *(.stab.excl) }
+  .stab.exclstr  0 : { *(.stab.exclstr) }
+  .stab.index    0 : { *(.stab.index) }
+  .stab.indexstr 0 : { *(.stab.indexstr) }
+  .comment       0 : { *(.comment) }
+  /* DWARF debug sections.
+     Symbols in the DWARF debugging sections are relative to the beginning
+     of the section so we begin them at 0.  */
+  /* DWARF 1 */
+  .debug          0 : { *(.debug) }
+  .line           0 : { *(.line) }
+  /* GNU DWARF 1 extensions */
+  .debug_srcinfo  0 : { *(.debug_srcinfo) }
+  .debug_sfnames  0 : { *(.debug_sfnames) }
+  /* DWARF 1.1 and DWARF 2 */
+  .debug_aranges  0 : { *(.debug_aranges) }
+  .debug_pubnames 0 : { *(.debug_pubnames) }
+  /* DWARF 2 */
+  .debug_info     0 : { *(.debug_info .gnu.linkonce.wi.*) }
+  .debug_abbrev   0 : { *(.debug_abbrev) }
+  .debug_line     0 : { *(.debug_line .debug_line.* .debug_line_end ) }
+  .debug_frame    0 : { *(.debug_frame) }
+  .debug_str      0 : { *(.debug_str) }
+  .debug_loc      0 : { *(.debug_loc) }
+  .debug_macinfo  0 : { *(.debug_macinfo) }
+  /* SGI/MIPS DWARF 2 extensions */
+  .debug_weaknames 0 : { *(.debug_weaknames) }
+  .debug_funcnames 0 : { *(.debug_funcnames) }
+  .debug_typenames 0 : { *(.debug_typenames) }
+  .debug_varnames  0 : { *(.debug_varnames) }
+  /* DWARF 3 */
+  .debug_pubtypes 0 : { *(.debug_pubtypes) }
+  .debug_ranges   0 : { *(.debug_ranges) }
+  /* DWARF Extension.  */
+  .debug_macro    0 : { *(.debug_macro) }
+  .debug_addr     0 : { *(.debug_addr) }
+  .gnu.attributes 0 : { KEEP (*(.gnu.attributes)) }
+  /DISCARD/ : { *(.note.GNU-stack) *(.gnu_debuglink) *(.gnu.lto_*) }
diff --git a/bsps/x86_64/amd64/start/start.c b/bsps/x86_64/amd64/start/start.c
index 0000000000..2dfeb7ebb8
--- /dev/null
+++ b/bsps/x86_64/amd64/start/start.c
@@ -0,0 +1,36 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <bsp.h>
+#include <start.h>
+// XXX: _start can pass boot arguments to boot_card
+// https://lists.rtems.org/pipermail/devel/2018-June/022123.html
+void _start(void)
+  boot_card("");
diff --git a/c/src/aclocal/rtems-cpu-subdirs.m4 b/c/src/aclocal/rtems-cpu-subdirs.m4
index 3ec5884fd1..edeaee9ed6 100644
--- a/c/src/aclocal/rtems-cpu-subdirs.m4
+++ b/c/src/aclocal/rtems-cpu-subdirs.m4
@@ -28,6 +28,7 @@ _RTEMS_CPU_SUBDIR([sh],[$1]);;
 _RTEMS_CPU_SUBDIR([sparc],[$1]);;
 _RTEMS_CPU_SUBDIR([sparc64],[$1]);;
 _RTEMS_CPU_SUBDIR([v850],[$1]);;
+_RTEMS_CPU_SUBDIR([x86_64],[$1]);;
 *) AC_MSG_ERROR([Invalid RTEMS_CPU <[$]{RTEMS_CPU}>])
 esac
diff --git a/c/src/lib/libbsp/x86_64/Makefile.am b/c/src/lib/libbsp/x86_64/Makefile.am
index 0000000000..c25b2d3f99
--- /dev/null
+++ b/c/src/lib/libbsp/x86_64/Makefile.am
@@ -0,0 +1,7 @@
+ACLOCAL_AMFLAGS = -I ../../../aclocal
+# Descend into the @RTEMS_BSP_FAMILY@ directory
+_SUBDIRS = @RTEMS_BSP_FAMILY@
+include $(top_srcdir)/../../../automake/subdirs.am
+include $(top_srcdir)/../../../automake/local.am
diff --git a/c/src/lib/libbsp/x86_64/acinclude.m4 b/c/src/lib/libbsp/x86_64/acinclude.m4
index 0000000000..92ae6f719e
--- /dev/null
