Gcov support in Covoar
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat Jul 14 21:29:21 UTC 2018
Hello,
As suggested by Joel, I have tried to figure out the structure of
the gcno files and written a gcno dumper.
This is not complete yet, I'm still working on it and I'll keep adding
to it as I "decode" the gcno files.
I'm attaching the c++ code, the gcno file I'm testing on and the txt
file generated from it.
please have a look. Is it moving in the right direction ?
On 12 July 2018 at 03:56, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> I have filed a ticket for gcov, as suggested by Joel.
> https://devel.rtems.org/ticket/3468
> -- vijay
> On 8 July 2018 at 01:43, Chris Johns <chrisj at rtems.org> wrote:
>> On 8/7/18 7:51 am, Vijay Kumar Banerjee wrote:
>> > On 8 July 2018 at 01:08, Joel Sherrill <joel at rtems.org <mailto:
>> joel at rtems.org>>
>> > wrote:
>> > On Sat, Jul 7, 2018, 2:33 PM Chris Johns <chris at contemporary.net.au
>> > <mailto:chris at contemporary.net.au>> wrote:
>> > On 5 Jul 2018, at 3:07 am, Joel Sherrill <joel at rtems.org
>> > <mailto:joel at rtems.org>
>> > <mailto:joel at rtems.org <mailto:joel at rtems.org>>> wrote:
>> > > On Wed, Jul 4, 2018, 3:06 AM Chris Johns <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>
>> > > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
>> > > How does this fit into the RTEMS Tester tool?
>> > > If you want to run gcov or lcov on uninstrumented
>> executables, then covoar has
>> > > to read gcno and write gcda files. And we have to then run
>> gcov or lcov as
>> > > normal.
>> > This is just a description of how it works. Not a particular
>> change.
>> > > It is the path to another report format.
>> > I am not sure I understand how we make this work and how we
>> support the
>> > user. Is
>> > this an option to 'rtems-test'?
>> > The aim of the 'rtems-test' command is to provide a documented
>> user
>> > interface.
>> > Providing direct access to covoar adds more documentation and
>> > complication to
>> > the test tool. For example how does the user wanting gcov
>> output get to the
>> > trace files? The user would need to step into how we implement
>> coverage
>> > and that
>> > is an interface we will not document and change.
>> > I wouldn't want a user to invoke covoar directly. It is just a
>> coverage
>> > reporting variant at this point. I doubt it will ever be the
>> default report
>> > format because we have details in the native reports that I don't
>> think you
>> > can get ever with gcov. I think the native format is closer to what
>> you
>> > would use on an analysis for the highest level of coverage.
>> > once covoar can generate the gcov reports, we can add it as an option
>> to rtems test.
>> > we can generate a file with the list of the notes/trace files from the
>> script
>> > which will work as an
>> > input to covoar, the user won't have to do anything manually.
>> Thank you. I now understand.
>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180715/fdfbb43a/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180715/fdfbb43a/attachment.zip>
