[PATCH v3] coverage : Add support to run coverage in supported bsp without extra options
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Jul 10 12:11:15 UTC 2018
ping :)
On 6 July 2018 at 02:08, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Hello Chris,
> If you find some time, please review this patch.
> It's a small patch but it's important since it affects how the command
> will look like.
> please review if this patch is alright or we need to have a different
> approach.
> Thanks
> On 3 July 2018 at 20:30, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> Close #3440
>> tester/rt/test.py | 21 ++++++++++++++-------
>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 1 +
>> 2 files changed, 15 insertions(+), 7 deletions(-)
>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>> index 9214ad6..5d25d82 100644
>> --- a/tester/rt/test.py
>> +++ b/tester/rt/test.py
>> @@ -232,7 +232,7 @@ def run(command_path = None):
>> '--filter': 'Glob that executables must
>> match to run (default: ' +
>> default_exefilter + ')',
>> '--stacktrace': 'Dump a stack trace on a user
>> termination (^C)',
>> - '--coverage': 'Perform coverage analysis of
>> test executables.'}
>> + '--coverage-sets': 'Perform coverage analysis for
>> specific sets.'}
>> mailer.append_options(optargs)
>> opts = options.load(sys.argv,
>> optargs = optargs,
>> @@ -283,14 +283,21 @@ def run(command_path = None):
>> raise error.general('RTEMS BSP not provided or an invalid
>> option')
>> bsp = config.load(bsp[1], opts)
>> bsp_config = opts.defaults.expand(opts.defaults['tester'])
>> - coverage_enabled = opts.find_arg('--coverage')
>> + coverage_sets = opts.find_arg('--coverage-sets')
>> + try:
>> + coverage_enabled = opts.defaults.get('coverage')
>> + except:
>> + coverage_enabled = False
>> if coverage_enabled:
>> cov_trace = 'cov' in debug_trace.split(',')
>> - if len(coverage_enabled) == 2:
>> - coverage_runner = coverage.coverage_run(opts.defaults,
>> - executables,
>> - symbol_set =
>> coverage_enabled[1],
>> - trace =
>> cov_trace)
>> + if coverage_sets:
>> + if len(coverage_sets) != 2:
>> + raise error.general('No sets provided in
>> --coverage-sets')
>> + else:
>> + coverage_runner = coverage.coverage_run(opts.def
>> aults,
>> + executables,
>> + symbol_set =
>> coverage_sets[1],
>> + trace =
>> cov_trace)
>> else:
>> executables,
>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> index 2f89117..6462448 100644
>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> @@ -38,3 +38,4 @@ target = sparc-rtems5
>> tester = %{_rtscripts}/qemu.cfg
>> bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
>> bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>> +coverage = True
>> 2.14.4
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180710/12e72b04/attachment.html>