+++ b/c/src/lib/libbsp/x86_64/acinclude.m4
@@ -0,0 +1,10 @@
+# RTEMS_CHECK_BSPDIR(RTEMS_BSP_FAMILY)
+AC_DEFUN([RTEMS_CHECK_BSPDIR],
+  case "$1" in
+  amd64 )
+    AC_CONFIG_SUBDIRS([amd64]);;
+    AC_MSG_ERROR([Invalid BSP]);;
+  esac
diff --git a/c/src/lib/libbsp/x86_64/amd64/Makefile.am b/c/src/lib/libbsp/x86_64/amd64/Makefile.am
index 0000000000..f05b40f3f9
--- /dev/null
+++ b/c/src/lib/libbsp/x86_64/amd64/Makefile.am
@@ -0,0 +1,40 @@
+ACLOCAL_AMFLAGS = -I ../../../../aclocal
+include $(top_srcdir)/../../../../automake/compile.am
+include $(top_srcdir)/../../bsp.am
+dist_project_lib_DATA = ../../../../../../bsps/x86_64/amd64/start/bsp_specs
+noinst_PROGRAMS =
+project_lib_DATA = linkcmds
+project_lib_LIBRARIES = librtemsbsp.a
+librtemsbsp_a_SOURCES =
+# startup
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspfatal-default.c
+#  XXX: We may want a custom bsp_work_area_initialize to detect memory size like
+#  the i386
+# FreeBSD's bootloader may leave a bootinfo structure for the kernel to find later:
+# http://fxr.watson.org/fxr/source/i386/include/bootinfo.h?v=FREEBSD11#L48
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-default.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/start/bspstart.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/start/start.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/sbrk.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/getentropy/getentropy-cpucounter.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspreset-empty.c
+# clock
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/clock/clock-simidle.c
+# console
+librtemsbsp_a_SOURCES += ../../../../../../bsps/x86_64/amd64/console/console.c
+# timer
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
+# cache
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/cache/nocache.c
+include $(top_srcdir)/../../../../automake/local.am
+include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
+include $(srcdir)/../../../../../../bsps/x86_64/amd64/headers.am
diff --git a/c/src/lib/libbsp/x86_64/amd64/configure.ac b/c/src/lib/libbsp/x86_64/amd64/configure.ac
index 0000000000..2f565fc4d9
--- /dev/null
+++ b/c/src/lib/libbsp/x86_64/amd64/configure.ac
@@ -0,0 +1,19 @@
+## Process this file with autoconf to produce a configure script.
+AC_PREREQ([2.69])
+AC_INIT([rtems-c-src-lib-libbsp-x86_64-amd64],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
+RTEMS_TOP(../../../../../..)
+RTEMS_SOURCE_TOP
+RTEMS_BUILD_TOP
+RTEMS_BSP_LINKCMDS
+RTEMS_CANONICAL_TARGET_CPU
+AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
+RTEMS_BSP_CONFIGURE
+RTEMS_BSP_CLEANUP_OPTIONS
+# Explicitly list all Makefiles here
+AC_CONFIG_FILES([Makefile])
+AC_OUTPUT
diff --git a/c/src/lib/libbsp/x86_64/configure.ac b/c/src/lib/libbsp/x86_64/configure.ac
index 0000000000..a398a4e202
--- /dev/null
+++ b/c/src/lib/libbsp/x86_64/configure.ac
@@ -0,0 +1,20 @@
+AC_PREREQ([2.69])
+AC_INIT([rtems-c-src-lib-libbsp-x86_64],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
+RTEMS_TOP(../../../../..)
