[PATCH 0/1] [GSoC - x86_64] User documentation for BSP
Joel Sherrill
joel at rtems.org
Fri Jul 13 14:02:41 UTC 2018
On Fri, Jul 13, 2018 at 8:25 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Hello Amaan,
> On Fri, Jul 13, 2018 at 3:32 AM, Amaan Cheval <amaan.cheval at gmail.com>
> wrote:
> > The built documentation can more easily be viewed here:
> > http://whatthedude.com/rtems/user/html/bsps/bsps-x86_64.html
> > It feels a bit convoluted to me at the moment. I'd appreciate feedback
> on how
> > the documentation may be made more understandable, and on whether the
> current
> > approach even seems sustainable - specifically, using FreeBSD's
> bootloader ties
> > us into using the UFS filesystem and can slow down the
> iterative-development
> > process.
> I agree. It looks like you have to build FreeBSD at least one time to
> use this? Alternatives should be again considered for iterative
> improvement.
Reducing what has to be built is an important goal. But an alternative is
to host a pre-built binary of what is required to boot. I did that for a
boot
floppy for the pc386. There were instructions for making one and they
worked but, in practice, just grabbing the floppy image was easier.
Note; you didn't need to use a real floppy. Telling qemu what file
was the 1.44 MB image was all that was needed. Combine that with
vfat for c: and it worked find.
So I think we need both -- RSB for building from source and a pre-built
binary.
> > In my opinion, this system is good _enough_ for now - we can explore
> other
> > options later if time permits, but I'd love to hear differing opinions.
> > P.S. - Joel asked earlier if the QEMU that the RSB builds will suffice -
> for me,
> > it didn't because in it "SDL support is disabled" (and so are all other
> graphics
> > options). It's likely possible to install FreeBSD without graphics, it
> may not
> > be worth the effort of setting up - it's likely easier to update the
> RSB's QEMU
> > to also build graphics support.
> I was going to recommend this. You can make it an option of the qemu
> configuration in RSB to enable the support needed. I suggest you talk
> to Vijay as he has some experience now with RSB, and also this will
> require Chris Johns approval.
Everything that wasn't needed was disabled to make it easier to build
on multiple hosts. Too many projects are Linux monoculture and
getting things built on multiple hosts can be a pain.
But I think SDL support needs to be enabled since otherwise we have
no way to test graphics at all.
> Relatedly, does it make sense for you to look at creating an RSB
> "recipe" for building the UEFI firmware?
See above. I think we need RSB recipes for everything required that
we expect to be put together by a user. And we should host binaries
along with matching sources for some pre-built versions. I don't want
this BSP to be an order of magnitude harder to get started with than
any of the others.
> > P.P.S. - Some of the documentation is double-spaced, but this patch
> isn't. Let me
> > know if it ought to be (the README didn't say anything of the sort, and
> it isn't
> > consistent throughout).
> Stick to one consistent approach within your chapters. If consistency
> needs to be dealt with across chapters in a manual or across the set
> of manuals, that can be done later and simpler if each chapter is
> internally consistent.
How did some documentation get to be double-spaced? I thought we
had a consistent style of single space or something like 1.5. I have
never even thought of changing the line spacing and don't know how. :)
Sounds like we need to look at fixing the inconsistent places.
> > Amaan Cheval (1):
> > user: Add x86_64 BSP chapter
> > user/bsps/bsps-x86_64.rst | 143 ++++++++++++++++++++++++++++++
> > 1 file changed, 142 insertions(+), 1 deletion(-)
> > 2.16.0.rc0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180713/6614a6bf/attachment-0001.html>