+RTEMS_SOURCE_TOP
+RTEMS_BUILD_TOP
+AM_INIT_AUTOMAKE([no-define foreign subdir-objects 1.12.2])
+AM_MAINTAINER_MODE
+RTEMS_ENV_RTEMSBSP
+RTEMS_PROJECT_ROOT
+RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY])
+AC_OUTPUT
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 0361128e1d..17c47f445e 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -487,6 +487,7 @@ score/cpu/sh/Makefile
 score/cpu/sparc/Makefile
 score/cpu/sparc64/Makefile
 score/cpu/v850/Makefile
+score/cpu/x86_64/Makefile
 score/cpu/no_cpu/Makefile
 posix/Makefile
 libblock/Makefile
diff --git a/cpukit/librpc/src/xdr/xdr_float.c b/cpukit/librpc/src/xdr/xdr_float.c
index 989cbfffad..b2282b376a 100644
--- a/cpukit/librpc/src/xdr/xdr_float.c
+++ b/cpukit/librpc/src/xdr/xdr_float.c
@@ -76,7 +76,8 @@ static char *rcsid = "$FreeBSD: src/lib/libc/xdr/xdr_float.c,v 1.7 1999/08/28 00
     defined(__sh__) || \
     defined(__BFIN__) || \
     defined(__m32c__) || \
-    defined(__v850)
+    defined(__v850) || \
+    defined(__x86_64__)
 #include <rtems/endian.h>
 #if !defined(IEEEFP)
diff --git a/cpukit/score/cpu/x86_64/Makefile.am b/cpukit/score/cpu/x86_64/Makefile.am
index 0000000000..db4bd15cd5
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/Makefile.am
@@ -0,0 +1,12 @@
+include $(top_srcdir)/automake/compile.am
+noinst_LIBRARIES = libscorecpu.a
+libscorecpu_a_SOURCES  = cpu.c
+libscorecpu_a_SOURCES += ../no_cpu/cpucounterfrequency.c
+libscorecpu_a_SOURCES += ../no_cpu/cpucounterread.c
+libscorecpu_a_SOURCES += x86_64-context-initialize.c
+libscorecpu_a_SOURCES += x86_64-context-switch.S
+libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
+include $(top_srcdir)/automake/local.am
+include $(srcdir)/headers.am
diff --git a/cpukit/score/cpu/x86_64/cpu.c b/cpukit/score/cpu/x86_64/cpu.c
index 0000000000..308d231186
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/cpu.c
@@ -0,0 +1,83 @@
+ *  @file
+ *  @brief x86_64 Dependent Source
+ * are met:
+ * SUCH DAMAGE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/system.h>
+#include <rtems/score/isr.h>
+#include <rtems/score/wkspace.h>
+#include <rtems/score/tls.h>
+Context_Control_fp _CPU_Null_fp_context;
+void _CPU_Exception_frame_print(const CPU_Exception_frame *ctx)
+void _CPU_Initialize(void)
+uint32_t _CPU_ISR_Get_level(void)
+  return 0;
+void _CPU_ISR_install_raw_handler(
+  uint32_t    vector,
+  proc_ptr    new_handler,
+  proc_ptr   *old_handler
+void _CPU_ISR_install_vector(
+  uint32_t    vector,
+void _CPU_Install_interrupt_stack(void)
+void *_CPU_Thread_Idle_body(uintptr_t ignored)
+  for( ; ; ) { }
diff --git a/cpukit/score/cpu/x86_64/headers.am b/cpukit/score/cpu/x86_64/headers.am
index 0000000000..b3792d00b1
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/headers.am
@@ -0,0 +1,16 @@
+include_machinedir = $(includedir)/machine
+include_machine_HEADERS =
+include_machine_HEADERS += include/machine/elf_machdep.h
+include_rtemsdir = $(includedir)/rtems
+include_rtems_HEADERS =
+include_rtems_HEADERS += include/rtems/asm.h
+include_rtems_scoredir = $(includedir)/rtems/score
+include_rtems_score_HEADERS =
+include_rtems_score_HEADERS += include/rtems/score/cpu.h
+include_rtems_score_HEADERS += include/rtems/score/cpuatomic.h
+include_rtems_score_HEADERS += include/rtems/score/cpuimpl.h
+include_rtems_score_HEADERS += include/rtems/score/x86_64.h
diff --git a/cpukit/score/cpu/x86_64/include/machine/elf_machdep.h b/cpukit/score/cpu/x86_64/include/machine/elf_machdep.h
index 0000000000..5f5cf1d6e0
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/include/machine/elf_machdep.h
@@ -0,0 +1,4 @@
+ * XXX: Needs research as to purpose. Seems like this might do:
+ * https://github.com/NetBSD/src/blob/trunk/sys/arch/amd64/include/elf_machdep.h
diff --git a/cpukit/score/cpu/x86_64/include/rtems/asm.h b/cpukit/score/cpu/x86_64/include/rtems/asm.h
index 0000000000..36699140b7
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/include/rtems/asm.h
@@ -0,0 +1,134 @@
+ * @file rtems/asm.h
+ * @brief Addresses Incompatible Flavors Problems
+ *  This include file attempts to address the problems
+ *  caused by incompatible flavors of assemblers and
+ *  toolsets.  It primarily addresses variations in the
+ *  use of leading underscores on symbols and the requirement
+ *  that register names be preceded by a %.
+ *  NOTE: The spacing in the use of these macros
+ *        is critical to them working as advertised.
+ *  COPYRIGHT:
+ *  This file is based on similar code found in newlib available
+ *  from ftp.cygnus.com.  The file which was used had no copyright
+ *  notice.  This file is freely distributable as long as the source
+ *  of the file is noted.  This file is:
+ *  COPYRIGHT (c) 2018.
+ *  COPYRIGHT (c) 1994-2006.
+#ifndef _RTEMS_ASM_H
+#define _RTEMS_ASM_H
+ *  Indicate we are in an assembly file and get the basic CPU definitions.
+#ifndef ASM
+#define ASM
+#endif
+#include <rtems/score/cpuopts.h>
+#include <rtems/score/x86_64.h>
+#ifndef __USER_LABEL_PREFIX__
+ *  Recent versions of GNU cpp define variables which indicate the
+ *  need for underscores and percents.  If not using GNU cpp or
+ *  the version does not support this, then you will obviously
+ *  have to define these as appropriate.
+ *  This symbol is prefixed to all C program symbols.
+#define __USER_LABEL_PREFIX__ _
+#endif
+#undef __REGISTER_PREFIX__
+#define __REGISTER_PREFIX__ %
+#include <rtems/concat.h>
+/** Use the right prefix for global labels.  */
+#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
+/** Use the right prefix for registers.  */
+#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
+ *  define macros for all of the registers on this CPU
+#define rax REG (rax)
+#define rbx REG (rbx)
+#define rcx REG (rcx)
+#define rdx REG (rdx)
+#define rdi REG (rdi)
+#define rsi REG (rsi)
+#define rbp REG (rbp)
+#define rsp REG (rsp)
+#define r8  REG (r8)
+#define r9  REG (r9)
+#define r10 REG (r10)
+#define r11 REG (r11)
+#define r12 REG (r12)
+#define r13 REG (r13)
+#define r14 REG (r14)
+#define r15 REG (r15)
+// XXX: eax, ax, etc., segment registers
+ *  Define macros to handle section beginning and ends.
+/** This macro is used to denote the beginning of a code declaration. */
+#define BEGIN_CODE_DCL .text
+/** This macro is used to denote the end of a code declaration. */
+#define END_CODE_DCL
+/** This macro is used to denote the beginning of a data declaration section. */
+#define BEGIN_DATA_DCL .data
+/** This macro is used to denote the end of a data declaration section. */
+#define END_DATA_DCL
+/** This macro is used to denote the beginning of a code section. */
+#define BEGIN_CODE .text
+/** This macro is used to denote the end of a code section. */
+#define END_CODE
+/** This macro is used to denote the beginning of a data section. */
+#define BEGIN_DATA
+/** This macro is used to denote the end of a data section. */
+#define END_DATA
+/** This macro is used to denote the beginning of the
+ *  unitialized data section.
+#define BEGIN_BSS
+/** This macro is used to denote the end of the unitialized data section.  */
+#define END_BSS
+/** This macro is used to denote the end of the assembly file.  */
+#define END
+ *  This macro is used to declare a public global symbol.
+ *  @note This must be tailored for a particular flavor of the C compiler.
+ *  They may need to put underscores in front of the symbols.
+#define PUBLIC(sym) .globl SYM (sym)
+ *  This macro is used to prototype a public global symbol.
+#define EXTERN(sym) .globl SYM (sym)
+#endif
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
index 0000000000..012ef5069b
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpu.h
@@ -0,0 +1,359 @@
+ * @file rtems/score/cpu.h
+ * This include file contains information pertaining to the x86_64 processor.
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _RTEMS_SCORE_CPU_H
+#define _RTEMS_SCORE_CPU_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <rtems/score/basedefs.h>
+#define CPU_SIMPLE_VECTORED_INTERRUPTS FALSE
+#define CPU_ISR_PASSES_FRAME_POINTER FALSE
+// XXX: Enable FPU support
+#define CPU_HARDWARE_FP     FALSE
+#define CPU_SOFTWARE_FP     FALSE
+#define CPU_ALL_TASKS_ARE_FP     FALSE
+#define CPU_IDLE_TASK_IS_FP      FALSE
+#define CPU_USE_DEFERRED_FP_SWITCH       TRUE
+#define CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE
+#define CPU_PROVIDES_IDLE_THREAD_BODY    FALSE
+#define CPU_STACK_GROWS_UP               FALSE
+#define CPU_STRUCTURE_ALIGNMENT __attribute__((aligned ( 64 )))
+#define CPU_CACHE_LINE_BYTES 64
+#define CPU_MODES_INTERRUPT_MASK   0x00000001
+#define CPU_MAXIMUM_PROCESSORS 32
+#define CPU_EFLAGS_INTERRUPTS_ON  0x00003202
+#define CPU_EFLAGS_INTERRUPTS_OFF 0x00003002
+#ifndef ASM
+typedef struct {
+  uint64_t rflags;
+   * Callee-saved registers as listed in the SysV ABI document:
+   * https://github.com/hjl-tools/x86-psABI/wiki/X86-psABI
+  uint64_t rbx;
+  void    *rsp;
+  void    *rbp;
+  uint64_t r12;
+  uint64_t r13;
+  uint64_t r14;
+  uint64_t r15;
+  // XXX: FS segment descriptor for TLS
+#ifdef RTEMS_SMP
+    volatile bool is_executing;
+#endif
+} Context_Control;
+#define _CPU_Context_Get_SP( _context ) \
+  (_context)->rsp
+typedef struct {
+  /* XXX: MMX, XMM, others?
+   * All x87 registers are caller-saved, so callees that make use of the MMX
+   * registers may use the faster femms instruction
+  /** FPU registers are listed here */
+  double      some_float_register;
+} Context_Control_fp;
+typedef struct {
+    uint32_t   special_interrupt_register;
+} CPU_Interrupt_frame;
+#endif /* ASM */
+#define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
+#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
+#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
+#define CPU_STACK_MINIMUM_SIZE          (1024*4)
+#define CPU_SIZEOF_POINTER         8
+#define CPU_ALIGNMENT              8
+#define CPU_HEAP_ALIGNMENT         CPU_ALIGNMENT
+#define CPU_PARTITION_ALIGNMENT    CPU_ALIGNMENT
+#define CPU_STACK_ALIGNMENT        16
+#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
+ *  ISR handler macros
+#ifndef ASM
+#define _CPU_Initialize_vectors()
+// XXX: For RTEMS critical sections
+#define _CPU_ISR_Disable( _isr_cookie ) \
+    (_isr_cookie) = 0;   /* do something to prevent warnings */ \
+#define _CPU_ISR_Enable( _isr_cookie )  \
+    (void) (_isr_cookie);   /* prevent warnings from -Wunused-but-set-variable */ \
+#define _CPU_ISR_Flash( _isr_cookie ) \
+RTEMS_INLINE_ROUTINE bool _CPU_ISR_Is_enabled( uint32_t level )
+  return false;
+#define _CPU_ISR_Set_level( new_level ) \
+uint32_t   _CPU_ISR_Get_level( void );
+/* end of ISR handler macros */
+/* Context handler macros */
+#define _CPU_Context_Destroy( _the_thread, _the_context ) \
+void _CPU_Context_Initialize(
+  Context_Control *the_context,
+  void *stack_area_begin,
+  size_t stack_area_size,
+  uint32_t new_level,
+  void (*entry_point)( void ),
+  bool is_fp,
+  void *tls_area
+#define _CPU_Context_Restart_self( _the_context ) \
+   _CPU_Context_restore( (_the_context) );
+#define _CPU_Context_Initialize_fp( _destination )  \
+   *(*(_destination)) = _CPU_Null_fp_context; \
+/* end of Context handler macros */
+/* Fatal Error manager macros */
+#define _CPU_Fatal_halt( _source, _error ) \
+/* end of Fatal Error manager macros */
+/* Bitfield handler macros */
+#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
+#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
+#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
+    (_output) = 0;   /* do something to prevent warnings */ \
+#endif
+/* end of Bitfield handler macros */
+#define _CPU_Priority_Mask( _bit_number ) \
+  ( 1 << (_bit_number) )
+#endif
+#define _CPU_Priority_bits_index( _priority ) \
+  (_priority)
+#endif
+/* end of Priority handler macros */
+/* functions */
+void _CPU_Initialize(void);
+  uint32_t    vector,
+  uint32_t    vector,
+void _CPU_Install_interrupt_stack( void );
+void *_CPU_Thread_Idle_body( uintptr_t ignored );
+void _CPU_Context_switch(
+  Context_Control  *run,
+  Context_Control  *heir
+void _CPU_Context_restore(
+  Context_Control *new_context
+) RTEMS_NO_RETURN;
+void _CPU_Context_save_fp(
+  Context_Control_fp **fp_context_ptr
+void _CPU_Context_restore_fp(
+static inline void _CPU_Context_volatile_clobber( uintptr_t pattern );
+static inline void _CPU_Context_validate( uintptr_t pattern );
+  /* TODO */
+  while (1) {
+    /* TODO */
+typedef struct {
+  uint32_t processor_state_register;
+  uint32_t integer_registers [1];
+  double float_registers [1];
+} CPU_Exception_frame;
+void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
+static inline uint32_t CPU_swap_u32(
+  uint32_t value
+  uint32_t byte1, byte2, byte3, byte4, swapped;
+  byte4 = (value >> 24) & 0xff;
+  byte3 = (value >> 16) & 0xff;
+  byte2 = (value >> 8)  & 0xff;
+  byte1 =  value        & 0xff;
+  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
+  return swapped;
+#define CPU_swap_u16( value ) \
+  (((value&0xff) << 8) | ((value >> 8)&0xff))
+typedef uint32_t CPU_Counter_ticks;
+uint32_t _CPU_Counter_frequency( void );
+CPU_Counter_ticks _CPU_Counter_read( void );
+static inline CPU_Counter_ticks _CPU_Counter_difference(
+  CPU_Counter_ticks second,
+  CPU_Counter_ticks first
+  return second - first;
+#ifdef RTEMS_SMP
+  uint32_t _CPU_SMP_Initialize( void );
+  bool _CPU_SMP_Start_processor( uint32_t cpu_index );
+  void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
+  void _CPU_SMP_Prepare_start_multitasking( void );
+  static inline uint32_t _CPU_SMP_Get_current_processor( void )
+    return 123;
+  void _CPU_SMP_Send_interrupt( uint32_t target_processor_index );
+  static inline void _CPU_SMP_Processor_event_broadcast( void )
+    __asm__ volatile ( "" : : : "memory" );
+  static inline void _CPU_SMP_Processor_event_receive( void )
+  static inline bool _CPU_Context_Get_is_executing(
+    const Context_Control *context
+    return context->is_executing;
+  static inline void _CPU_Context_Set_is_executing(
+    Context_Control *context,
+    bool is_executing
+#endif /* RTEMS_SMP */
+typedef uintptr_t CPU_Uint32ptr;
+#ifdef __cplusplus
+#endif
+#endif /* ASM */
+#endif /* _RTEMS_SCORE_CPU_H */
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h
index 0000000000..598ee76b20
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpuatomic.h
@@ -0,0 +1,14 @@
+ * COPYRIGHT (c) 2012-2013 Deng Hengyi.
+#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
+#define _RTEMS_SCORE_ATOMIC_CPU_H
+#include <rtems/score/cpustdatomic.h>
+#endif /* _RTEMS_SCORE_ATOMIC_CPU_H */
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
index 0000000000..bac092c320
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h
@@ -0,0 +1,37 @@
+ * @file
+ * @brief CPU Port Implementation API
+ * Copyright (c) 2013, 2016 embedded brains GmbH
+#ifndef _RTEMS_SCORE_CPUIMPL_H
+#define _RTEMS_SCORE_CPUIMPL_H
+#include <rtems/score/cpu.h>
+#define CPU_PER_CPU_CONTROL_SIZE 0
+#ifndef ASM
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifdef __cplusplus
+#endif
+#endif /* ASM */
+#endif /* _RTEMS_SCORE_CPUIMPL_H */
diff --git a/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h b/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
index 0000000000..237d95de98
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h
@@ -0,0 +1,41 @@
+ * are met:
+ * SUCH DAMAGE.
+#ifndef _RTEMS_SCORE_X86_64_H
+#define _RTEMS_SCORE_X86_64_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define CPU_NAME "x86-64"
+#define CPU_MODEL_NAME "XXX: x86-64 generic"
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_SCORE_X86_64_H */
diff --git a/cpukit/score/cpu/x86_64/x86_64-context-initialize.c b/cpukit/score/cpu/x86_64/x86_64-context-initialize.c
index 0000000000..2324d16990
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/x86_64-context-initialize.c
@@ -0,0 +1,95 @@
+ * are met:
+ * SUCH DAMAGE.
+ * Stack alignment note:
+ * Per the x86-64 SysV ABI, the stack frame layout is as follows:
+ *       optional args
+ *       ------        (16-byte alignment boundary)
+ * RSP-> return_addr   (RSP is moved lower as needed for this frame)
+ * Per the ABI:
+ *  > The end of the input argument area shall be aligned on a 16 (32 or 64, if
+ *    __m256 or __m512 is passed on stack) byte boundary.
+ *  > In other words, the value (%rsp + 8) is always a multiple of 16 (32 or 64)
+ *    when control is transferred to the function entry point.
+ * We want the stack to look to the '_entry_point' routine
+ * like an ordinary stack frame as if '_entry_point' was
+ * called from C-code.
+ * Note that '_entry_point' is jumped-to by the 'ret'
+ * instruction returning from _CPU_Context_switch() or
+ * _CPU_Context_restore() thus popping the _entry_point
+ * from the stack.
+ * Hence we must initialize the stack as follows
+ *         [arg0 (aligned)]:  n/a
+ *         [ret. addr     ]:  NULL
+ * RSP->   [jump-target   ]:  _entry_point
+ * When Context_switch returns it pops the _entry_point from
+ * the stack which then finds a standard layout.
+  bool is_fp,
+  void *tls_area
+  uintptr_t _stack;
+  /* avoid warning for being unused */
+  (void) is_fp;
+  // XXX: Should be used in the future
+  (void) new_level;
+  (void) tls_area;
+  // XXX: Leaving interrupts off regardless of `new_level` for now
+  the_context->rflags = CPU_EFLAGS_INTERRUPTS_OFF;
+  _stack  = ((uintptr_t) stack_area_begin) + stack_area_size;
+  _stack &= ~(CPU_STACK_ALIGNMENT - 1);
+  _stack -= sizeof(uintptr_t); /* fake return address for entry_point's frame;
+                                * this allows rsp+8 to be an aligned boundary */
+  *((proc_ptr *) _stack) = entry_point;
+  the_context->rbp     = (void *) 0;
+  the_context->rsp     = (void *) _stack;
+  // XXX: Initialize thread-local storage area (TLS / TCB)
diff --git a/cpukit/score/cpu/x86_64/x86_64-context-switch.S b/cpukit/score/cpu/x86_64/x86_64-context-switch.S
index 0000000000..cb451e9acb
--- /dev/null
+++ b/cpukit/score/cpu/x86_64/x86_64-context-switch.S
@@ -0,0 +1,98 @@
+ * are met:
+ * SUCH DAMAGE.
+#endif
+#include <rtems/asm.h>
+#ifndef CPU_STACK_ALIGNMENT
+#error "Missing header? CPU_STACK_ALIGNMENT not defined"
+#endif
+BEGIN_CODE
+ *  void _CPU_Context_switch( run_context, heir_context )
+ *  This routine performs a normal non-FP context.
+.p2align  1
+PUBLIC(_CPU_Context_switch)
+.set RUNCONTEXT_ARG,   rdi                   /* save context argument */
+.set HEIRCONTEXT_ARG,  rsi                   /* restore context argument */
+SYM(_CPU_Context_switch):
+  movq    RUNCONTEXT_ARG, rax  /* rax = running threads context */
+  /* Fill up Context_Control struct */
+  pushf
+  popq               (0 * CPU_SIZEOF_POINTER)(rax) /* pop rflags into context */
+  movq    rbx,       (1 * CPU_SIZEOF_POINTER)(rax)
+  movq    rsp,       (2 * CPU_SIZEOF_POINTER)(rax)
+  movq    rbp,       (3 * CPU_SIZEOF_POINTER)(rax)
+  movq    r12,       (4 * CPU_SIZEOF_POINTER)(rax)
+  movq    r13,       (5 * CPU_SIZEOF_POINTER)(rax)
+  movq    r14,       (6 * CPU_SIZEOF_POINTER)(rax)
+  movq    r15,       (7 * CPU_SIZEOF_POINTER)(rax)
+  movq    HEIRCONTEXT_ARG, rax /* rax = heir threads context */
+restore:
+  pushq (0 * CPU_SIZEOF_POINTER)(rax)       /* push rflags */
+  popf                                      /* restore rflags */
+  movq  (1 * CPU_SIZEOF_POINTER)(rax), rbx
+  movq  (2 * CPU_SIZEOF_POINTER)(rax), rsp
+  movq  (3 * CPU_SIZEOF_POINTER)(rax), rbp
+  movq  (4 * CPU_SIZEOF_POINTER)(rax), r12
+  movq  (5 * CPU_SIZEOF_POINTER)(rax), r13
+  movq  (6 * CPU_SIZEOF_POINTER)(rax), r14
+  movq  (7 * CPU_SIZEOF_POINTER)(rax), r15
+  /* XXX: TLS - load GDT and refresh FS segment selector */
+  ret
+ *  void _CPU_Context_restore( new_context )
+ *  This routine performs a normal non-FP context restore.
+PUBLIC(_CPU_Context_restore)
+.set NEWCONTEXT_ARG,   rdi       /* context to restore argument */
+SYM(_CPU_Context_restore):
+  movq      NEWCONTEXT_ARG, rax  /* rax = running threads context */
+  jmp       restore
+END_CODE
+END
2.15.0
